跳转到主内容
iPod Touch第4代电池更换
你所需要的
  1. iPod Touch第4代电池更换, 前面板: 步骤 1 中的图像 1,1
    • iPod Touch第4代前面板通过粘合剂连接在后壳上。 强烈建议使用热风枪软化粘合剂。
    • 当热风枪温度调节在“低”位置时,开始加热触摸屏下部靠近主home键的位置。
    • 建议以绕圈圈的方法加热所需的部分,以均匀地散发整个装置的热量。
    do I have to use a heat gun
    Fabiola Winfield - 回复
    yes it is crucial
    ben folks -
    but u can use a hair dryer on warm
    ben folks -
    I didn't use a heat gun but this was due to the glass being rather shattered and not just cracked in the corner. The rule of thumb might be to not use excessive force, if you see that you need to use the heat gun or a blow dryer as someone suggested. I also wanted to point out the the adhesive strip just around the edges was exposed and it is rather strong so I was able to pull it around part of the edge which actually helped the glass disengage.
    nirv -
    Hi, thanks to this tutorial achieves replace my iPod battery to 100%, it was difficult, so thanks iFixit!
    The only problem I had was with the iFixit screwdriver disappointed me greatly, as it can not remove the screws with the screwdriver.
    A tip for those who first make repairs before starting the disarmament carefully read through the tutorial to not make a mistake that could damage your iPod and do not forget to place pieces in a safe place so they are not lost.
    Greetings from Guatemala
    Alfonso.
    Alfonso Espinoza - 回复
    well then u suck
    ben folks -
    Be careful with the heat gun!! Don`t use it too much. You can melt something inside, specially when you`re closing the iPod.
    Luiz R - 回复
    No man you can use a blow dryer!
    Colton B - 回复
    Would a heat bead bag be safer option to weaken the adhesive?
    Angus McLauchlan - 回复
    I had success with as low as 80°C using a hair dryer to melt the adhesive, I kept track of it with a meat thermometer. The battery says it's rated only up to 60°C...
    micahvanderhill - 回复
    I got through all the parts to take the wifi antenna out!! But, I'm having a hard time putting the stuff back!!
    ~Palm head~ But thank you ifixit for the great and awesome directions, I understand clearly!! Thank you very much
    Kaiden - 回复
    A hairdryer perfectly does the job. I’d recommend heating the bottom for 20 seconds, then attempt at inserting a plastic pick between the glass and the chassis. If it doesn’t work, reapply some heat in 10 seconds intervals until the glue gives in. You shouldn’t have to exert lots of force to release the adhesive, heat should do the job.
    Then apply some heat to the top of the screen to release the remaining adhesive. Opening is straightforward. Just beware of the ultra little slack of the short yet fragile flexible digitizer cable.
    Olivier Biot - 回复
    Thanks for the tip!
    Sean - Lua Tech -
  2. iPod Touch第4代电池更换: 步骤 2 中的图像 1,2 iPod Touch第4代电池更换: 步骤 2 中的图像 2,2
    • 当心,因为触摸将是非常热的。使用 时用毛巾拿着它可能会有帮助。
    • 将撬棒的边缘插入前玻璃面板和靠近home键的塑料挡板之间。
    • 不要试图在塑料表圈和钢制后盖之间撬动。
    • 向上撬前面板的底部边缘,注意不要过度弯曲玻璃面板。
    • 如果撬起前面板组件太困难,请重新加热并重试。
    There should be (in general) better notes about the reassembly process. Getting the thing glued back in is WAY harder than just "reverse this step." Getting it to sit flush with any kind of adhesion is pretty difficult. No real advice other than make sure the edges of the metal thing at the top of the back of the digitizer are in the right slots and use judiciously placed pieces of 3M 300LSE adhesive.
    jonathan - 回复
    I actually just figured it out. I had the ribbon cable for the digitizer running under the LCD and that wasn't allowing the LCD to sit down far enough. By re-folding the digitizer cable so it was triple-folded (when you do it you'll see what I mean) and only under the glass where there is no LCD, you'll get the glass to sit right.
    jonathan - 回复
    I'm havin' problems with mine... hum, the front panel broke and i don't know where can i buy a new one. Can you help me?! Detail, the Touch screen still working... the external screen is broken, but the internal is ok...
    Nathan Bergmann - 回复
    EBay mate sells plenty
    Greg W -
    Glue is under the black part of the glass, not under the clear part of the glass.
    The Glue is mostly around the top and bottom about 1/2 inch in or so, around both left and right edges the strip of glue is very thin about 1/8 inch or so.
    I had success with heat and sliding the tool or pick up and down the side where there is less glue until it started separating being careful that I was between front glass panel and the black plastic bezel.
    Evon Waters - 回复
    Take a look at the post What parts to move from the broken screen?
    That will give you some advice as to what to move over from the broken screen, metal bracket, home button and small sponge spacer on the tip of the digitizer connector. Also how important it is to use new adhesive. If after assembling the screen bulges on one side (top or bottom) take the time to dissasemble and check that everything is in place (flat) and like jonathan writes, the digitizer cable is folded.
    asle - 回复
  3. iPod Touch第4代电池更换: 步骤 3 中的图像 1,1
    • 当有足够的空间抓住前面板的底部边缘时,将其从Touch上抬起,沿其左右边缘剥离粘合剂。
    • 如果粘合剂太难分离,在继续步骤之前使用热风枪软化。
  4. iPod Touch第4代电池更换: 步骤 4 中的图像 1,2 iPod Touch第4代电池更换: 步骤 4 中的图像 2,2
    • 因为第四代Touch的构造,除非主板被移除,否则数字转换器电缆不能断开。 处理前面板部件时要特别小心,因为它是通过非常精致的数字转换器电缆连接到Touch的其余部分的。
    • 此外,显示数据电缆非常短,并连接到前面板组件顶部附近的主板。 如果在取下前面板组合件的顶部边缘时没有断开连接,请在将前面板组合件从Touch上取下之前,务必用工具将其断开。
    • 小心地将前面板组件的顶部分离粘合剂,将其固定在Touch上,注意连接两个组件的短数字转换器电缆。
    The LCD cable which attaches to the logic board, is, indeed, very short. When reassembling the iPod, you may only be able to leave a small crack between the glass and the body to allow for enough space to reattach this cable. A plastic opening tool works well, but be warned: it takes quite a bit of patience.
    reidbauer - 回复
    Indeed the LCD cable which attaches to the logic board is short and I spent a good 30 minutes trying to get it to seat. When I finally did I realized I broke the right side and that is why my display is not working now. When they say difficult, they mean difficult - I have experience with electronics and I recommend you first practice on an older unit if you can.
    kitlammers - 回复
    Most guides recommend simply cutting the digitizer cable once you have disconnected the data cable. This makes things much simpler for subsequent steps rather than having the front panel dangling there.
    bowlingb - 回复
    Before i do this repair, does my screen have to be all together. Because my iPod got cracked a while ago, so do i have to buy a new screen so i can put the jack in? Also what goes first in the process when doing both of those things ?
    Diondre Jordan - 回复
    Reconnecting the data cable is actually pretty easy. Just hold your screen at a 90 degree angle and put it on your underlying surface (and not on the back part of your ipod). Then just use the opening tool to reconnect the cable. The cable is long enough. If you connected it properly try pushing the home button on the back part (not the actual button). If done properly, your screen should light up. (if not try again to connect the cable) Then just fold the screen onto the back part without lifting it. The cable disconnects very easily.
    12cw47 - 回复
    Maybe if you could show an image pointing out the the digitizer and display cable. I missed the part that the display cable pops off, and didn't get to it until almost the end.
    jimjty - 回复
  5. iPod Touch第4代电池更换: 步骤 5 中的图像 1,1
    • 卸下以下八个十字#00号螺丝:
    • 一个3.5毫米十字螺丝
    • 两个3.0毫米十字螺丝
    • 一个2.3毫米十字螺丝
    • 一个2.4毫米十字螺丝
    • 三个2.0毫米十字螺丝
    The antenna cable will almost always stick to the digitzer and often the glass is broken there. You can use a knife to pick out broken glass around the edges elsewhere but use ONLY PLASTIC tool to separate the antenna cable from the old digitzer. This cable is very thin and a metal tool can easily cut the cable which you cannot then repair but must buy a replacement.
    asle - 回复
    If you are removing broken glass be sure to recover the steel plate glued to the top of glass as well as the home button at the bottom of the assembly.
    Mark - 回复
    This steel plate or bracket has been discussed many times here. My best experience is to NOT move it to a new screen. Without the bracket and using enough adhesive in fact brings the new screen closer to the chassis and a snugger fit. Read more here: What parts to move from the broken screen?
    asle -
    Notice, in the image the switch for the home button has a tiny sub-1mm dot in the center of it. When I reassembled the home button did not work. That tiny cylinder of material had been knocked off the switch. A rounded probe could still activate the switch, but the flat metal plate on the home button could not. Fortunately, I was working on a white cloth, and a careful search turned up the tiny cylinder. I was able to reattach it and repair the home button.
    ciradrak - 回复
    I would like to add that the tiny cylinder is 0.65mm in diameter and 0.20mm high. I was able to successfully reattach it using a thick cyanoacrylate. You must be careful not to foul the switch's membrane with too much glue. I would suggest using fine point tweezers and a metal probe to apply the tiny dot of glue. You need a steady hand for this.
    ciradrak -
  6. iPod Touch第4代电池更换: 步骤 6 中的图像 1,1
    • 使用撬棒的边缘从后置摄像头上撬起薄钢盖。
    • 请注意位于相机旁边挡板旁边的小弹簧(用黄色标注部分)。
    • 从iPod上取下钢盖。
    Be sure to get the tool down deep when removing the rear camera. If not, you can accidentally snag the mid-section of the camera and it will come apart -- and you'll end up buying a replacement.
    Country Computer Service - 回复
    I have snagged that part of the camera several times. Easy to fix with super-glue along the edges of the cover. Works great. Sometimes no matter how carefully you pry up it falls apart.
    asle -
    This metal plate fits under plastic near RHS edge, and other side drops between the camera and a circuit board - to refit, you may need to loosen a nearby screw to allow you to move the circuit board a little to let this metal plate clip onto the side of the camera.
    I had to press down hard with a plastic tool to get this metal plate to clip on.
    Don't forget to re-tighten it later (I forgot).
    phil colbourn - 回复
    A strip metallic cover, glued to display isn't mentioned in this guide.
    Note that most new front panels are going without this part and you would need to remount it.
    Daniel Filatov - 回复
    what exactly is the copper tape for that sits over the backplate that covers the rear camera? it gives me trouble every time.
    yhwhelrey0 - 回复
    The copper is important for heat dispensing. It has nothing to do with grounding or signal. In worst case if it is torn the Touch could get hotter but should work. If it is torn I usually just lift up one part and move it so it is in contact with the other copper part.
    asle -
    I just replaced the screen and rear cam on my 4th gen. The camera does not work??? Any ideas????????
    mark - 回复
    Maybe the rear camera connection got loose when you lifted up the logic board in top to replace the digitizer. I would open it again and check the connection to the rear camera. Hope you fix it!
    asle -
  7. iPod Touch第4代电池更换: 步骤 7 中的图像 1,2 iPod Touch第4代电池更换: 步骤 7 中的图像 2,2
    • 将iPod开口工具的边缘插入触摸屏左下角附近的钢板下。
    • 将用粘合剂板固定在塑料内壳上向赏撬动。
    • 如果钢板仍连接在主板上,请重新加热该区域以松开粘合剂,然后使用打开工具将它从主板上分离。
    • 使用时要非常小心,扬声器在照片中标注的区域之下。 它与非常细和短的电线连接。
    • 这里有一条非常细的带状电缆,将音量和电源按钮连接到逻辑板。 尝试像这样在这个区域操作,以免破坏电缆。 抬起平板时一定要抓住这根电缆。 由于有胶水残留,可能会粘在盘子上。 这是非常脆弱的。
    • 如果不小心的话这根线就很容易断裂。
    • 红色标注区域下面也有粘合剂。
    I couldn't get a spudger in-between this space, so I went to the side where the three screws were on the left hand side and worked my way towards the bottom to separate the glue...
    Kevin Hulett - 回复
    The power and volume wire on the logic board were covered with adhesive. Be careful! While trying to remove the steel mid plane I found that the adhesive will rip the ribbon!
    Chris Boenitz - 回复
    Here is where you take it easy. Two things can be broken here.
    -Use time to carefully separate the bottom left part of the midplane. It sticks to the speaker which you tear the speaker leads if you are to hasty to lift it up. And remember the mid plane must not be bended up here since it needs to be 100% aligned so the new digitizer does not bulge here when in place.
    - The second picture. The black visible adhesive sticks to the volume cable. Use time to carefully separate the mid plane here so the cable is not ripped when you lift up the midplane. Pry a plastic tool like the picture or/and a spudger slowly in until you see/feel the midplane loosening. A broken volume cable is no fun.
    asle - 回复
    as stated before, be very careful with the part at the speaker.
    the speaker actually sticks to the mid plane and i accidentally lifted it with the plane and separated one cable from the board!
    stan - 回复
    That small ribbon cable ripped, be sure to really watch this - look at the second picture in this step and try to make sure you understand where it is on the board under it.
    kitlammers - 回复
    This was difficult during both disassembly and reassembly. I used a thin guitar pick to separate the ribbon cable by the volume buttons from the steel midplane. Reassembly was tough because I didn't have the ipod dock connector seated correctly, AND more importantly, the speaker has a part that needs to be inserted into a black part on TOP of the dock connector-- it looks almost like a tiny air duct that has a foam gasket around it.
    Nik - 回复
    I was able to replace the home button ribbon cable without having to fully remove the steel mid plane. It lifted up enough from the iPod's body that I was able to slip the ribbon in around the support it sticks to and hold it in place until the adhesive set.
    Much simpler, and didn't cause any problems -- the mid plane didn't deform, and snapped right back into place.
    Thanks for the guide.
    jon - 回复
    Unfortunately there was so much glue on the tiny power/volume button ribbon cable that any attempt at removing the steel cover plate would eventually rip that cable at the 4 solder joints. A picture of that cable would help tearing down more securely.
    Is there a way to repair the torn ribbon cable or should I consider my iPod as dead now?
    Olivier Biot - 回复
  8. iPod Touch第4代电池更换: 步骤 8 中的图像 1,2 iPod Touch第4代电池更换: 步骤 8 中的图像 2,2
    • 稍微倾斜钢板,将它从后壳中取出。
    • 注意不要撕开将后置摄像头连接到钢板中间平面的连接带。
    • 将钢板从后壳提起,然后剥下粘在后置相机上的连接带。
    I was able to stop at step 8 for the battery replacement.
    Once you remove the metal shield, desolder the 3 leads. Then use your heat gun to warm the battery. Use plastic pry tool between copper backing and battery and separate them (two adhesive strips on the sides of the battery). Once done with this, you can snake the battery ribbon cable from between the logic board and aluminum casing. Not as easily, but still very doable, snake the new battery ribbon back through the same slot; solder 3 points and reassemble. Much easier than removing the entire board. Good luck!
    Oh also, not mentioned in this guide - there is a plastic/silicon substance covering the 3 leads. Prior to desoldering remove this as much as possible with metal or plastic spudger (if metal, be sure not to bridge the connections).
    Syl2us - 回复
    I stopped dismantling here as well and was able to replace the battery and everything works on the ipod. tricky parts for me were the copper adhesive on the rear camera and getting the data display cable reconnected
    I used plenty of heat first heating the ipod in an industrial oven to about 150 F and then as needed heating a heat gun.
    dhawke -
    what do you do if you break the copper connector to the camera?
    justinallison1 - 回复
    The copper tape is mainly for heat dispersion. Without the copper tape it should work anyway but I would just lift up and move one part of the tape so that it is in contact with the other part when you put it together.
    asle -
    justinallison1, From what I understand, it is ok if that copper tape rips. In fact, I have seen people remove it completely. If it rips, just try and have the 2 pieces touching. (This is what I have researched and done myself with no negative results.
    Katie Kousoulos - 回复
    after removed the steel mid plate, does anybody measure the battery voltage? I measured the battery voltage is only 0.3V. is it normal? I de-soldered the battery three points and measured the battery voltage 3.8V. So It looks like battery is OK. The logic board has problem. So I connected external power source 3.7V and maximum current 50mA to the battery B+ and B-. I found the power source dropped to only 1.65V and 50mA. Could I say logic board has problem?
    William - 回复
    i break the copper connector to the camera then i do, does home button work?
    Arsh - 回复
    The copper tape is really not a connector. It is a heat shield that spreads heat. Just try to attach it so it overlaps. It does not affect any connection.
    asle - 回复
  9. iPod Touch第4代电池更换, 耳机孔: 步骤 9 中的图像 1,1
    • 使用撬棒将耳机插孔连接器向上撬出主板上的插槽。
    I was able to ply the battery out slowly, without removing the logic board because the battery was so swollen. Just started by prying it out using the side of the case, not the logic board, and it peeled out slowly. As mentioned further down in the instructions, the copper flashing had to be pushed back into shape. The battery unsoldered easily, lifting as described. Just slip the flexible conductor from the battery out from under the logic board.
    It powers up without a battery if you need to get data off the iPod.
    Tom Thompson - 回复
  10. iPod Touch第4代电池更换: 步骤 10 中的图像 1,1
    • 卸下将耳机插组件固定到后壳的单个2.6毫米十字螺丝。
    • 螺丝呈90度角。 确保以这样的角度摘除它。
    Be sure to note the way the ribbon cable bends between the connector and the rest of the jack assembly. Bending your new one in the same manner while hooking up the connector should make it a lot easier make the connection.
    matthew r - 回复
    That "90 degrees screw" doesn't come out! What I have to do? Die Kacke ist am dampfen!
    0815Hater - 回复
    It came out! Thank you for nothing! Die Kacke ehat aufgehört zu dampfen! Sorry for my english!
    0815Hater - 回复
  11. iPod Touch第4代电池更换: 步骤 11 中的图像 1,2 iPod Touch第4代电池更换: 步骤 11 中的图像 2,2
    • 使用 iPod 撬棒轻轻将最靠近电池的耳机插组件边缘从凹槽中抬起。
    • 从后壳内取下耳机孔。
    This was the hardest Part
    Charlie Baldwin - 回复
  12. iPod Touch第4代电池更换, 上主板: 步骤 12 中的图像 1,1
    • 拆下主板板顶边附近的三个螺丝:
    • 一个2.0毫米十字螺丝
    • 两个2.3毫米十字螺丝
    Can you use the same colour coding as with The above sizes? [HvL]
    Hugo van Leeuwen - 回复
    These colors are too close together.. One red, two yellow.. Please.
    playpets106 - 回复
    Thanks for the comment! I adjusted that step, should be much easier to see now.
    If you're ever having trouble seeing screw markers or other small details on a step, you can always view a larger version of the image with the "View Huge" link on the top left corner of the image.
    Andrew Optimus Goldheart -
    Can someone explain what the copper/ribbon is that the lower yellow marked screw goes through is for? Perhaps only heat dissipation? The ipod I have was given to me with much of the glass smashed and picked out, so some of this is just missing. Obviously I can't put it back...
    hutchwilco - 回复
  13. iPod Touch第4代电池更换: 步骤 13 中的图像 1,1
    • 使用撬棒的边缘轻轻地撬动后置摄像头,但不要将其从后壳上取下。
    • 请勿尝试移除后置摄像头。
    When you insert your tool to remove the rear camera make sure you have the tip all the way in. You can accidentally grab the middle of the camera assembly and it will come apart - and you'll have to replace the entire camera.
    hi! i accidentally cut the copper adhesive on rear camera, and now it doesn't work: i start the app "camera" and it opens but still close the lens... can i fix it ? if yes, how? thanks
    simone usala - 回复
  14. iPod Touch第4代电池更换: 步骤 14 中的图像 1,2 iPod Touch第4代电池更换: 步骤 14 中的图像 2,2
    • 使用撬棒轻轻抬起电池旁边的主板边缘,以便用另一只手抓住电池。
    • 不要过力弯曲主板,因为它非常薄且脆弱。
    • 音量控制键带状电缆仍然连接时,请小心不要抬起太多,否则很容易撕裂。
    • 在用一只手轻轻提起主板的同时,使用撬棒在主板板的顶部边缘提上位于连接带附近的主板。
    • 当最后一个显示屏组件连接器从后壳顶部边缘摘除时,主板可以提起。
    Use extreme caution when lifting the board. There are 2 ribbon cables that are extremely fragile, 1 connecting the rear facing camera and another connects the volume controller flex on the logic board.
    Evon Waters - 回复
    Adding to Evon's comment:
    BEFORE YOU LIFT UP THAT BOARD...
    Use your plastic pry tool and make sure the flex cable, between the board and power button is not on top of the board. Take your time because even the slightest snag can tear that flex cable which leads to de-soldering/soldering the battery & flex cable.
    Once the board is lifted the first time I usually put a piece of Kapton tape over that area of the cable in case it has to be pulled up again.
    Can you explain this in a little more detail?
    I have done a dozen or more iPod screens without any issue. I have one here now that does nothing. Just a black screen. It won't even take a charge.
    Should I simply desolder those pads and then resolder? Sort of like unplugging and replugging to reset something?
    Thanks!
    Rene
    Rene Jeddore -
    Ciao dopo aver seguito il tuo aiuto per come cambiare la batteria io ho rimontato tutto ma la barra di sblocco non scorre più o i comandi in quella altezza del touch , tutto il resto funziona perfettamente.Dove potrei aver sbagliato?
    Potete aiutarmi grazie
    salvatore sagone - 回复
    I placed a penny between the battery and board and it held it in place at just the right height.
    gcroley - 回复
    I was so so so so careful when lifting the logic board past the flex cable on the power button. Before final assembly, plugged it all in to test and it booted OK. LCD and Digitizer worked. Went to power it off and found the power button wouldn't work. Sure enough, the tiny (<0.5mm) strip of copper in that power flex cable had torn right through. About to pitch this rotten, stinking thing across the back yard into the trees. I've spent 5 hours of my life fixing this today! Aaargh!!!!!
    Squonky - 回复
    On this step i broke the entire board, so it now is a Apple Galaxy Fold, also the battery exploded .-.
    Ferx 7 - 回复
  15. iPod Touch第4代电池更换, 逻辑板组件: 步骤 15 中的图像 1,3 iPod Touch第4代电池更换, 逻辑板组件: 步骤 15 中的图像 2,3 iPod Touch第4代电池更换, 逻辑板组件: 步骤 15 中的图像 3,3
    • 使用塑料打开工具小心地将iPod的扬声器从外壳的凹槽处翘出。
    • 切勿完全移走扬声器,它们的底部仍然与逻辑板相焊接。
    • 让扬声器放在电池上方,以便接下来继续安装电池。
  16. iPod Touch第4代电池更换: 步骤 16 中的图像 1,3 iPod Touch第4代电池更换: 步骤 16 中的图像 2,3 iPod Touch第4代电池更换: 步骤 16 中的图像 3,3
    • 在接下来的几个步骤中,您将松开电池下面的粘合剂,逻辑板和电池下面的框架。 慢慢地,小心地,均匀地做。 注意不要刺破电池或弯曲逻辑板。
    • 使用塑料开口工具撬起电池三个暴露边缘的粘合剂。
    • 不要试图撬开电池,只要开始松开胶粘剂。
  17. iPod Touch第4代电池更换: 步骤 17 中的图像 1,2 iPod Touch第4代电池更换: 步骤 17 中的图像 2,2
    • 电池边缘松动后,开始撬起逻辑板的边缘。 从顶部开始,沿着电路板的方向前进。
    • 为了防止弯曲/折断逻辑板,请勿尝试移除逻辑板。 底座连接器仍然嵌入在框架中。 再次,你只是试图松动更多的粘合剂。
  18. iPod Touch第4代电池更换: 步骤 18 中的图像 1,2 iPod Touch第4代电池更换: 步骤 18 中的图像 2,2
    • 使用塑料开口工具时,小心地将底座连接器从外壳凹槽中推出。 平均地在每个角落操作,直到连接器松动。
    • 由于底座连接器连接在逻辑板上,因此将其推出外壳可能会导致逻辑板开始弯曲。 要格外小心,不要弯曲板子。
    This was the hardest step for me. I ended up snapping the mother board at the corner because the adhesive just suddenly released. I wish there were a few more pictures and pointers on how to remove the charging port. Does anyone know a good place to get a cheap 32 GB mother board??
    Damon - 回复
    Existe cola embaixo do conector, por isso, a dificuldade em retirá-lo. Eu aconselho, um pequeno aquecimento com a pistola de calor, na parte traseira da carcaça, antes de tentar a remoção do conector.
    mpcellmendes - 回复
    For Step 17, just slip a length of waxed dental floss under the top left and right corners of the battery, slowly slide down the back of the battery with a sawing motion. All the adhesive will be seperated w/out any risk of bending the board or puncturing the battery. Charging port will now be easily removed.
    carol - 回复
    Well Done! Nice to see extra ideas for Steps as it can make the process much better. Thank u!
    Vicki - 回复
  19. iPod Touch第4代电池更换: 步骤 19 中的图像 1,3 iPod Touch第4代电池更换: 步骤 19 中的图像 2,3 iPod Touch第4代电池更换: 步骤 19 中的图像 3,3
    • 一旦所有粘合剂从逻辑板/电池组件下面被释放,从侧面提起并小心地旋转以接近电池的下侧。
    • 逻辑板仍然连接到后壳。 不要试图完全分离组件,否则你会撕裂这条带状电缆。
    At this step there should be indicated much clearer in BOLD YELLOW RED what ever to turn the logic board instead of removing, since it VERY easily will break the ribbon.
    Fboecom - 回复
  20. iPod Touch第4代电池更换, 电池: 步骤 20 中的图像 1,2 iPod Touch第4代电池更换, 电池: 步骤 20 中的图像 2,2
    • 用一只手捏住位于电池底部的铜制屏蔽罩,同时用另一只手牢牢捏住电池。
    • 小心地将铜屏蔽罩从电池上剥下来。
    • 不要迅速剥离铜护罩。 否则可能会对电池造成不可挽回的损坏。
    • 安装新电池时,铜屏蔽层必须尽可能平坦。 否则电池和LCD相结合时会增加厚度
  21. iPod Touch第4代电池更换: 步骤 21 中的图像 1,3 iPod Touch第4代电池更换: 步骤 21 中的图像 2,3 iPod Touch第4代电池更换: 步骤 21 中的图像 3,3
    • 如果有必要,使用塑料棒将位于电池底部附近的黄色kapton胶带剥下。
  22. iPod Touch第4代电池更换: 步骤 22 中的图像 1,3 iPod Touch第4代电池更换: 步骤 22 中的图像 2,3 iPod Touch第4代电池更换: 步骤 22 中的图像 3,3
    • 此时,电池只能通过一根电缆连接到电路板。
    • 向上旋转电池,远离电路板。
    • 翻转装置以看清楚电池焊点。
  23. iPod Touch第4代电池更换: 步骤 23 中的图像 1,1
    • 在接下来的几个步骤中,您将拆除电路板上的三个电池焊点。
    • 在拆焊3根引线之前,可能会有一些硅胶覆盖它们。 使用塑料或金属spudger撬棒(如果是金属,要非常小心不要桥段连接)尽可能多的去除焊点。
  24. iPod Touch第4代电池更换: 步骤 24 中的图像 1,3 iPod Touch第4代电池更换: 步骤 24 中的图像 2,3 iPod Touch第4代电池更换: 步骤 24 中的图像 3,3
    • 第四代Touch上的电池通过带有穿过电池带缆的小孔的焊盘连接,并连接到电路板正面的平垫上。 在此步骤中,您将使用金属撬棒单独加热每个焊盘,从电路板上撬起它。
    • 不要用电缆将电路板上和带状电缆上的焊盘连接起来。 短路有可能烧坏电路板。
    • 谨防电路板和电缆过热。 只要把铁的尖端对着焊盘保持足够长的时间,以使焊料融化。 过多的热量积聚有可能破坏电路板或熔化带状电缆。
    • 从电池带状电缆的外部开始操作。 加热最外面的焊盘,同时轻轻地从带状电缆下面撬起,从板上释放。 然后剩下的两个垫子重复这个过程,从外面操作。
    Make sure to use plenty of flux to avoid lifting pads
    Craig - 回复
    READ ALL THE STEPS BEFORE YOU BEGIN
    1. Do NOT use a metal spudger for this.
    2. Cover surrounding components with Kapton tape.
    3. Optional (if you found this tutorial and are replacing the volume/power flex cable and your battery is good) Cover two of the three leads with Kapton tape to avoid shorting a good battery.
    6. Set your temperature on your soldering iron with a flat chisel tip.
    7. Apply a little flux to a copper soldering braid.
    8. Place the copper braid on the contact that you want to de-solder - you may need to lightly hold it steady with your thumb in place.
    9. From the bottom of the cable very gently push up with your index finger.
    10. With your other hand, the one with your iron, gently press down to melt the solder, as soon as the solder melts use your index finger to gently push the cable up so as to disconnect the cable from the solder pad. Wait about 15 seconds for the solder to cool.
    11. Insert a piece of kapton tape between the cable and solder pad.
    12. Repeat steps 7-12 for the remaining two contacts.
    FLUX WARNING:
    If using flux, be sure to use 94%+ alcohol (once the battery is disconnected completely) to clean off any remaining flux. Don't try cleaning flux off until the battery is removed to avoid pushing debris between contacts and onto other components that will cause a short.
    Rule of thumb, if power is flowing through a logic board don't apply alcohol or try to clean it. Always remove the power source then thoroughly clean. Pushing around small metal particles in alcohol while a device is "hot" is the fastest way to cause a short or electrical arching.
    Bonjour, j'Ai un gros problème, en enlevant la nappe, chaque connecteur a un morceau de nappe qui ne veux pas s'enlever, j'ai beau chauffé le métal mais je ne suis pas capable de les enlever, si quelqu'un pourrai m'aidé s.v.p.
    Merci !
    jonono2 - 回复
    I followed what another user had suggested and didn't remove the logic board - it worked well and I managed to do it easily enough. However, when trying to remove the solder and cable from the battery terminals (it was really tricky) I think I may have pulled the pad off. I put my iPod back together anyway but now it won't boot, show up in iTunes when it's plugged in or (in fact) do anything. Could the possible loss of the middle terminal be the root of these problems?
    Dan - 回复
    In this step DON’T USE A METAL SPUDGER!!! Use the plastic/nylon one from ifixit. Then there will be no chance of bridging the contacts on either the battery or the logic board.
    Lawrence - 回复
  25. iPod Touch第4代电池更换: 步骤 25 中的图像 1,2 iPod Touch第4代电池更换: 步骤 25 中的图像 2,2
    • 在这一点上,电池应该从电路板上拿下来。
    • 从电路板上取下旧电池,放在一边。
  26. iPod Touch第4代电池更换: 步骤 26 中的图像 1,2 iPod Touch第4代电池更换: 步骤 26 中的图像 2,2
    • 接下来,使用烙铁头来压平逻辑板焊盘上的焊料。 照片分别为“之前”和“之后”的镜头。
    • 切记不要过多地加热垫子。
    Hello, I have pulled the middle pad off my iPod 4th Generation how can i repair this?
    Karl - 回复
    I did the same thing and accidentally pulled the middle battery pad from the logic board. I know that I am supposed to gently remove the 'laquer' or 'shellac' covering around the area of the pad in order to expose the copper circuit underneath. I am just not sure which circuit I should be working with. A good closeup of the area to work on would be greatly apreciated.
    ALF -
    Best plan is to take it to Apple store.
    delriesenhuber - 回复
  27. iPod Touch第4代电池更换: 步骤 27 中的图像 1,3 iPod Touch第4代电池更换: 步骤 27 中的图像 2,3 iPod Touch第4代电池更换: 步骤 27 中的图像 3,3
    • 将新电池放置到位,并将远触点与外部焊盘对齐。 使用一小块电工胶带将电缆固定在焊盘上。
    • 颠倒安装电池(电缆朝上)会损坏电路板。
    • 将胶带条放在电池带电缆的末端以覆盖两个焊盘,并将触点向下压在电路板上。
    • 加热最右边的触点,直到下面的焊料熔化,然后在触点上涂上少量的焊料,让它流过电缆上的两个孔,然后流到电路板。
    • 不要使用太多的焊料。所需的合适的数量只是微乎其微的。
    • 一旦钎料流入接头,要同时去除焊料和铁。
  28. iPod Touch第4代电池更换: 步骤 28 中的图像 1,1
    • 移动胶带,使其不再覆盖剩余的两根导线。 如果您对电缆相对于电路板上电极的位置感到满意,请继续。 如果没有,请先拆下第一个连接,然后重试。
    • 将剩下的两个焊盘焊接到电路板上,注意电缆或电路板过热。
    Thanks for your trouble of detailing the battery replacement. Frankly, I would rather buy another Ipod rather than go through the process and likely screw it up half way through. Of course, that is exactly what Apple has in mind for the consumer.
    pwkoughan - 回复
    Apple hold their customers in low regard. “Value for money” is beyond their imagination, no more than vulgar expression!
    John Ledwidge - 回复
结论
要重新组装您的设备,请按照相反的顺序完成这些步骤。
208等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Jake Devincenzi
于04/18/11注册
117,260 声望
创作了57篇指南
43条评论
Where do i get the best quality battery?
Dave - 回复
Did it! Now screen is a bit funky when I press on the sides of the iPod. Although all seems good :)
Thanks iFixit!
Philipp Boulanov - 回复
I had a similar problem when pressing on the center button. Turns out it was too much solder on the battery connector. I had to disassemble again and used some solder wick to lower the solder blobs. I suspect that the back plate must not be completely flat for you.
Joshua Belcher -
I followed this guide to the letter but the new battery only has half a charge and will not take a charge when plugged in. Any thoughts?
Bill Lee - 回复
To clarify, does the battery show as charging when plugged in? If so, will it go from no/low charge back up to half charge? If this is the case, I would contact whoever sold you the battery and ask for a replacement.
Joshua Belcher -
For those using rework stations, what temperatures are recommended for the iron & hot air blower?
Daniel Lott - 回复
The following temperatures worked well for me:
150ºC hot air for softening adhesives.
290ºC for removing old solder.
Make sure to add liquid flux before removing all traces of old solder, & clean all surfaces.
Apply new flux to both sides of Kapton cables as well as the board. Set your iron temperature acording to the recommended setting for your ROHS electronics solder.
*DO NOT USE NON ROHS or lead bearing solder*
*DO NOT USE plumbing or acid core solder as this will destroy your electronics*
Daniel Lott -
To anybody who gets a white screen when trying to power on the device, all that is needed is a forced restart, just hold the home and power buttons until you get the apple logo
Hugh Powell - 回复
Invaluable. especially re screw lengths-though how you tell a 2.3mm screw from a 2.4mm screw is a bit of a poser. Unsoldering the battery before folding the logic board out of the way worked for me. Unsoldering the old battery connections was difficult, though, as the battery fitted had the connections apparently covered in plastic. Didn't find any problems using leaded solder - certainly in UK it is allowed for repair work.
Steve - 回复
Just to say, Thank you! :)
Marc - 回复
I was a complete and total newbie. I replaced the battery and the screen with this tutorial. I accidentally missed a screw and I think that is why my volume down button didn't make it out alive but that was my only casualty. As I have never soldered before I watched a youtube video on soldering tips first and that helped my confidence. Overall it was very stressful but I have kids too which added to that, but it was a success! Thanks for this very detailed awesome guide!
Aimee Gordon - 回复
Although these are very nice, detailed instructions, I ruined my Ipod on Step 19. If you do not lift the assembly carefully at this step, the FPC cable attached between the logic board and the case will tear VERY EASILY!
Carlos - 回复
I just did this with (relative) ease, but I turned it back on yesterday and have had it plugged in the whole time, and it WILL NOT charge! It being my first ipod repair there were a number of casualties, but nothing I considered to be life or death...
1) internal speaker wire got sliced somehow, not even sure how...
2) ribbon cable to volume control completely separated (again, not even sure how)
How does the battery even get power? It's just soldered to the logic board....does electricity just go through the soldering/ribbon cable into/out of the battery?
Chris - 回复
Hello, first of all, congratulations on the great guide!
I`d like to give a hint. You don`t NEED to go through all the steps to change the battery. You can skip STEPS 16 to 23. You don`t need to actually remove the logic board to change the battery. Just desolder the connections and pass the riboon below the board. That`ll save some time.
Another hint is BE CAREFUL with the heat gun. I used it too much and I think that I`ve damaged something. But it was my fault =[
Great guide, thanks!!
Luiz R - 回复
after i have change a battery a have lost touch on the corner of the screen, tyhere is a way to fixc that or i have to change the sreen and lcd.
piergagne1 - 回复
ALF - 回复
I skipped steps 6 and 9-23 and it worked perfect. Pulled the battery out without removing the logic board after snipping the bad battery flex cable fed the new battery flex carefully between the logic board. Beware... tons of adhesive between battery and copper tape below
trevor - 回复
I broke unfortunately my iPod touch when I tried to replace the battery. I didn't have the specific tools to open it so I damaged it when opening it. I bought Samsung phone next week to replace my iPod, it's easy to change battery to it.. no more integrated batteries!
mikkoharkonen2 - 回复
My battery is to small. It didn't work and my iPod won't work for ever. All in all it was more difficult than I thought. DIE KACKE IST SO RICHTIG AM DAMPFEN!!!!
0815Hater - 回复
ok so i dont know if i need to replace my battery or what to do?!?! because my ipod is getting really slow and crashes alot! and i need to charge my ipod 4 alot!
isaiah75 - 回复
Completed battery replacement over two days. Everything is working. The carefully worded procedure, although sufficient, is not for the faint of heart! Patience is paramount. Adhesive, 'foam rubber' seals, silicone over battery pads, and odd-shaped speaker and other components provided added challenge for me. I made good use of additional items: 7X fine tip tweezers, Exacto knife, plastic dental pick, additional tiny screwdriver, solder wick, Kapton tape to provide extra layer of insulation over new battery pads, and OptiVisor to accommodate my 66 yr old eyesight. Without these instructions, the battery replacement would have been near impossible. Thanks.
Alan Hutchenreuther - 回复
I replace the battery and it worked but a few days later it stopped working, open it up and I messed up the FTC connector, now need to replace FTC connector and the flex cable, help please how to do it?
DSANTIAGOSOY - 回复
Thank you for the guide!
My ipod ran through the washing machine and the dryer, the battery appeared to be unable to charge. So I changed it with the guide.
I was able to change the battery at the step 17, I skipped the step 13 and 15, and I could have skipped 9 to 11 with the headphone jack.
It was not easy to pry the different parts and to seat back the LCD cable at the end, be patient!
Ludovic Fontaine - 回复
Well I amimpressed even a begginers hands and a good mind can build and repair there own once you have the tools and in some cases the right tools are the right wrong tools improvise and thismi pod pid pods pide pode poa pia ND THANK YOU ON MY NEW JOB I NOW REPAIR AND IX ALL KINDS OF EQUIPMENT
is the best tutorial on subjects on these
jspataro420 - 回复
Wow, that was hard. However the ipod survived and is fully functional. Thanks for the guide!
jimjty - 回复
Yes I accomplished this but it was difficult. Really wish Apple was a bit nicer about designing these things. I found that using a heating pad worked really well a loosening up the adhesive. I felt it was a bit safer than the heat gun approach less likely to have overheating issues.
Brian Lenz - 回复
I follow the guide to replace battery and it work. Had some what of a time removing the battery because the adhesive was adhering strongly, but finally it separated from the housing. Desoldering and resoldering and the reassembling went well.
So now I have my ipod back . Thanks for the wonderful guide.
Maggie - 回复
Hi ,
My ipod touch wasn't working and when I charge my ipod touch it wasn't working for a long time. can you please help me, Thanks
Angela - 回复
This did not help.
Maddie c - 回复
This did not help. Maybe I need to throw my iPod out.
Maddie c - 回复
Hello, I have a 4 gen iPod touch 32 GB, I need to repair BUT I dropped three screws in the vent by my desk and can NOT find them. FAT Fingers VERY SMALL screws. Where can you find these ? They are
One 2.3 mm Phillips screw
One 2.4 mm Phillips screw
One 2.0 mm Phillips screw
Thank you for your valuable time and Info. Have A Blessed Day. Regards'
jeanyondervich - 回复
Hello, I have a 4 gen iPod touch 32 gb, I need to repair BUT I dropped three screws in the vent by my desk and can NOT find them. FAT Finger's Very SMALL Screws!!!!!!! Very Old House! They are
Where can I find these? Do these come in a pack? Thank you for your valuable time. Have A Blessed Day. Regards'
jeanyondervich - 回复
I ended up breaking the board at 18... I think this step could be skipped... I think one could unsolder the ports after 17. Remove the battery, install, the battery en resolder after that point... Thanks anyways...
Charles Brillon - 回复
Hi, I have replaced the battery, at first, the spare shiiii...ty battery was weird and only charged to 50% then it never charged until it ran out of any charge.
then after detaching the shiiii...ty battery, in the middle of the process I accidentally broke the "volume" and "touch screen" flat cable, and lost all the mini screws.
fortunately, the main board was intact and i connected it to a very ordinary 3.7 V-4000 mAh lipo battery and it work perfect!! (naturally it does not fit in the casing anymore!)
sometime i detach the LCD panel and I use it only as a very powerful and compact music player!
My advice ~ {{{{{{{{{ Don't waste your money on the "Original" shiiii...ty spare batteries, you can buy an ion-battery as cheap as a few bucks in any capacity }}}}}}}}}}}}}
farhad sedri - 回复
Nerve wracking but successful, thanks to your step by step picture perfect explanation.
valman - 回复
Thanks! I replaced the battery successfully- Great instructions-
However- Can anyone tell me how I killed Wifi?
Lol-
david brien - 回复
Who ever thought integrated batteries were a good idea should be punched.
Wes InIowa - 回复
Good, it is called very complicate !!! Apple does all to make it nearly impossible to change the battery. But I did it !!! I am happy. It took me about 6 hours an d at the end I missed the instruction how to glue all together again.? I fortunately bought the set for it together with the battery. But cleaning all from the old glue took half of the time. Thank you for the good step by step instruction.
Dieter Rozowski - 回复
I’m new to the fixing products industry and i was just wondering as to why you have to take all the logic board and headphone jack out etc because i thought that all you had to do was to open up the device and use the pull tabs to release the battery, or is this just on the more recent devices.
Harry Sparkes - 回复
Hello, I replaced the battery of my 4th generation iPod touch with that of another exactly identical iPod. Since then, the screen always shows the red battery icon with the lightning bolt symbol. What should I do?
Shawn Poulin - 回复
Crikey. I’ve been given an old iPod such as this one, which is not holding a charge. Having read this, I’m not sure I want to try replacing the battery myself - especially since I don’t know how to solder and don’t own a heat gun!
paul - 回复
You can skip steps 18-23 by desoldering the 3 battery connections and unsticking the old battery from the copper film that is stuck to the backplate with an opening tool at step 17. The battery will curl but this isn’t a problem so long as you don’t bend it too far. Slide the old battery out from under the logic board. Use the opening tool to smooth down the copper film if it has lifted by pressing down firmly and pushing the blade from centre to outer edge. Slide the new battery beneath the logic board and wrap the ribbon over the top. Solder up and reassemble.
John Chisholm - 回复
Hi is there a need for a new adhesive? The guide does not talk about the step when the parts are finally put back together. Or is using the heat gun again with the old adhesive sufficient? Will the device resist rain and humidity once reassembled?
Dierk - 回复
添加评论
浏览统计数据:
过去 24 小时: 27
过去 7 天: 178
过去 30 天: 881
总计 490,301
