本指南有最近更改,您可查看未经巡查的最新版本。
简介
Replace the broken logic board in your iPod Nano.
你所需要的
Insert an iPod opening tool between the outer case and top bezel near the screen.
Lifting up on the iPod opening tool, gently pry the top panel off of the device.
Use a heat gun to soften the adhesive underneath the plastic bezel at the bottom of the iPod.
Use a plastic opening tool to pry the bezel from the case of the iPod and remove it.
Use a heat gun to soften the adhesive underneath the camera/microphone cover.
Pry the camera/microphone cover off the case with a metal spudger and remove it.
11等其他人完成本指南。
一条评论
at step 14 when lifting the click wheel have a look at the small black bar, placed to the upper edge of the chip. in its center it holds a very small tiny coil spring thats hardly to see and that easily jumps out. better you lift the click wheel in parallel to the ground. if spring jumps off one time, you will never find it again. i guess it has some grounding purpose a it docks on the metal below the logic on the click wheel. also a point to have an eye on at reassembly
An distege - 回复
