简介
Your iPod's motherboard controls just about everything on the iPod.
你所需要的
Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
The angle is important. I tried forever to get it started more like the photo, straight in between. No luck, seemed impossible. When I put the iPod down on a padded surface, held the top/white half with one hand, I was able to push "down" into the metal with the opening tool with relative ease. Popped right off without any great force. Then I was able to more closing match the remaining photos, circling around the other tabs holding it as pictured.
Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
can be a little reluctant - DONT FORCE IT! gently pry the _entire_ contents out of the metal base at the dock-connector end. After which the headphone jack and lock switch will be free. Unlike newer models, there are no active components on the metal rear panel so no ribbon cables running between the two halves.
Loosen the connector by pulling the brown locking bar toward the hard drive cable using the tips of your fingers.
2等其他人完成本指南。
4条评论
I wish all iPods were this easy to fix!
I just replaced a battery and Logic Board in an iPod 2nd Generation. Totally easy; No soldering necessary. The hardest part was waiting for the Logic Board in the mail.
My 2G will not connect to either windows or macos via FW. I have cleaned the connector, checked the logic board for obvious damage, etc. My 1G connects to the same computers just fine. The 2G otherwise works, passes all diagnostics (seems to), and wakes up and charges when I plug it in to the computer. Do I need a new logic board? Otherwise, I am thinking of just manually transferring my music to the drive and living with it.
Hi,
try to replace the hard drive from your 1G first ans see if this works.
Please let me know.
Thanks,
