简介
Upgrade your storage with a new hard drive.
工具
配件
没有特定配件。
Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. It helps to hold the iPod at top and bottom as shown and squeeze to help pop out the edge. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
Lift the battery up from the adhesive holding it to the iPod.
Lay the battery next to the iPod (it is still connected to the logic board).
7等其他人完成本指南。
8条评论
Kevin. Theydon't make hard drives for it for anymore, but they make adapters for CF card and SD cards. Of Course you can put whatever size you want in it
1st and maybe 2nd gen sync and charge only over firewire and need a hard drive. I tried a comact flash and a zif ssd in the format of the newer hard drives and it finds the drive, but wont format. It stops half way. The newer ipods (3rd gen and up) that sync over usb can use solid state alternatives (2nd gen is the same ipod with a bigger drive and a touch scroll wheel). If you can find a zif ssd smaller than 32gb it might work, but dont forget about the zif to 50 pin adapter.
ZIF SSD KingSpec ZF18-32
Has anyone replaced the 5GB drive with the 10GB (original model)? Any issues?
Am trying to resurrect my old 5gb scroll wheel ipod. Keep getting the folder+exclamation. Makes a weird electronic buzzing noise as it tries to reboot. Occasionaly springs back to life only to freeze after a few minutes. When I do get it connected disk utility says the drive is fine. Am wondering if I can swap out the drive for a Toshiba MK3006GAL 30gb 50pin single-platter drive; it’s the only potential match I can find for sale. anyone tried this?
Am sorry to say that I folded a bubblegum card over and placed it inside the case at the end near the drive connector. The iPod has worked flawlessly ever since. I suspect my HDD is fine but that there may be a loose contact somewhere at the connection between HDD and board that the extra pressure has helped rectify. Not really a ‘fix’ but it seems to be working.
