跳转到主内容
iPod Nano 2nd Generation Top Bezel Replacement
你所需要的
  1. iPod Nano 2nd Generation Top Bezel Replacement, Top Bezel: 步骤 1 中的图像 1,1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod Nano 2nd Generation Top Bezel Replacement: 步骤 2 中的图像 1,1
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic top.
    • Lift the top bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
结论
12等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
2条评论
But how do I install it on? Do I just push it back? I want to fix mine but it doesn't even have the top part anymore, or the hold switch
luis - 回复
I would recommend that you put some new adhesive on there. All you have to do is put the switch in its place and put on a new top and push it down.
Ad123re -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 5
过去 30 天: 27
总计 18,885
