跳转到主内容
简介
  • The glass lens of the rear camera on your iPhone X is broken.
  • You need to replace this lens because the pictures are fuzzy.
  • To start with, remove the broken fragments of glass and obtain a new lens.
  • Clean the area and attach the new lens with double-sided tape or 2 drops of glue.
  • This simple repair requires care as you must avoid touching the cameras.
  • For safety, use eye-protection glasses in order to avoid any flying glass fragments getting in your eyes.
  1. If the camera glass is broken, remove the broken glass pieces from the camera housing. Remove the broken glass around the camera lens area, then clean the contours of the camera lens area.
    • If the camera glass is broken, remove the broken glass pieces from the camera housing.
    • Remove the broken glass around the camera lens area, then clean the contours of the camera lens area.
  2. Attach the new rear camera glass with adhesive or use two drops of clear superglue on the sides of the camera housing. Position the replacement camera lens in the camera lens area using precision tweezers.
    • Attach the new rear camera glass with adhesive or use two drops of clear superglue on the sides of the camera housing.
    • Position the replacement camera lens in the camera lens area using precision tweezers.
    • Be extremely precise while doing this! You do not want to have to clean up and re-apply the superglue that you may have smeared when you aligned the camera glass wrong!
  3. Apply light pressure on the camera lens to secure the lens glass to the camera housing.
    • Apply light pressure on the camera lens to secure the lens glass to the camera housing.
    • You can now test your rear camera to check the sharpness of your photos and videos.
结论
Congratulations! You have successfully replaced the camera lens on your iPhone X. Clean the lens with a microfiber cloth and you should be able to shoot videos and take pictures normally again.
32等其他人完成本指南。
特别感谢这些译者︰
fr en
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
cPix
于2016年06月14日注册
3,157 信誉积分
创作了8篇指南
It was great to see…
Hizbur Rahman - 回复
It is not that easy because of the tough adhesive. it is impossible to remove the glass without heating it, but be careful the camera lenses got damage of to intensive heat. Better remove the camera before tiny pieces of glass could harm the functionality.
BSlash - 回复
Will the device still be waterproof after this repair? (provided the repair is done correctly)
George Downs - 回复
Bonjour,
Pour information : les iPhone ne sont pas étanches ! Même si les publicités laissent penser le contraire, il faut savoir que les iPhone ne sont pas étanches, pour preuve : il suffit de lire les conditions de garantie de chez Apple qui stipulent bien : “La présente Garantie ne s’applique pas : ... aux dommages causés par un accident,... une exposition à un liquide, au feu, à un tremblement de terre ... “
Donc, que ce soit après une réparation ou avant la réparation, votre iPhone n’est pas étanche, les différents joints “d’étanchéité” présents dans l’iPhone le protège principalement des poussières fines et des petites projections de liquide (genre : micro gouttelettes d’eau) .
Vous pouvez trouver ces joints sur cPix.fr ainsi que les pièces détachées et les outils pour réparer votre iPhone X
Mais n’oubliez pas, il n’est pas étanche ;-)
cPix - 回复
This is the worst repair guide on this website. . Not enough information on this guide to properly do the repair
berningchase - 回复
添加评论
浏览统计数据:
过去的24小时: 105
过去的7天: 639
过去的30天: 2,479
总计 95,553
