跳转到主内容
修复你的物品
维修的权力
商店
简介
This is an advanced, professional-level repair for replacing only the glass portion on an iPhone XS cracked screen, also known as screen refurbishing.
视频概述
  1. Test the display, touch functionality and 3D Touch of the screen. All going well.
    • Test the display, touch functionality and 3D Touch of the screen. All going well.
  2. Take apart the phone and remove the OLED Screen Assembly. Then put the OLED Screen Assembly on the Heating platform.
    • Take apart the phone and remove the OLED Screen Assembly. Then put the OLED Screen Assembly on the Heating platform.
    • Apply the specialized iPhone X/XS glue remover to the gap between the bezel and the OLED screen.
    • Cut out the top bracket with the Cutting Nipper and remove the ear speaker cover. Continue to separate the bezel with Pry Piece and Glue Remover. Then separate the bezel from the OLED with the Cutting Nipper.
  3. First, let’s stick adhesive tape on the broken glass lens. Then, place the OLED Screen Assembly on the Heat Platform.
    • First, let’s stick adhesive tape on the broken glass lens. Then, place the OLED Screen Assembly on the Heat Platform.
    • Remove residual glue on the ear speaker area with a blade.
    • Separate the glass lens from OLED with Cutting Wire.
  4. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  5. OCA Glue removing can be finished with hand tearing.
    • OCA Glue removing can be finished with hand tearing.
  6. The OCA should be laminated to the glass lens at first.
    • The OCA should be laminated to the glass lens at first.
    • Then laminate the OCA attached glass lens to the OLED Screen.
    • This step is quite complicated and please check out the video for detailed operation.
  7. Put the OLED Screen Assembly into Bubble Removing Machine for 10 minutes.
    • Put the OLED Screen Assembly into Bubble Removing Machine for 10 minutes.
  8. Prepare a new piece of iPhone XS bezel. Apply the 460 glue to the bezel. Apply pressure to fit the OLED Screen Assembly with the bezel.
    • Prepare a new piece of iPhone XS bezel. Apply the 460 glue to the bezel. Apply pressure to fit the OLED Screen Assembly with the bezel.
  9. Get the OLED Screen Assembly installed and test. Run function test - Display; Touch; 3D Touch. All going well.
    • Get the OLED Screen Assembly installed and test. Run function test - Display; Touch; 3D Touch. All going well.
Phryne
于2019年11月17日注册
10,251 信誉积分
创作了80篇指南
添加评论
浏览统计数据:
过去的24小时: 9
过去的7天: 141
过去的30天: 707
总计 2,590
