简介
按照本指南中的步骤拆卸,转移和/或更换 iPhone XS 中的耳机扬声器和前传感器组件。该组件包括耳机扬声器、麦克风、环境光传感器、泛光照明器和接近传感器。
这个组件在工厂与你的个人iPhone配对,因此你必须在更换显示器时将其从旧显示器转移到新的。
泛光照明器是组成生物识别Face ID安全功能的一部分,如果原始组件损坏或安装不正确,Face ID功能将失败。用新零件替换它也会导致Face ID失效,因此在此过程中要特别注意不要损坏任何这些组件。如果损坏,只有苹果可以恢复Face ID功能。
你所需要的
将蓝色手柄向后拉,以解锁反向钳的夹臂。
将反向钳从 iPhone 的左侧或右侧边缘滑进。
将吸盘放置在 iPhone 底部边缘附近,一个在正面,一个在背面。
将吸盘挤压在一起,以在所需区域产生吸力。
加热 iOpener并将其穿过反向钳的臂部。
将iOpener折叠,使其位于iPhone的底部边缘
等待一分钟,让粘合剂有机会打开,形成一个打开的缝隙。
在屏幕和塑料边框之间的缝隙中插入翘片,而不是直接插入屏幕本身。
跳过接下来的三个步骤。
用坚定而持续的压力拉起吸盘,使前面板和后壳之间产生一个轻微的间隙。
在屏幕和塑料边框之间的间隙插入翘片,而不是直接插入屏幕。
It seems like I need a third hand to do this. To hold the phone; hold the suction cup; and push the pick in the space.
在这个步骤中使用的工具:Magnetic Project Mat$19.95
卸下固定主板连接器支架的五颗螺钉,如下所示:
三个1.0毫米Y000螺钉
一个1.3毫米Y000螺丝
一个3.7毫米十字螺丝
FYI: I used a tiny piece of scotch tape to hold those 1mm screws in place while aligning the magnetic screwdriver. Otherwise they are so tiny the magnetic bit pulls them right out the hole.
用撬棒或指甲分离前面板的传感器总成连接器。
In my phone the connector made poor contact with the socket resulting in no sound audible through the phone receiver/headset. There was an overhang of insulation close to the socket which I believe may have prevented a good connection. So if you have these kinds of audio problems you might see if this is the problem.
使用撬棒或者指甲来将数字转换器排线链接头从插座上翘起。
Reassembly: reconnecting the press connectors upon reassembly was so hard, even for the ones not seated in a recessed location !! It took me two days to get them reconnected. What helped me was to shine bright lights on all sides of the iPhone and then hold the iPhone vertically like a book and press it in that way. They are now all in, but the touchscreen functionality has disappeared :( so I will need to reconnect that one.
小心的抬起排线,直到粘合剂断开。
Will replacing camera and sensors fix damaged face I'd
No, FaceID will be disabled because the original sensors are paired with the logic board.
取下耳机扬声器和前传感器组件。
接近传感器
泛光照明器
必须正确定位这些模块,这样才不会被任何粘合剂阻塞。
What is that hole that is on the opposite side of the proximity sensor? Is it necessary any adhesives or special filter to put it back on the bracket?
Hi Rafael! The hole is for the front-facing microphone. You should be able to reuse the existing adhesive on the screen. If you're transferring it, you can cut a square of double-sided tape such as Tesa tape, poke a generous hole in the center of the square, and apply it to the cable with the hole.
把你的更换零件和原装零件做对比——你可能需要转移一些旧的零件,或者在安装之前把新零件后面的胶带去掉。
请按逆序操作重组你的设备。
把你的电子废料带到 R2 或者 e-Stewards 认证的回收商那里。
维修进展不如意?请查阅我们的问题解答指南 来排除障碍。
请按逆序操作重组你的设备。
27等其他人完成本指南。
由衷感谢以下译者:
92%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
13条评论
My iPhone xs face I'd isnt working . Can changing front cameras and sensors will fix it ,
no, cameras are not part of the prox module located on the display itself. you have to switch the prox module from the old display to the new one, the bundle of prox sensor, ambient light sensor, receiver, top mic and face id module. or run repaircal on new display assembly with NEW prox module etc OR ELSE face ID won’t work
nand26 -
My iPhone XS’s Face ID stopped working yesterday suddenly. I tried all the standard stuff like resetting Face ID and restore, so it’s definitely a hardware problem.
When trying to set up Face ID, the phone detects a face but always says to move the phone up or down. Likewise, in selfie portrait mode in the camera, it keeps saying move farther away.
So if I were to change the front sensor assembly, it wouldn’t work anyway?
Daniel Kim - 回复
Hi Daniel,
You are correct. FaceID hardware is paired to the logic board—replacing the hardware will disable FaceID.
Can you tell how to make face id still work after changed this part ?
Hello,
Please can you explain so we all understand the connection of replacing the earphiece speaker on this way and Face ID function? Will it work or not! What is confusing is that face id projector is on another flex, below battery…but I don’t understand what part that face id is using is on this new part you replaced. Face ID is on both flex or how is working. Why simply replacing this earphiece with new flex will cause faliure in face ID. Please explain!!!! Thank’s
Hi Kobra,
The flood illuminator on the earpiece speaker module is paired with the logic board and will cause Face ID to not work if it is replaced.
Hi, If I replace iPhone XS Earpiece Speaker with this new one, my FaceID will stop working? please clarify.
hi, i need to replace the display and ear speaker on my iphone xs. replacing ear speaker and display will make face id still working? sorry but i am little confused. just wanna make sure if i buy display and ear speaker replacement am i all set?
No, Face ID will be disabled after the replacement of the earpiece speaker due to apple pairing the flood illuminator sensor to the logic board so if you want Face ID to work you will have to get apple to do it because they pair components to the logic board because they like money and don't care about their customers. That is all.
Face ID stopped working after iphone XS was under water, and now letter "y" not working any ideas please on what do do....
Der Original Akku ist codiert. Egal, ob man einen zweiten Apple Original Akku oder einen neuen Fremdakku einbaut erscheint bereits in den Einstellungen eine "Wichtige Batterienachricht" mit einem roten Punkt. "Unbekanntes Bauteil" und die "Informationen zum Batteriezustand" sind nicht verfügbar. Diese Nachricht verbleibt immer und nervt auf Dauer immens.
Der Akku muss angelernt werden und dieses können von jetzt an nur authorisierte Apple Servicebetriebe und diesen ist es durch Apple verboten die notwendige Info weiterzugeben.
Dies ist nicht zu verwechseln mit der bereits bekannten Rekalibrierung seit iOS 14.5.
Seit dieser neuen Codierung kostet der Akkutausch bei Apple auch nicht mehr 75 € sondern aktuell 99 € (Stand Novmber 2023 in Deutschland).
Damit sind künftig alle nicht authorisierten Servicebetriebe raus - denn wer will schon dauernd diese Mitteilung auf dem Bildschirm haben?
Überlegt vorher, ob unter diesen Bedingungen ein eigener Akkutausch noch sinnvoll ist .....
Manfred Wachtel - 回复
Lieben Dank @manfredwachtel ! Mehr Infos dazu haben wir auch in unserem Blog zusammengefasst: https://de.ifixit.com/News/78890/teileko...
Sandra Hiller -
