跳转到主内容
iPod Nano 6th Generation Battery Replacement
你所需要的
  1. iPod Nano 6th Generation Battery Replacement, Front Panel Assembly: 步骤 1 中的图像 1,1
    • Use a heat gun or hair dryer to soften the adhesive securing the perimeter of the front panel assembly to the outer case.
    • Be careful not to overheat the front panel assembly, as it may result in damage to the LCD.
  2. iPod Nano 6th Generation Battery Replacement: 步骤 2 中的图像 1,1
    • While the front panel is still warm, use the edge of an opening tool to pry it from the headphone jack side of the front panel assembly out of the Nano.
    • Do not attempt to pry out the front panel assembly from, or insert the opening tool into the left side of the display, as the display data cable is right underneath and may be damaged in the process.
    • Continue prying the perimeter of the front panel assembly out of the outer casing, being careful not to damage the display data cable held under its left edge.
    • If the front panel is excessively difficult to lift out of the outer case, reheat the area and try again.
  3. iPod Nano 6th Generation Battery Replacement: 步骤 3 中的图像 1,2 iPod Nano 6th Generation Battery Replacement: 步骤 3 中的图像 2,2
    • Lift the front panel assembly from the headphone jack side of the Nano.
    • Pull the front panel assembly slightly away from the left side of the Nano to clear the display data cable.
    • The front panel assembly is still attached to the Nano by two cables.
  4. iPod Nano 6th Generation Battery Replacement: 步骤 4 中的图像 1,1
    • Lay the front panel assembly next to the Nano.
    • Remove the following two screws:
    • One 2.3 mm Phillips screw
    • One 2.6 mm shouldered Phillips screw
  5. iPod Nano 6th Generation Battery Replacement: 步骤 5 中的图像 1,2 iPod Nano 6th Generation Battery Replacement: 步骤 5 中的图像 2,2
    • Use an opening tool to pry the steel shield out of the Nano by its upper right corner.
    • Remove the steel shield from the Nano.
  6. iPod Nano 6th Generation Battery Replacement: 步骤 6 中的图像 1,2 iPod Nano 6th Generation Battery Replacement: 步骤 6 中的图像 2,2
    • Use an opening tool to disconnect the display data and digitizer cable connectors up from their sockets on the logic board.
  7. iPod Nano 6th Generation Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the front panel assembly, minding its two cables that may get caught.
    • To reassemble, you can use the double-sided tape found here.
  8. iPod Nano 6th Generation Battery Replacement, Battery: 步骤 8 中的图像 1,2 iPod Nano 6th Generation Battery Replacement, Battery: 步骤 8 中的图像 2,2
    • Use an opening tool to gently pry the battery up from the adhesive securing it to the outer case.
    • The adhesive is very strong. Work carefully and slowly, making sure to not slip and break any fragile components.
    • Use your thumb to pull the battery toward the left side of the Nano as you pry the battery's other edge out of the outer case.
    • From here, you can either splice the new battery wires or desolder and remove the old battery wires from the logic board entirely. These two options are detailed below.
  9. iPod Nano 6th Generation Battery Replacement, Splicing old wires to new wires: 步骤 9 中的图像 1,1
    • The wires on your replacement battery can be spliced into the existing wires from the old battery. This process allows you to install your new battery without desoldering and removing the existing wires from the logic board.
    • Detailed instructions for this procedure can be found in this Fix It Planet video.
  10. iPod Nano 6th Generation Battery Replacement, Removing old wires entirely: 步骤 10 中的图像 1,1
    • Use an opening tool to lift the headphone jack assembly connector up and out of its socket on the logic board.
  11. iPod Nano 6th Generation Battery Replacement: 步骤 11 中的图像 1,2 iPod Nano 6th Generation Battery Replacement: 步骤 11 中的图像 2,2
    • Remove the single 1.9 mm Phillips screw that secures the logic board to the outer case.
    • Use an opening tool to gently pry the logic board off the adhesive holding it against the outer case.
    • Do not excessively pry the logic board upward.
  12. iPod Nano 6th Generation Battery Replacement: 步骤 12 中的图像 1,2 iPod Nano 6th Generation Battery Replacement: 步骤 12 中的图像 2,2
    • Use your opening tool to gently push the dock connector toward the center of the Nano.
    • Remove the logic board assembly from the Nano, being careful not to damage the headphone jack assembly cable.
    • Follow the steps found in this PON2.0 video for desoldering and removing the old battery wires from the logic board.
结论
另外一个人完成了本指南。
3条评论
This is probably a stupid question but is there a way to put on the battery without solder? i dont have any tools and there isnt really any repair shops next to my place or around
ThomasDV5 - 回复
You could could splice the wires (cut the original battery wire in the middle exspose some bare wire and twist together with the replacement batteries wire) don't forget to not leave bare wire exposed heat shrink or wrap with electrical tape.
P tr -
Do you sell the adhesive to adhere the face back on?
Bill - 回复
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 141
过去 30 天: 915
总计 7,994
