简介
使用本指南移除并更换 iPhone XS 中的后置摄像头。后置摄像头组件由两个独立的模块组成:一个是广角摄像头,另一个是长焦摄像头。两个模块都作为一个单元更换。
iPhone XS 和 XS Max 都使用相同的相机;该部件可以在两个型号之间自由交换。
注意:本指南指示你完全拆下显示屏电缆并拆下显示屏组件,以便更好地接触后置摄像头 —— 但是,可以在仍连接显示屏电缆的情况下拆卸和更换后置摄像头。只要显示器得到适当支撑且显示器电缆没有损坏,高级读卡器可以跳过断开显示器以节省时间。
你所需要的
将蓝色手柄向后拉,以解锁反向钳的夹臂。
将反向钳从 iPhone 的左侧或右侧边缘滑进。
将吸盘放置在 iPhone 底部边缘附近,一个在正面,一个在背面。
将吸盘挤压在一起,以在所需区域产生吸力。
加热 iOpener并将其穿过反向钳的臂部。
将iOpener折叠,使其位于iPhone的底部边缘
等待一分钟,让粘合剂有机会打开,形成一个打开的缝隙。
在屏幕和塑料边框之间的缝隙中插入翘片,而不是直接插入屏幕本身。
跳过接下来的三个步骤。
用坚定而持续的压力拉起吸盘,使前面板和后壳之间产生一个轻微的间隙。
在屏幕和塑料边框之间的间隙插入翘片,而不是直接插入屏幕。
It seems like I need a third hand to do this. To hold the phone; hold the suction cup; and push the pick in the space.
在这个步骤中使用的工具:Magnetic Project Mat$19.95
卸下固定主板连接器支架的五颗螺钉,如下所示:
三个1.0毫米Y000螺钉
一个1.3毫米Y000螺丝
一个3.7毫米十字螺丝
FYI: I used a tiny piece of scotch tape to hold those 1mm screws in place while aligning the magnetic screwdriver. Otherwise they are so tiny the magnetic bit pulls them right out the hole.
用撬棒或指甲分离前面板的传感器总成连接器。
In my phone the connector made poor contact with the socket resulting in no sound audible through the phone receiver/headset. There was an overhang of insulation close to the socket which I believe may have prevented a good connection. So if you have these kinds of audio problems you might see if this is the problem.
使用撬棒或者指甲来将数字转换器排线链接头从插座上翘起。
Reassembly: reconnecting the press connectors upon reassembly was so hard, even for the ones not seated in a recessed location !! It took me two days to get them reconnected. What helped me was to shine bright lights on all sides of the iPhone and then hold the iPhone vertically like a book and press it in that way. They are now all in, but the touchscreen functionality has disappeared :( so I will need to reconnect that one.
小心的抬起排线,直到粘合剂断开。
Will replacing camera and sensors fix damaged face I'd
No, FaceID will be disabled because the original sensors are paired with the logic board.
将新的更换部件与原始部件进行比较 -—— 在安装之前,你可能需要转移剩余部件或从新部件上移除背面粘合剂。
要重新组装你的设备,请按相反顺序执行上述步骤。
将你的电子垃圾带到R2或e-Stewards认证的回收商。
修理没有按计划进行?查看我们的论坛以获取故障排除帮助。
24等其他人完成本指南。
由衷感谢以下译者:
88%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
一条评论
I have some dark spots on my main camera and i notice some dust behind the lens cover, do you think it as to do with it?
Thank you
Der Original Akku ist codiert. Egal, ob man einen zweiten Apple Original Akku oder einen neuen Fremdakku einbaut erscheint bereits in den Einstellungen eine "Wichtige Batterienachricht" mit einem roten Punkt. "Unbekanntes Bauteil" und die "Informationen zum Batteriezustand" sind nicht verfügbar. Diese Nachricht verbleibt immer und nervt auf Dauer immens.
Der Akku muss angelernt werden und dieses können von jetzt an nur authorisierte Apple Servicebetriebe und diesen ist es durch Apple verboten die notwendige Info weiterzugeben.
Dies ist nicht zu verwechseln mit der bereits bekannten Rekalibrierung seit iOS 14.5.
Seit dieser neuen Codierung kostet der Akkutausch bei Apple auch nicht mehr 75 € sondern aktuell 99 € (Stand Novmber 2023 in Deutschland).
Damit sind künftig alle nicht authorisierten Servicebetriebe raus - denn wer will schon dauernd diese Mitteilung auf dem Bildschirm haben?
Überlegt vorher, ob unter diesen Bedingungen ein eigener Akkutausch noch sinnvoll ist .....
Manfred Wachtel - 回复
Lieben Dank @manfredwachtel ! Mehr Infos dazu haben wir auch in unserem Blog zusammengefasst: https://de.ifixit.com/News/78890/teileko...
Sandra Hiller -
