跳转到主内容
加入维修社区 - 创建账户
iPod Shuffle 1st Generation USB Port Replacement
你所需要的
  1. iPod Shuffle 1st Generation USB Port Replacement, Hold Switch: 步骤 1 中的图像 1,1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    询问修复机器人
    添加评论
  2. iPod Shuffle 1st Generation USB Port Replacement: 步骤 2 中的图像 1,1
    • Use a spudger to pry up the white plastic hold switch.
    询问修复机器人
    添加评论
  3. iPod Shuffle 1st Generation USB Port Replacement, Casing: 步骤 3 中的图像 1,1
    • If present, remove the cap from the USB port.
    询问修复机器人
    添加评论
  4. iPod Shuffle 1st Generation USB Port Replacement: 步骤 4 中的图像 1,1
    • The following step can be challenging and time consuming. Be sure to go slowly and have patience to prevent damaging your iPod.
    • Use an Exacto knife to separate the glue holding the USB port on the iPod. Run the knife along the seam between the two sections of the iPod until the glue is separated. Expect to run the knife along this edge 20-30 times before the glue will be entirely freed.
    添加评论
  5. iPod Shuffle 1st Generation USB Port Replacement: 步骤 5 中的图像 1,1
    • Continue to run the knife around all four edges of the USB port until the glue is released. You may be able to gently wiggle the knife from side to side to help release the glue.
    询问修复机器人
    添加评论
  6. iPod Shuffle 1st Generation USB Port Replacement: 步骤 6 中的图像 1,1
    • Use a spudger to push on the headphone jack and slide the USB port out of its housing.
    • If the USB port doesn't come free, check to make sure all the glue holding the USB port in place has been released. Pulling on the USB port itself is not recommended as there is a fragile ribbon cable that can be ripped if the USB port suddenly comes free.
    添加评论
  7. iPod Shuffle 1st Generation USB Port Replacement: 步骤 7 中的图像 1,1
    • After the USB port comes free, carefully slide it out of its housing. Don't pull it out too far because there's still a ribbon cable connecting it to the logic board.
    询问修复机器人
    添加评论
  8. iPod Shuffle 1st Generation USB Port Replacement: 步骤 8 中的图像 1,1
    • Continue to slide the iPod out of its casing by using a spudger to push on the logic board near the headphone jack.
    添加评论
  9. iPod Shuffle 1st Generation USB Port Replacement: 步骤 9 中的图像 1,1
    • Turn the iPod so that the click wheel is facing up. This will prevent the battery indicator from falling out.
    • If the battery indicator does fall out, don't forget to replace it prior to reassembling the iPod. Getting the battery indicator back in place can be tricky. You'll have to slide it in from the end of the iPod's casing and get it to fall into its slot in the casing.
    • Slide the iPod out of its casing.
    询问修复机器人
    添加评论
  10. iPod Shuffle 1st Generation USB Port Replacement, USB Port: 步骤 10 中的图像 1,1
    • Use a spudger to flip up the black plastic tab holding the USB port ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
    添加评论
  11. iPod Shuffle 1st Generation USB Port Replacement: 步骤 11 中的图像 1,1
    • Carefully peel the yellow USB ribbon up from the battery.
    添加评论
  12. iPod Shuffle 1st Generation USB Port Replacement: 步骤 12 中的图像 1,1
    • Slide the USB ribbon out of its connector.
    • Lift the USB port and detached ribbon cable out of the iPod.
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
1指南评论
Will this be back in stock in the near future?
Maanav Patel - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 100
总计 19,611
