跳转到主内容
iPhone XR Display Assembly Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iPhone XR Display Assembly Replacement, Unscrew the battery connector cover: 步骤 1 中的图像 1,2 iPhone XR Display Assembly Replacement, Unscrew the battery connector cover: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Remove three 1.2 mm Y000 screws securing the battery connector cover bracket.
    • Remove the bracket.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  2. iPhone XR Display Assembly Replacement, Disconnect the battery: 步骤 2 中的图像 1,2 iPhone XR Display Assembly Replacement, Disconnect the battery: 步骤 2 中的图像 2,2
    • Use the point of a spudger to pry the battery connector straight up out of its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  3. iPhone XR Display Assembly Replacement, Unscrew the display connector cover: 步骤 3 中的图像 1,2 iPhone XR Display Assembly Replacement, Unscrew the display connector cover: 步骤 3 中的图像 2,2
    • Remove the two 1.2 mm Y000 screws securing the display connector bracket.
  4. iPhone XR Display Assembly Replacement, Disconnect the digitizer: 步骤 4 中的图像 1,2 iPhone XR Display Assembly Replacement, Disconnect the digitizer: 步骤 4 中的图像 2,2
    • Use the tip of a spudger to pry up and disconnect the digitizer cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  5. iPhone XR Display Assembly Replacement, Disconnect the display: 步骤 5 中的图像 1,2 iPhone XR Display Assembly Replacement, Disconnect the display: 步骤 5 中的图像 2,2
    • Use the tip of a spudger to disconnect the display cable connector.
  6. iPhone XR Display Assembly Replacement, Unscrew the logic board connector cover: 步骤 6 中的图像 1,2 iPhone XR Display Assembly Replacement, Unscrew the logic board connector cover: 步骤 6 中的图像 2,2
    • Remove the five screws securing the logic board connector bracket to the rear case:
    • One 1.3 mm Phillips #000 screw
    • One 1.5 mm Phillips #000 screw
    • Three 1.2 mm Y000 screws
    • Be careful not to lose the smaller bracket clipped onto the edge. It's secured with a small clip and is easy to accidentally knock off of the larger bracket.
  7. iPhone XR Display Assembly Replacement, Disconnect the front sensors: 步骤 7 中的图像 1,2 iPhone XR Display Assembly Replacement, Disconnect the front sensors: 步骤 7 中的图像 2,2
    • Use the tip of a spudger to pry the front sensor assembly connector up from its socket.
  8. iPhone XR Display Assembly Replacement, Remove the display assembly: 步骤 8 中的图像 1,1
结论
2等其他人完成本指南。
Adam O'Camb
于04/11/15注册
195,355 声望
创作了416篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 636
