当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
Be careful when using a metal spudger, as you may scratch the outer case.
Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
Pry the rear case away from the front case.
Lift the bottom of the rear case and remove it from the rest of the iPod.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与3其他贡献者
于01/05/10注册
39,524 声望
创作了67篇指南
徽章: 47
+ 44更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 31
总计 8,110
