这个纤薄、新颖、绿绿的是啥?正是第7代 iPod Nano。这款产品有多个色彩可供选择,但我们偏好绿色。
Nano 完全重新设计,和 iPod touch 和 iPhone 一起称兄道弟。
16GB 存储空间
2.5英寸宽屏多点触控显示屏
内建的加速度传感器
蓝牙4.0
在先前如同整形医师般对逻辑板的窥探后,我们终于可以轻轻取出逻辑板了~
如同第五代,许多重要的部件 - 包括电池、Lightning 接头以及音量控制部件 - 都被焊在逻辑板上。
逻辑板走了,后壳孤零零的。做一个“原谅色”的外壳真不容易,你懂得~
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
23条评论
As usual, iFixit has decided that any integration, thinness, beauty or functionality is low on the list of importance. The most important thing is Lego like snap together and bulk.
I'd recommend you to read the iFixIt mission statement, but you'd figure out they're right soon enough when your first iProduct breaks one way or the other 1 month after the warranty expires..
Using screws and clips does not imply that a product cannot be slim and beautiful, btw.
denmike -
Tried to replace a broken digitizer and ended up breaking the LCD. These instructions don't make clear in Step #6 how deep you need to get the opening tool in order to pull out the ENTIRE DISPLAY ASSEMBLY. The picture indicates, quite wrongly, that you only need to get the tip of the opening tool under the glass. This will result in separating the digitizer from the screen prematurely, and then breaking the LCD screen. The reality is that you must get the tool deep under the metal base of the assembly and pry the whole thing out with much force (it's glued on both sides). Frustrating.
True, I broke the LCD screen with this method. Glue is everywhere in this device.
Axel -
