跳转到主内容
iRULU AX106 Speaker Replacement
你所需要的
  1. iRULU AX106 Speaker Replacement, iRULU AX106 Disassembly: 步骤 1 中的图像 1,1
    • Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
    • There may be plastic covers protecting the screws, if this is the case take a phillips head screwdriver, and gently apply pressure on the covers until they come off.
  2. iRULU AX106 Speaker Replacement: 步骤 2 中的图像 1,2 iRULU AX106 Speaker Replacement: 步骤 2 中的图像 2,2
    • Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
    • While a good deal of force is required to separate the screen from the case, make sure to separate the screen from the case at each corner before attempting to completely remove the screen. There are delicate wires that may be damaged if the screen is removed is before the corners are separated.
  3. iRULU AX106 Speaker Replacement: 步骤 3 中的图像 1,3 iRULU AX106 Speaker Replacement: 步骤 3 中的图像 2,3 iRULU AX106 Speaker Replacement: 步骤 3 中的图像 3,3
    • Using a pair of tweezers, gently unplug connectors A and B from the logic board.
    • Completely separate the screen and case.
  4. iRULU AX106 Speaker Replacement, Speaker: 步骤 4 中的图像 1,1
    • Locate the two speakers and using the soldering iron and solder sucker carefully remove the solder that binds the two speakers down.
    • Insert the new speaker heads where the old speakers were previously.
    • Now use the soldering iron to solder the leads of the two speakers onto the logic board.
    • Be careful, the soldering iron will be extremely hot.
结论
Andrew Mele
于03/24/15注册
146 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015 的会员
UMASSD-VIJAYBHASKAR-S15S4G7
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 314
