跳转到主内容
iPod Shuffle 4th Generation Rear Panel Replacement
你所需要的
  1. iPod Shuffle 4th Generation Rear Panel Replacement, Rear Panel: 步骤 1 中的图像 1,1
    • Accessing the internals of the 4th generation Shuffle is extremely difficult, as the rear panel is both glued to the front case and secured by metal retaining clips. It is highly unlikely that you will be able to remove the rear panel without inflicting cosmetic and/or structural damage.
    • Before proceeding, be sure your Shuffle is switched off.
  2. iPod Shuffle 4th Generation Rear Panel Replacement: 步骤 2 中的图像 1,2 iPod Shuffle 4th Generation Rear Panel Replacement: 步骤 2 中的图像 2,2
    • Use a combination of iPod opening tools and metal spudgers to pry the rear panel away from the Shuffle by the seam nearest the ON/OFF switch.
  3. iPod Shuffle 4th Generation Rear Panel Replacement: 步骤 3 中的图像 1,1
    • Remove the rear panel from the Shuffle.
结论
5等其他人完成本指南。
2指南评论
what glue to fix it?
pedro_bizarro - 回复
I recommend 2mm TESA tape
Ben Capehart -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 35
总计 10,094
