简介
Use this guide to replace your Nano's logic board assembly.
Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
While the front panel is still warm, use the edge of an iPod opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
I strongly recommend using a Small Suction Cup (IF145-019-1) instead of a plastic opening tool.
After half an hour of various heating times, trying to use a plastic opening tool, I overheated the LCD, which caused it to discolour. Now I need to buy a new screen. I wish I'd thought to use a suction cup earlier; it seems so obvious in retrospect.
We have a temperature controlled testing oven at work. I set the oven for 50 degrees C, let it absorb heat for half an hour, then took it out. I had zero luck with either the plastic pry tool or the suction cup, so I carefully pried up the indicated side with the sharp pointed tip of a dental pick until I could get the plastic tool into the crack opening.
Remove the front panel assembly, minding its two cables that may get caught. To reassemble, you can use the double-sided tape found here.
How come you did not put back the metal plate that goes between the iPod and the display?
Use an iPod opening tool to lift the headphone jack assembly connector up and out of its socket on the logic board.
Use your iPod opening tool to gently push the dock connector toward the center of the Nano.
Remove the logic board assembly from the Nano, being careful not to damage the headphone jack assembly cable.
64等其他人完成本指南。
9条评论
Hi, i wonder if you could help me... I changed my cracked screen (my ipod worked even though the screen was broken) but then when I assembled the ipod ( I did everything you did) it doesn't work, nor does my computer recognize it anymore. Would you happen to know what might be the problem? Have I unintentionally somehow damaged it?
Thanks for the guide Andrew! I've just replaced my cracked screen and everything works flawlessly.
Hi..just to tell u about my ipod. It was accidentaly washed in my washing machine. I want to know..is the ipod still in function if i replace the battery only not the board. Im still hoping that my ipod still can be use. I love my ipod 6th generation. It has sentimental value to me..huhu
I did the very same thing, washed my 6th gen in the washer. when i realized what i had done, i immediately put the ipod in a tub of rice. now it works, but only when it’s plugged in. I’m pretty sure it’s the battery that needs replacing. I’ve not replaced the battery as all of the things i need from ifixit are out of stock. If everything on the ipod works except that it won’t hold a charge and stay on unless plugged in, then it’s most likely the battery and replacing it will probably fix the problem.
hello i have also a Ipod Nano 6 e generation found in recyclebox ! ,i have put in Iphone charge kabel to see if he work,s no reaction it all, i opent the Enclosure carefully and discover what,s in how compact is it ,what fragile component,s are inside ,i found a kabel from mainboard wich is broken ,i search on Google Ipod Nano 6 e generation kabel and replace the new one and connect it with the little mainboard also the little screen and put it on Iphone charge kabel again ,i press the on button to see if it will start up but no ,it could be the processor is crashed and the Ipod is Crashed ,it is a very compact nice design media player MP 3
I found that my locksmith pinning tweezers are perfect for disconnecting the the various connectors.
any suggestions on how to fix an on/off button on the IPOD Nano Gen 6
Do I need new adhesive to reassemble?
David Wallin - 回复
