跳转到主内容
iPod Mini Bottom Bezel Replacement
你所需要的
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
  1. iPod Mini Bottom Bezel Replacement: 步骤 2 中的图像 1,1
    • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
    • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
  2. iPod Mini Bottom Bezel Replacement: 步骤 3 中的图像 1,1
    • Lift the metal retaining bracket out of the iPod.
结论
15等其他人完成本指南。
iRobot
于09/24/09注册
1 声望
创作了636篇指南
一条评论
After removing my bottom bezel, I needed a couple small, cut pieces of double sided tape to hold it in place upon reassembly.
Stephen - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 71
总计 18,434
