跳转到主内容
iPod Touch 5th Generation Lightning Connector Assembly Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iPod Touch 5th Generation Lightning Connector Assembly Replacement, Lightning Connector Assembly: 步骤 1 中的图像 1,1
    • Use the tip of a spudger to peel back a small piece of tape covering a screw on the left side of the headphone jack.
  2. iPod Touch 5th Generation Lightning Connector Assembly Replacement: 步骤 2 中的图像 1,1
    • Remove the following screws securing the headphone jack, Lightning connector, and speaker.
    • Three 2.6 mm #000 Phillips screws
    • Two 2.0 mm #000 Phillips screws
  3. iPod Touch 5th Generation Lightning Connector Assembly Replacement: 步骤 3 中的图像 1,1
    • Use the flat end of a spudger to pry the speaker up from the rear case.
    • Do not try to remove the speaker, as it is soldered to the Lightning connector assembly.
  4. iPod Touch 5th Generation Lightning Connector Assembly Replacement: 步骤 4 中的图像 1,2 iPod Touch 5th Generation Lightning Connector Assembly Replacement: 步骤 4 中的图像 2,2
    • Grasping the large ribbon cable, gently pull the Lightning connector assembly out of the bottom of the case.
结论
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 225
