跳转到主内容
加入维修社区 - 创建账户
iPhone X SIM Card Reader Replacement
你所需要的
  1. iPhone X SIM Card Reader Replacement, SIM Card Reader: 步骤 1 中的图像 1,3 iPhone X SIM Card Reader Replacement, SIM Card Reader: 步骤 1 中的图像 2,3 iPhone X SIM Card Reader Replacement, SIM Card Reader: 步骤 1 中的图像 3,3
    • The SIM card reader of the iPhone X is soldered with medium-temperature tin, while the middle layer of the motherboard adopts low-temperature tin. Hence we advise you to separate the motherboard before removing the SIM card reader.
    • There are other ICs on the SIM card reader.
    • Besides, a plastic part is also in the middle of the SIM card reader.
  2. iPhone X SIM Card Reader Replacement: 步骤 2 中的图像 1,2 iPhone X SIM Card Reader Replacement: 步骤 2 中的图像 2,2
    • While disassembling and soldering, we need to heat it with rotational air and control the temperature. Attach the motherboard to the PCB Holder. Heat it with a Hot Air Gun at 240℃ and airflow 7. Tear off the sticker on the back of the motherboard.
    • Put the motherboard on the Heating Platform. We only need to heat the SIM card reader part. Fix the motherboard with high-temperature adhesive. Set the temperature of the Heating Platform to 200℃. Heat the edge of the SIM card reader with Hot Air Gun 280℃ and airflow 7.
  3. iPhone X SIM Card Reader Replacement: 步骤 3 中的图像 1,2 iPhone X SIM Card Reader Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Stir the SIM card reader with tweezers while heating. Remove the SIM card reader when it becomes loose. Please be noted that we need to pick up the SIM card reader in a vertical manner.
    • To avoid damage or misposition of components under the SIM card reader avoid prying with tweezers.
  4. iPhone X SIM Card Reader Replacement: 步骤 4 中的图像 1,2 iPhone X SIM Card Reader Replacement: 步骤 4 中的图像 2,2
    • Next, we replace the old SIM card reader with a new one. Apply some Paste Flux to the bonding pad of the SIM card reader.
    • Put the new SIM card reader in position. Keep heating it on the 200℃ Heating Platform. Heat the edge of the SIM card reader evenly with a Hot Air Gun 280℃ and airflow 7. Press the SIM card reader gently while heating. Make sure that the SIM card reader is pressed against the PCB.
  5. iPhone X SIM Card Reader Replacement: 步骤 5 中的图像 1,2 iPhone X SIM Card Reader Replacement: 步骤 5 中的图像 2,2
    • Turn off the power. Cool the motherboard. Check the SIM card reader soldering. The SIM card reader is pressed against the PCB. Every soldering spot has no pseudo-soldering. Solder it again with Soldering Iron if pseudo-soldering happens.
    • Please set the temperature of the Hot Air Gun according to the environment and device brand. The temperature in this article is only for reference.
结论
另外一个人完成了本指南。
REWA
于11/24/20注册
18,669 声望
创作了55篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 17
过去 30 天: 71
总计 4,271
