跳转到主内容
加入维修社区 - 创建账户
iPod Mini Headphone Jack Board Replacement
你所需要的
    1. iPod Mini Headphone Jack Board Replacement, Top Bezel: 步骤 1 中的图像 1,1
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      询问修复机器人
      添加评论
    2. iPod Mini Headphone Jack Board Replacement: 步骤 2 中的图像 1,1
      在这个步骤中使用的工具:
      Jimmy
      $7.95
      • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
      • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
      • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
      添加评论
    3. iPod Mini Headphone Jack Board Replacement: 步骤 3 中的图像 1,1
      • Lift the top bezel off of the iPod.
      添加评论
    1. iPod Mini Headphone Jack Board Replacement, Bottom Bezel: 步骤 4 中的图像 1,1
      在这个步骤中使用的工具:
      Jimmy
      $7.95
      • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
      添加评论
    2. iPod Mini Headphone Jack Board Replacement: 步骤 5 中的图像 1,1
      • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
      • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
      添加评论
    3. iPod Mini Headphone Jack Board Replacement: 步骤 6 中的图像 1,1
      • Lift the metal retaining bracket out of the iPod.
      询问修复机器人
      添加评论
    1. iPod Mini Headphone Jack Board Replacement, Headphone Jack Board: 步骤 7 中的图像 1,1
      • Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
      询问修复机器人
      添加评论
    2. iPod Mini Headphone Jack Board Replacement: 步骤 8 中的图像 1,1
      • Remove the two #00 Phillips screws securing the headphone jack to the casing.
      询问修复机器人
      添加评论
    3. iPod Mini Headphone Jack Board Replacement: 步骤 9 中的图像 1,1
      • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
      • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
      询问修复机器人
      添加评论
    4. iPod Mini Headphone Jack Board Replacement: 步骤 10 中的图像 1,1
      • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
      询问修复机器人
      添加评论
    5. iPod Mini Headphone Jack Board Replacement: 步骤 11 中的图像 1,1
      • Lift the battery off of the logic board and lay it to the side of the iPod.
      询问修复机器人
      添加评论
    6. iPod Mini Headphone Jack Board Replacement: 步骤 12 中的图像 1,1
      • Use a spudger to carefully pry up the headphone jack board from the logic board. Be careful to pry up near the connector to prevent unnecessary strain on the board.
      • Lift the headphone jack board off of the logic board.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
15等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 30
过去 30 天: 97
总计 30,431
