跳转到主内容
iRULU AX106 Disassembly
你所需要的
  1. iRULU AX106 Disassembly, iRULU AX106 Disassembly: 步骤 1 中的图像 1,1
    • Using a Philips head #00 screwdriver locate and remove each of the four screws located along the tall side of the iRulu.
    • There may be plastic covers protecting the screws, if this is the case take a phillips head screwdriver, and gently apply pressure on the covers until they come off.
  2. iRULU AX106 Disassembly: 步骤 2 中的图像 1,2 iRULU AX106 Disassembly: 步骤 2 中的图像 2,2
    • Use the opening tool to pry the screen from the case applying pressure at each of the four corners of the screen.
    • While a good deal of force is required to separate the screen from the case, make sure to separate the screen from the case at each corner before attempting to completely remove the screen. There are delicate wires that may be damaged if the screen is removed is before the corners are separated.
  3. iRULU AX106 Disassembly: 步骤 3 中的图像 1,3 iRULU AX106 Disassembly: 步骤 3 中的图像 2,3 iRULU AX106 Disassembly: 步骤 3 中的图像 3,3
    • Using a pair of tweezers, gently unplug connectors A and B from the logic board.
    • Completely separate the screen and case.
结论
3等其他人完成本指南。
Andrew Mele
于03/24/15注册
146 声望
创作了2篇指南
团队
UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-7, Vijaybhaskar Spring 2015 的会员
UMASSD-VIJAYBHASKAR-S15S4G7
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 2,576
