跳转到主内容
iPod Shuffle 2nd Generation Logic Board Assembly Replacement
你所需要的
  1. iPod Shuffle 2nd Generation Logic Board Assembly Replacement, Logic Board Assembly: 步骤 1 中的图像 1,1
    • Before beginning, be sure your Shuffle is turned off as shown.
  2. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 2 中的图像 1,2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 2 中的图像 2,2
    • Use the edge of an iPod opening tool to pry the plastic cover off the headphone jack side of the Shuffle.
    • Remove the plastic cover and set it aside.
  3. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 3 中的图像 1,1
    • Remove the two Phillips screws from the headphone jack side of the Shuffle.
  4. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 4 中的图像 1,2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 4 中的图像 2,2
    • Use the edge of an iPod opening tool to remove the steel cover from the headphone jack side of the Shuffle.
  5. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 5 中的图像 1,2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 5 中的图像 2,2
    • Use the edge of an iPod opening tool to pry the plastic cover off the controls side of the Shuffle.
  6. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 6 中的图像 1,2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the hold and shuffle sliders from the Shuffle.
  7. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 7 中的图像 1,1
    • Remove the two Phillips screws on the controls side of the Shuffle.
  8. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 8 中的图像 1,2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 8 中的图像 2,2
    • Use the edge of an iPod opening tool to remove the steel plate from the controls side of the Shuffle.
  9. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 9 中的图像 1,1
    • Use the edge of an iPod opening tool to slightly pry the steel plate on the headphone jack side of the Shuffle away from the lip cut into the outer case.
  10. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 10 中的图像 1,2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: 步骤 10 中的图像 2,2
    • Use your iPod opening tool to push the logic board assembly out of the outer case enough to grab the logic board by its edges.
    • Pull the logic board assembly out of the outer case.
结论
21等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 33
总计 19,937
