当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Before you begin, it's a good idea to test-fit your new battery in the iPhone.
This works best after reinstalling the speaker and Taptic Engine. Refer to the guide you used to remove your old battery.
Make sure the battery connector lines up correctly with its socket on the logic board.
Be careful not to touch the Face ID camera and sensor hardware along the top edge of the iPhone (the "notch" area).
If your test-fit looks good, take the battery back out and place it face-down on your work surface (with the connector contacts facing up).
If your battery came with new adhesive strips already installed, skip to Step 7 .
If you have a two-cell battery, make sure the cells are aligned as they would be when installed in the iPhone.
Peel off the blue plastic liner from your new set of adhesive strips, and discard it.
Some strips have a single large blue liner, while others have a two-piece liner. Either way, peel it all off.
Once the adhesive is exposed, be careful not to touch it.
Once the adhesive sticks to the battery, you can't peel it off or reposition it—if you make a mistake, you'll have to start over with fresh adhesive strips.
Double-check the orientation of the adhesive strips, and make sure your battery is still lying face-down (with the connector contacts facing up).
Carefully position the adhesive strips over the battery, and stick them in place as shown.
Place the strips slightly off-center, very close to the long edge of the battery.
The black pull tabs at each end should protrude equally far over the top and bottom edges of the battery.
Roll your fingertip along the edges of the battery to stick down the black pull tab at the end of each adhesive strip.
Be sure to get all four tabs—three on the bottom edge, and one on the top.
When installing the battery, be careful not to touch the Face ID camera and sensor hardware along the top edge of the iPhone (the "notch" area).
Carefully position the battery and set it into the iPhone.
Make sure the battery connector lines up with its socket on the logic board.
It's okay to temporarily connect the battery to make sure it lines up correctly, but make certain it's disconnected before reassembling your iPhone.
Press the battery firmly onto the adhesive strips to secure it in place.
If your battery came with an additional plastic liner on the top, peel it off and discard it before closing up your phone.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
