跳转到主内容
iPod Shuffle 3rd Generation Logic Board Replacement
你所需要的
  1. iPod Shuffle 3rd Generation Logic Board Replacement, Rear Case: 步骤 1 中的图像 1,1
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. iPod Shuffle 3rd Generation Logic Board Replacement: 步骤 2 中的图像 1,2 iPod Shuffle 3rd Generation Logic Board Replacement: 步骤 2 中的图像 2,2
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. iPod Shuffle 3rd Generation Logic Board Replacement: 步骤 3 中的图像 1,1
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. iPod Shuffle 3rd Generation Logic Board Replacement: 步骤 4 中的图像 1,1
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
  5. iPod Shuffle 3rd Generation Logic Board Replacement, Logic Board: 步骤 5 中的图像 1,1
    • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
  6. iPod Shuffle 3rd Generation Logic Board Replacement: 步骤 6 中的图像 1,1
    • Remove the single Phillips screw securing the logic board to the front case.
  7. iPod Shuffle 3rd Generation Logic Board Replacement: 步骤 7 中的图像 1,1
    • Peel the battery up from the front case with an iPod opening tool.
    • Remove the logic board and battery from the iPod.
结论
2等其他人完成本指南。
Matthew Newsom
于01/05/10注册
41,972 声望
创作了67篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 11
总计 6,683
