跳转到主内容
加入维修社区 - 创建账户
iPod 5th Generation (Video) Front Faceplate Replacement
你所需要的
  1. iPod 5th Generation (Video) Front Faceplate Replacement, Open your iPod.: 步骤 1 中的图像 1,1
    • Take caution while opening your iPod, making sure not to rip any ribbon cables.
    • You can use things such as a guitar pick or spudger to pry open the iPod.
  2. iPod 5th Generation (Video) Front Faceplate Replacement, Unplug the iPod's battery ribbon cable: 步骤 2 中的图像 1,1
    • Gently unplug the battery ribbon cable from the iPod and lift up the back shell.
    • Make sure the iPod looks like the image shown.
  3. iPod 5th Generation (Video) Front Faceplate Replacement, Pry the frontplate off of the frame that holds the motherboard: 步骤 3 中的图像 1,2 iPod 5th Generation (Video) Front Faceplate Replacement, Pry the frontplate off of the frame that holds the motherboard: 步骤 3 中的图像 2,2
    • Using a spudger or pick, gently pry the frontplate off of the iPod's frame that holds internals such as the screen, motherboard, etc.
    • Your iPod should look like the second image when this step is completed.
  4. iPod 5th Generation (Video) Front Faceplate Replacement, Installing the new frontplate: 步骤 4 中的图像 1,2 iPod 5th Generation (Video) Front Faceplate Replacement, Installing the new frontplate: 步骤 4 中的图像 2,2
    • First, install the middle button that came with your new frontplate by lifting up the click wheel and simply clicking the center button into place.
    • Then, install the frontplate by just aligning the frontplate with the iPod frame and pressing it down into place until all the clips click together.
  5. iPod 5th Generation (Video) Front Faceplate Replacement, Plug the battery ribbon cable back in: 步骤 5 中的图像 1,1
    • Before closing the iPod, make sure you reconnect the battery ribbon cable.
    • Be careful not to rip it!
  6. iPod 5th Generation (Video) Front Faceplate Replacement, Close your iPod and try to turn it on: 步骤 6 中的图像 1,2 iPod 5th Generation (Video) Front Faceplate Replacement, Close your iPod and try to turn it on: 步骤 6 中的图像 2,2
    • Once you've completed everything and closed your iPod, try and turn it on by pressing any button on the click wheel. If it turns on and everything works without issue, than you've successfully completed this guide!
    • But, if something doesn't work after replacing it, such as there being no sound or the screen is not displaying things correctly, reopen the iPod and examine the ribbon cables and capacitors to make sure none are missing or ripped.
结论
3等其他人完成本指南。
appealingapple
于03/26/23注册
217 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 58
过去 30 天: 297
总计 5,669
