跳转到主内容
iPod Touch 7th Generation Battery Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独使用。
你所需要的
  1. iPod Touch 7th Generation Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove three 1.6 mm #000 Phillips screws securing the logic board to the rear case.
  2. iPod Touch 7th Generation Battery Replacement, Warm back of iPod with heat gun or hair dryer: 步骤 2 中的图像 1,1
    • There are two strips of adhesive keeping the battery in place.
    • Turn the iPod over and heat the BACK of the aluminium iPod case. Do not heat the battery.
    • The aluminium case does not have to be hot; you should always be able to touch heated parts with your fingers at all times without it being uncomfortable.
  3. iPod Touch 7th Generation Battery Replacement: 步骤 3 中的图像 1,2 iPod Touch 7th Generation Battery Replacement: 步骤 3 中的图像 2,2
    • There are three notches on either side of the battery. In the next few steps, you will be using these notches to gradually pry the battery up from the rear case.
    • The battery is secured with large amounts of adhesive, so you'll need to go slowly and carefully to avoid puncturing or creasing the battery.
    • Insert a plastic opening tool into the top right notch and gently pry up on the battery.
    • Do not attempt to pry up the entire battery at this point; you just want to start to loosen the adhesive at each of the prying points, in turn.
  4. iPod Touch 7th Generation Battery Replacement: 步骤 4 中的图像 1,2 iPod Touch 7th Generation Battery Replacement: 步骤 4 中的图像 2,2
    • Continue with the lower right notch. Insert the plastic opening tool into the notch, and gently pry up on the side of the battery.
  5. iPod Touch 7th Generation Battery Replacement: 步骤 5 中的图像 1,2 iPod Touch 7th Generation Battery Replacement: 步骤 5 中的图像 2,2
    • Continue prying the battery up from the bottom.
    • When prying along the bottom, be careful not to press down too hard against the speaker or headphone jack.
  6. iPod Touch 7th Generation Battery Replacement: 步骤 6 中的图像 1,2 iPod Touch 7th Generation Battery Replacement: 步骤 6 中的图像 2,2
    • Pry along the left side as well.
    • You may need to move back and forth between the sides and bottom of the battery, prying a small amount at a time until the battery is entirely free from the adhesive.
  7. iPod Touch 7th Generation Battery Replacement: 步骤 7 中的图像 1,3 iPod Touch 7th Generation Battery Replacement: 步骤 7 中的图像 2,3 iPod Touch 7th Generation Battery Replacement: 步骤 7 中的图像 3,3
    • Once all of the adhesive is loosened, lift the battery up from the bottom and swing it out over the left side of the rear case.
    • Be sure not to yank it out, as it is soldered to the logic board.
    • Flip the battery over to straighten its cable and set it down.
结论
Tarun Thiruma
于11/20/19注册
37,718 声望
创作了134篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 7
总计 108
