跳转到主内容
iPod Nano 2nd Generation Bottom Bezel Bracket Replacement
你所需要的
  1. iPod Nano 2nd Generation Bottom Bezel Bracket Replacement, Bottom Bezel: 步骤 1 中的图像 1,1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod Nano 2nd Generation Bottom Bezel Bracket Replacement: 步骤 2 中的图像 1,1
    • When removing the the bottom bezel, be sure not to bend the plastic surrounding the dock connector.
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic bezel
    • Lift the bottom bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
  3. iPod Nano 2nd Generation Bottom Bezel Bracket Replacement, Bottom Bezel Bracket: 步骤 3 中的图像 1,1
    • Remove the following two screws:
    • One #00 Phillips screw with a large head near the headphone jack.
    • One #00 Phillips screw with a smaller head near the side of the iPod. This screw strips easily, so be sure to press down firmly on the screwdriver.
  4. iPod Nano 2nd Generation Bottom Bezel Bracket Replacement: 步骤 4 中的图像 1,1
    • Use a metal spudger to carefully pry the headphone jack out of the casing. DO NOT remove the headphone jack from the iPod entirely, as it is connected via a fragile ribbon connector to the click wheel.
  5. iPod Nano 2nd Generation Bottom Bezel Bracket Replacement: 步骤 5 中的图像 1,1
    • Slide the headphone jack out until the white plastic housing is no longer held in place by the metal casing.
  6. iPod Nano 2nd Generation Bottom Bezel Bracket Replacement: 步骤 6 中的图像 1,1
    • Remove the newly-revealed Phillips #00 screw from beneath the headphone jack.
  7. iPod Nano 2nd Generation Bottom Bezel Bracket Replacement: 步骤 7 中的图像 1,1
    • Lift the bottom bezel bracket out of the iPod.
结论
7等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 25
总计 17,698
