简介
在iPod Touch 第五代中,逻辑板、电池、前置摄像头、Lightning连接器、扬声器、耳机插孔和home键被焊接在一起,形成一个整体。使用本指南拆卸整个总成。
你所需要的
屏幕的底部(接近Home键位置)粘合剂最强。
使用热风枪或者吹风机(低档位)来软化粘合剂。
在您进行下一步骤撬起屏幕前,您有可能需要再进一步加热来让粘合剂加温变得软化。
这里有两条胶带将电池固定到位。
将iPod翻转到背面,铝制后壳上。 切勿加热电池。
铝合金外壳不必太烫; 随时使用手指触碰确保不会加热过热。
要重新组装设备,请按照相反的顺序进行操作
9等其他人完成本指南。
由衷感谢以下译者:
100%
ZERO_TWICE正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
3条评论
Wouldn't this be a 5th generation touch since it has the wiggle yellow flex cable while the 6th generation has a straight ribbon cable as seen on the teardown?
yes and also the home button switch is different and the battery has pull tabs. its mostly the same process but omit the ones for the home button and add steps for the battery with pull tabs
Well I have been working on my friends ipod 5th. I got a new screen but it would not go back to gether. I thank it need a battery it was puffy in the middle. I did get a new battery but some how the new screen messed up. But I'm free brave now I'm going to fix it
