跳转到主内容
iPod Nano 4th Generation Top Bezel Replacement
你所需要的
  1. iPod Nano 4th Generation Top Bezel Replacement, Slide Switch Into Lock: 步骤 1 中的图像 1,2 iPod Nano 4th Generation Top Bezel Replacement, Slide Switch Into Lock: 步骤 1 中的图像 2,2
    • Put the hold switch in the lock position.
  2. iPod Nano 4th Generation Top Bezel Replacement, Get Under The Bezel: 步骤 2 中的图像 1,1
    • Use your opening tool or your flathead screwdriver to get under the bezel and replace it.
    • You will have to push the metal but don't be scared it won't bend.
    • It is held on with some adhesive so you will have too use some force.
  3. iPod Nano 4th Generation Top Bezel Replacement, Finished!!: 步骤 3 中的图像 1,1
    • Your done!!! (Yes that simple)
结论
另外一个人完成了本指南。
Ad123re
于01/16/24注册
165 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 24
总计 288
