简介
Click here for the most up-to-date guide for this procedure. The guide you are currently viewing is retained for historical purposes only.
你所需要的
with a heat gun 3 to 5 inches away on high heat up the glue the screen is held in with
when holding wear gloves or a thick cloth it will be very HOT
use a blade to separate from the casing
with an blade slice the black strips on the metal plat from the casing
take off all visible screws ALL make sure you take off all screws then with a plastic tool lift up the metal plate don t be shy use some force they are circled in red
in blue peel off the wifi connector with a thin blade
in the green just pop off the connector it is similar to a lego piece
take off the screw shown in the first picture
also take off the metal plate use you plastic tool to take it off in the blue
in the red unfold that thin foil type material
in the orange be to first take out the screw holding the camera in
in the green lift up the circuit make sure not to lift it to much as this can cause damage wait fot the next instructions to lift up
when you do lift up the circuit be careful with the wire in the red so not to damage it
in the blue is the back camera do not worried if you lift it out of place it simply pops back into place
另外一个人完成了本指南。
