跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
iPod Nano 5th Generation Click Wheel Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iPod Nano 5th Generation Click Wheel Replacement, Click Wheel: 步骤 1 中的图像 1,2 iPod Nano 5th Generation Click Wheel Replacement, Click Wheel: 步骤 1 中的图像 2,2
    • Use a heat gun to soften the adhesive underneath the plastic bezel at the bottom of the iPod.
    • Use a low heat setting and do not hold the heat gun in place for too long to avoid melting the plastic bezel.
    • Use a plastic opening tool to pry the bezel from the case of the iPod and remove it.
  2. iPod Nano 5th Generation Click Wheel Replacement: 步骤 2 中的图像 1,3 iPod Nano 5th Generation Click Wheel Replacement: 步骤 2 中的图像 2,3 iPod Nano 5th Generation Click Wheel Replacement: 步骤 2 中的图像 3,3
    • Unscrew three screws from the bottom of the iPod:
    • Two 4.4 mm angled Phillips screws
    • One 5.4 mm Phillips screw.
    • These screws may not come out on their own, so be sure not to lose them when removing the retainer.
    • Use a plastic opening tool to pry the metal retainer out from the bottom of the iPod and remove it.
  3. iPod Nano 5th Generation Click Wheel Replacement: 步骤 3 中的图像 1,2 iPod Nano 5th Generation Click Wheel Replacement: 步骤 3 中的图像 2,2
    • Insert a metal spudger into the slot at the bottom of the iPod just above the dock connector.
    • Use the metal spudger to pry up the bottom edge of the click wheel.
  4. iPod Nano 5th Generation Click Wheel Replacement: 步骤 4 中的图像 1,2 iPod Nano 5th Generation Click Wheel Replacement: 步骤 4 中的图像 2,2
    • Place a guitar pick between the click wheel and the case of the Nano and remove the metal spudger.
    • Pry up the edges of the click wheel with the guitar pick until the click wheel comes free from the case.
    • Do not try to completely remove the click wheel yet, as it is still held in place by a ribbon cable.
  5. iPod Nano 5th Generation Click Wheel Replacement: 步骤 5 中的图像 1,2 iPod Nano 5th Generation Click Wheel Replacement: 步骤 5 中的图像 2,2
    • Lift the click wheel out of the way with one hand and use a plastic opening tool to pry the click wheel ribbon cable connector off its socket on the logic board.
    • Remove the click wheel.
结论
Matthew Newsom
于01/05/10注册
39,496 声望
创作了67篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,164
