简介
Connects the touch interface to the logic board.
你所需要的
Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
After all five tabs along the right side are free, the case should open easily.
Lift up the hard drive with one hand and carefully disconnect the hard drive ribbon from the logic board.
Lift the hard drive out of the iPod.
Use a spudger to carefully disconnect the orange touch wheel cable from the front panel.
Lift the touch wheel cable out of the iPod.
4等其他人完成本指南。
