跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
iRobot Mint 4200 Wheel Motor Replacement
你所需要的
  1. iRobot Mint 4200 Wheel Motor Replacement, Remove Battery: 步骤 1 中的图像 1,1
    • Remove the 4mm flathead screw on the battery cover.
  2. iRobot Mint 4200 Wheel Motor Replacement: 步骤 2 中的图像 1,1
    • Pull out the battery and unplug the wires.
    • The nylon tip pliers can help you get a better grip on the battery plug.
    • Do not pull on the wires.
  3. iRobot Mint 4200 Wheel Motor Replacement, Wheel Motor Covers: 步骤 3 中的图像 1,1
    • Eight Phillips screws are located underneath the stickers.
    • Carefully cut around the 8 screw holes using an X-acto knife or razor blade to reveal the screws.
    • Remove the screws with a #2 Phillips screwdriver.
  4. iRobot Mint 4200 Wheel Motor Replacement: 步骤 4 中的图像 1,1
    • Separate wheel motor lid and set aside.
    How do you get cover off after removing the screws
    rebawmetz - 回复
  5. iRobot Mint 4200 Wheel Motor Replacement, Cleaning Pad: 步骤 5 中的图像 1,1
    • Remove cleaning pad.
    • The cleaning pad is magnetic and will pull right off with a little force.
  6. iRobot Mint 4200 Wheel Motor Replacement, Separating Top Case: 步骤 6 中的图像 1,1
    • Remove four #2 Phillips screws.
  7. iRobot Mint 4200 Wheel Motor Replacement, Separate Case: 步骤 7 中的图像 1,1
    • With the device upside down, pull up to separate the bottom from the top cover.
  8. iRobot Mint 4200 Wheel Motor Replacement, Wheel Removal: 步骤 8 中的图像 1,1
    • Locate the three arrows on each wheel.
    • Insert metal spudger at arrow locations to pop off the wheel covers.
  9. iRobot Mint 4200 Wheel Motor Replacement: 步骤 9 中的图像 1,1
    • Use blunt nose pliers to remove circlip.
    • Once clip is removed you can pull the wheel off in an outward motion.
    • Wedge one side of the pliers between the clip opening and carefully pry upwards.
  10. iRobot Mint 4200 Wheel Motor Replacement, Motor Mount: 步骤 10 中的图像 1,1
    • Remove two #1 Phillips screws.
    • Pull off sprocket.
  11. iRobot Mint 4200 Wheel Motor Replacement, Remove Counterweights: 步骤 11 中的图像 1,1
    • Remove four #2 Phillips and lift off retainer.
    • Pull out all weights and set aside
    • Keep weights stacked together so they do not get mixed up.
  12. iRobot Mint 4200 Wheel Motor Replacement, Unplug Motor: 步骤 12 中的图像 1,1
    • Unplug the motor.
    • Do not pull on the plug as this can cause damage.
  13. iRobot Mint 4200 Wheel Motor Replacement: 步骤 13 中的图像 1,1
    • Using the blunt nose pliers, peel up the adhesive and feed the wires with adhesive through the opening.
  14. iRobot Mint 4200 Wheel Motor Replacement, Pull the Motor Out: 步骤 14 中的图像 1,1
    • Flip the unit over and pull the motor out.
结论
另外一个人完成了本指南。
Blake Klein
于01/29/17注册
70,601 声望
创作了50篇指南
2条评论
Nice! Very helpful.
Evan Noronha - 回复
Popping the wheel covers as shown breaks the small hooks that hold the wheel cover on. You need to rotate the cover clock wise to release them. There probably is a special tool that uses the small impressions in the cover.
wayne peterson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 18
总计 1,708
