简介
使用本指南移除并更换 iPhone XS Max 中的后置摄像头。后置摄像头组件由两个独立的模块组成:一个是广角摄像头,另一个是长焦摄像头。两个模块都作为一个单元更换。
iPhone XS 和 XS Max 都使用相同的相机;该部件可以在两个型号之间自由交换。
注意:本指南指示你完全拆下显示屏电缆并拆下显示屏组件,以便更好地接触后置摄像头 —— 但是,可以在仍连接显示屏电缆的情况下拆卸和更换后置摄像头。只要显示器得到适当支撑且显示器电缆没有损坏,高级读卡器可以跳过断开显示器以节省时间。
你所需要的
将蓝色手柄向后拉,解锁反向钳的手臂。
将手臂滑过 iPhone 的左边缘或右边缘。
将吸盘靠近 iPhone 的底部边缘——一个在前面,一个在后面。
将吸盘一起挤压,以向所需区域施加吸力。
加热 iOpener 并将其穿过反向钳的手臂。
把 iOpener 折叠起来,放在 iPhone 的底部边缘。
等待一分钟,让粘合剂有机会释放,形成一个开口缝隙。
将打开工具插入开口缝隙,位于屏幕和塑料边框之下,而不是屏幕本身。
跳过接下来的三个步骤。
将新的更换部件与原始部件进行比较 -—— 在安装之前,你可能需要转移剩余部件或从新部件上移除背面粘合剂。
要重新组装你的设备,请按相反顺序执行上述步骤。
将你的电子垃圾带到R2或e-Stewards认证的回收商。
修理没有按计划进行?查看我们的论坛以获取故障排除帮助。
30等其他人完成本指南。
由衷感谢以下译者:
88%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
4条评论
Hi I was wondering if the rear facing camera class is broken is there a way to replace the glass?
I’m replacing it now by myself :) There’s nothing complicated. (except screws and reminding where they come from)
Zared -
Yes you can buy it on Amazon for around $8. It is very easy, no heat gun required
After being quoted over $500 at various repairers to replace these rear-facing cameras, I decided to purchase the part for $100 and complete the repair myself. The instructions were detailed and easy to follow, and the different screws being colour coded on the instructions really helped with reassembling. My camera now works perfectly, and I saved myself over $400 by doing the repair myself. I also replaced the adhesive water resistant seal, which was much easier than I anticipated. All in all, 10/10 repair guide, thank you so much!
