跳转到主内容
Fix Your Stuff
Right to Repair
Parts & Tools
简介
Replace the rear case on your iPod shuffle for a shiny new clip.
配件
没有特定配件。
  1. Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case. Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. Lift the bottom of the rear case and remove it from the rest of the iPod.
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
结论
另外一个人完成了本指南。
Matthew Newsom
于2010年01月05日注册
34,026 信誉积分
创作了67篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 5
过去的30天: 17
总计 6,687
