跳转到主内容
iRobot Braava 320 Body Shell Replacement
你所需要的
  1. iRobot Braava 320 Body Shell Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Body Shell Replacement: 步骤 2 中的图像 1,1
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Body Shell Replacement: 步骤 3 中的图像 1,2 iRobot Braava 320 Body Shell Replacement: 步骤 3 中的图像 2,2
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
  4. iRobot Braava 320 Body Shell Replacement, Body Shell and Control Panel: 步骤 4 中的图像 1,1
    • With the battery removed, rotate your device so the front of it is facing you.
    • Remove the four 10mm Phillips #2 screws that attach the shell.
  5. iRobot Braava 320 Body Shell Replacement: 步骤 5 中的图像 1,2 iRobot Braava 320 Body Shell Replacement: 步骤 5 中的图像 2,2
    • Using both hands, hold the device together while you flip it over.
    • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
结论
另外一个人完成了本指南。
Adam Lewis
于02/28/17注册
214 声望
撰写一个指南
团队
USF Tampa, Team S1-G3, Nance Spring 2017 USF Tampa, Team S1-G3, Nance Spring 2017 的会员
USFT-NANCE-S17S1G3
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 715
