跳转到主内容
简介
按照本指南中的步骤来移除或转移您的iPhone X 中的听筒和前传感器组件。组件包括听筒,麦克风,环境光传感器,泛光感应元件和距离感应器。
iPhone 出厂时该组件与手机是一对一配对好的,所以当您更换手机屏幕时应将其从您手机的旧屏幕上转移到新屏幕上。
这包括了用于生物识别安全的泛光感应元件Face ID ,如果这个组件被损坏或被替换的话,您的Face ID就不能再使用了,所以在换屏幕的过程中要格外注意保护这个部件。如果损坏的话,只有苹果官方才可以为其修复。
  1. 开始之前,将iPhone电池放电至25%以下。 充电的锂离子电池如果意外刺破,可能会引起火灾和/或爆炸。
    • 开始之前,将iPhone电池放电至25%以下。 充电的锂离子电池如果意外刺破,可能会引起火灾和/或爆炸。
    • 在开始拆卸之前关闭你的iPhone。
    • 卸下iPhone底部的两颗6.9毫米五角梅花型长螺丝。
    • 如果螺丝滑牙或损坏,更换这些螺丝
    • 拆解iPhone的显示屏将损害其防水密封性。 在执行此步骤之前,请准备好新的密封胶条,或者在不更换密封条的情况下重新组装iPhone,但请不要让iPhone与液体接触。
    There are 6.81mm long screws!
    Daniel - 回复
    One of the pentalobe screws is stripped :( - suggestions for how to get it out?
    cgtyoder - 回复
    same situation here
    kaunomarcius - 回复
    Same issue for me too, how do I get the stripped screw out?
    patrick27leiser - 回复
    Update: I was able to get the “stripped” screw out using another Pentalobe-2 screwdriver bit from another company. It seems it wasn’t the screw, but the screw driver that was actually stripped. Hence why the other screwdriver kit I got came with 3 of this bit, I suppose.
    I ended up going to a jewelry store, and they drilled down into the screw, with of course an incredibly tiny bit. That allowed me to insert the P2 driver, and I was able to unscrew it at that point. Good luck!
    cgtyoder - 回复
    Same issue with the stripping. The tip of the iFixit P2 head in my $70 kit just ground off on the first screw and that was that. Not much you can do.
    Kyle Harris - 回复
    yes correct the same happened to me, the screws were perfect shaped never been open and as soon as i used the P2 it stripped the screws, seems like the P2 is slightly smaller but Dremel kit with a very small drill bits and precise knife tool is the way to go.
    Dulce Vidal - 回复
    Hi, there this is a great informative post that is really shareable to all newbies who are interested in the Guide for the mobile phone repair industry. Really the mobile phone repair blogging is a great way to make money online. Thank you for sharing the post.
    You may know more about iPhone Repair, https://fixnrepair.org/iphone-repair/
    Muhammad Forhad - 回复
    This step in automatically followed through, without any thought. Why remove these screws? Can anybody explain? The Screen is detachable all the same, with them well screwed in…
    Uri - 回复
    These screws attach to a plate that’s part of the screen half of the phone. If you succeed in detaching the screen without removing those, it would seem reasonable that you will have damaged that plate or its ability to keep the two halves together.
    Dan Long -
  2. 加热iPhone的下边缘将有助于软化固定显示器的粘合剂,使其更容易打开。
    • 加热iPhone的下边缘将有助于软化固定显示器的粘合剂,使其更容易打开。
    • 使用吹风机或加热枪或准备一个iOpener,并将其放置到iPhone的下边缘约一分钟,以软化下面的粘合剂。
    General tip regarding heating necessary to remove adhesive:
    consider using a heated tip of a small screwdriver or metal spudger (not the one made of plastic, provided in kit), rather than to heat the device itself.
    Uri - 回复
    You then need to be careful about the temp of the tool which if hot enough can melt plastic components or harm them. Keeping the heat source (heat gun) far enough away from the object that you’ll eventually melt the glue but would be much harder to melt components. I try to keep 4” or 5” gap between the source & object
    Sandman619 -
    Thanks for the info. Could a air convector do the job
    dominique.br - 回复
  3. 接下来的两个步骤演示了iSclack,这是一个我们推荐给经常修理的人的方便工具。 如果您没有使用iSclack,请跳过接下来两个步骤来使用替代方法。 如果塑料深度计连接在iSclack的中心,那么现在就把它取下来 - 对于像iPhone X这样的大型手机来说,并不需要它。
    • 接下来的两个步骤演示了iSclack,这是一个我们推荐给经常修理的人的方便工具。 如果您没有使用iSclack,请跳过接下来两个步骤来使用替代方法。
    • 如果塑料深度计连接在iSclack的中心,那么现在就把它取下来 - 对于像iPhone X这样的大型手机来说,并不需要它。
    • 将吸盘定位在靠近iPhone底部边缘的位置,前部和后部。
    • 将两个吸盘牢固地按到位。
    • 如果您的显示器或后玻璃破裂严重,用透明的包装胶带覆盖它可能会使吸盘粘附。 为此,iSclack还包括两盘胶带。
  4. 牢牢握住iPhone,闭合上iSclack手柄,将屏幕与手机后壳稍微分开。 不要试图完全分离屏幕; 你所需要的是沿着底部边缘开一个小开口。 插入一个撬片到间隙中。
    • 牢牢握住iPhone,闭合上iSclack手柄,将屏幕与手机后壳稍微分开。
    • 不要试图完全分离屏幕; 你所需要的是沿着底部边缘开一个小开口。
    • 插入一个撬片到间隙中。
    • 跳过接下来的两个步骤。
  5. 如果使用单个吸盘,将其应用到手机的底部边缘,同时避免玻璃的弯曲部分。 如果显示器严重破裂,用一层透明的包装胶带盖住可能会使吸盘粘附。 或者,可以使用非常坚固的胶带代替吸盘。 如果其他所有方法均失败,则可以将吸盘粘在破碎的筛子上。
    • 如果使用单个吸盘,将其应用到手机的底部边缘,同时避免玻璃的弯曲部分。
    • 如果显示器严重破裂,用一层透明的包装胶带盖住可能会使吸盘粘附。 或者,可以使用非常坚固的胶带代替吸盘。 如果其他所有方法均失败,则可以将吸盘粘在破碎的筛子上。
    If you were using some form of screen protector, it may come off first as soon as you pull on the suction cup. Do not be alarmed. That is normal behavior.
    Alain-Daniel Wa-Baguma - 回复
    3m VSB double stick tape will stick to the screen when the suction cups fail (see my comment on step 1)
    Tawan Khamapirad - 回复
  6. 牢牢的拉起吸盘,使前面板和后壳之间产生一个微小的间隙。 插入一个撬片到间隙。 将显示器固定到位的防水粘合剂非常牢固; 制造分析需要大量的力量。 如果你很难打开一个缝隙,应用更多的热量,并上下轻轻摇动屏幕,以削弱粘合剂,直到你创建足够的缝隙插入你的工具。
    • 牢牢的拉起吸盘,使前面板和后壳之间产生一个微小的间隙。
    • 插入一个撬片到间隙。
    • 将显示器固定到位的防水粘合剂非常牢固; 制造分析需要大量的力量。 如果你很难打开一个缝隙,应用更多的热量,并上下轻轻摇动屏幕,以削弱粘合剂,直到你创建足够的缝隙插入你的工具。
    In addition to safety goggles, I would recommend you also wear good gloves to avoid getting cut with the glass as you try to pry it open.
  7. 将撬片沿着左下角和iPhone的左侧边缘滑动,将显示屏固定的粘合剂进行切割。 请勿将开口部分太深插入iPhone中,否则可能会损坏内部组件。 请勿将开口部分太深插入iPhone中,否则可能会损坏内部组件。
    • 将撬片沿着左下角和iPhone的左侧边缘滑动,将显示屏固定的粘合剂进行切割。
    • 请勿将开口部分太深插入iPhone中,否则可能会损坏内部组件。
  8. 重新插入您的撬片在iPhone的底部边缘,并向右滑动它继续分离粘合剂。 请勿将插头插入很深,否则可能会损坏iPhone的这一侧的显示屏电缆。 只需将其插入几毫米,即显示器挡板的宽度即可。 请勿将插头插入很深,否则可能会损坏iPhone的这一侧的显示屏电缆。 只需将其插入几毫米,即显示器挡板的宽度即可。
    • 重新插入您的撬片在iPhone的底部边缘,并向右滑动它继续分离粘合剂。
    • 请勿将插头插入很深,否则可能会损坏iPhone的这一侧的显示屏电缆。 只需将其插入几毫米,即显示器挡板的宽度即可。
  9. 显示屏的顶部边缘被胶水和卡扣固定。 沿显示屏的上角滑动撬片,同时朝着Lightning端口的方向向下轻轻拉动或推动显示屏。 如果用力太大,固定显示屏的卡扣会被折断。 请小心操作!
    • 显示屏的顶部边缘被胶水和卡扣固定。
    • 沿显示屏的上角滑动撬片,同时朝着Lightning端口的方向向下轻轻拉动或推动显示屏。
    • 如果用力太大,固定显示屏的卡扣会被折断。 请小心操作!
    • 再次,不要将撬片插入深于显示屏边框的宽度,这样可能会损坏前面板内的传感器。
    • 将撬片滑动到对角,并切掉所有剩余用来固定显示器的粘合剂。
    These are the best instructions I’ve ever read for anything.! Thank you!
    Peter Andrew - 回复
  10. 拉上吸盘上的小凸起,将其从前面板上取下。
    • 拉上吸盘上的小凸起,将其从前面板上取下。
    • 如果您使用了iSclack,而且它仍粘贴在iPhone上,请立即将其取下。
  11. 从iPhone显示屏的左侧向上打开iPhone,就像面对书本底部时,翻开最后一页一样。 不要试图将屏幕和手机完全分开,因为几条易碎的连接线任然与iPhone的控制板连接着。 如图所示,保证屏幕的框架也和屏幕一起拆开,而不是还卡在手机里。
    • 从iPhone显示屏的左侧向上打开iPhone,就像面对书本底部时,翻开最后一页一样。
    • 不要试图将屏幕和手机完全分开,因为几条易碎的连接线任然与iPhone的控制板连接着。
    • 如图所示,保证屏幕的框架也和屏幕一起拆开,而不是还卡在手机里。
    • 在重新组装过程中,将显示器放置到位,沿着顶部边缘对齐夹子,然后小心地将顶部边缘压入到位,然后将其余部分向下收紧。 如果不能轻松安装到位,请检查显示器周边的夹子状况,确保它们没有弯曲。
    My phone came apart in a different way and looks not right the little box at the top of the display as actually bolted to the top of the frame body I think something went really wrong when I opened it.
    Mike Kostersitz - 回复
    It opens like a book but be careful not to open it all the way — only as far as shown in the photo. Otherwise it will strain the thin cable that connects the sensor module and then no more FaceID for you (or, as it turns out me). This could have been made more explicit in the instructions.
    Richard Tucker - 回复
    It opens like a book but be careful not to open it all the way  … the small stainless steel tabs that hold the screen around the metal frame, that are on the bend place (right side of the phone)… are tend to bend, you can straighten them back to 90 deg. but the plastic base that they are on? very fragile- watch out not to break the plastic bezel … it may come apart of the glass.
    dabur872 - 回复
  12. 拧出固定逻辑板支架的5个符合以下长度Y000规格的螺丝
    • 拧出固定逻辑板支架的5个符合以下长度Y000规格的螺丝
    • 3个1.1mm的螺丝
    • 1个3.1mm的螺丝
    • 1个3.7mm的螺丝
    • 做这步的时候,注意记住每个螺丝位置并在安装的时候准确的拧回去,因为这保护你的摄像头不被破坏。
    One thing I found helpful for replacing the screws was to use only the 000screwdriver tip, without the handle. This way, the tip isn’t magnetized and the screw doesn’t tend to ‘roll’ off the screwdriver tip (the screw has almost no mass, so the head (largest surface) is pulled around to the side of the screwdriver tip when magnetized).
    Rich May 23, 2020
    ungodly - 回复
    My 3.1mm screw had a stripped head, could not remove it. (Factory defect, this iPhone was never opened)
    So I had to give up removing the display assembly, and jumped directly to battery replacement, Step 20.
    That was tricky as I had to keep the display at 90º with a risk of breaking display connectors, but hopefully the replacement went well.
    I would not recommend to do this but to follow the guide, but, in case someone encounters a similar issue, that could help!
    vingu - 回复
    My 1.1mm screw had a stripped head. Used a 3mm steel drill to cut the head off (just 1 mm deep haha) so i could remove the bracket.
    Renout v Oijen - 回复
  13. 移除后盖
    • 移除后盖
    • 后盖可能会轻轻在粘连着,用稳定并缓慢的力度将其分开。
    • 在你装回去的过程中,在屏幕密封之前这是一个测试你的iPhone是否功能完好的好机会,但要注意在测试完后一定要关机后才能继续进行下一步哦。
    I tested it, then proceeded to close up the device without the bracket. Do I need to reopen and install? All connections are good?
    monastra7 - 回复
    The bracket helps those many connectors underneath maintain good contact. Probably in the short term nothing bad will happen, but I’d hang onto the bracket and reinstall it when convenient.
    Jeff Suovanen -
    Agree with Jeff
    cgtyoder -
  14. 用撬棍的尖端或干净的指甲去撬开电池与逻辑板的连接 尽量不要损伤在逻辑板或其他板周围的黑色硅脂,这是用来加强防水防尘能力的
    • 用撬棍的尖端或干净的指甲去撬开电池与逻辑板的连接
    • 尽量不要损伤在逻辑板或其他板周围的黑色硅脂,这是用来加强防水防尘能力的
    • 轻轻挑开那个接口,避免逻辑板意外的连到电池上接通手机的电源
    cosa può succedere se non si disconnette la scheda logica'?
    luca.valli - 回复
    note: be careful not to crush or puncture your battery at this step!! I gave mine a minor dent, which I hope wont be a problem.. but something to keep in mind for fxlks in the future!
    Noal Balint - 回复
  15. 用撬棍或者指甲来断开前面板传感器的连接 用撬棍或者指甲来断开前面板传感器的连接
    • 用撬棍或者指甲来断开前面板传感器的连接
  16. 使用撬棒的尖端或手指甲来撬开OLED面板排线的插头。 想要重新连接这种按压型插头,先将插头的一侧对准位置轻轻按压到位,然后在另一侧重复操作。切忌从中间按压插头。如果插头没有对准位置就对其进行按压的话,插头的触脚会被折弯,会对插头插座造成永久性的损坏。
    • 使用撬棒的尖端或手指甲来撬开OLED面板排线的插头。
    • 想要重新连接这种按压型插头,先将插头的一侧对准位置轻轻按压到位,然后在另一侧重复操作。切忌从中间按压插头。如果插头没有对准位置就对其进行按压的话,插头的触脚会被折弯,会对插头插座造成永久性的损坏。
    Snap ‘em in like little Legos.
    Ray Johnson - 回复
    Maybe the manual should flip step 17 and 18 (as the digitizer cable from 18, is in the way of the OLED cable of step 17) ?
    Renout v Oijen - 回复
  17. 使用Spudger撬棒的尖端将数据排线的插头从插座撬开。 这个插头所处于的隐蔽位置使其不容易重新连接上。要花点时间小心地将其对准位置,然后用你的手指先轻轻地将其一侧按压到位,然后是另一侧。你可以感觉得到它卡在正确的位置。
    • 使用Spudger撬棒的尖端将数据排线的插头从插座撬开。
    • 这个插头所处于的隐蔽位置使其不容易重新连接上。要花点时间小心地将其对准位置,然后用你的手指先轻轻地将其一侧按压到位,然后是另一侧。你可以感觉得到它卡在正确的位置。
    • 如果维修完后发现屏幕有任何触摸失灵的部位,请先断开电池连接然后重新连接这个插头,确保其完整的卡在了正确的位置,并且插座里没有灰尘或其他的损坏。
    This was probably the hardest part other than trying to get the screen off with the crappy suction cups. I re-installed the bracket only the find out that the touch screen would not respond to touch. Had to remove the five screws, remove the bracket and reseat the recessed screen connector. Reseating the bracket took another 10+ minutes. I carefully used the angled forceps to grab the cable and align the connector being careful not to damage the cable.
    Once you have the connector seated, I would reconnect the battery, power on the phone, and check the touch screen response before re-installing the bracket (step 13).
    Yeah, this was probably the trickiest part of the reassembly. The power connector cable kept getting in the way so I moved it carefully but fully out of the way. Then it was a matter of fiddling around with it a bit and being careful not to force it on.
    Jeffrey Hoy -
  18. 前面板传感器组弯折型的排线在这里被一点点粘胶粘住了。 小心地提起排线直到粘胶被分离。 小心地提起排线直到粘胶被分离。
    • 前面板传感器组弯折型的排线在这里被一点点粘胶粘住了。
    • 小心地提起排线直到粘胶被分离。
    Do this sensor affect face id?
    bonglkv - 回复
    It is part of the face id part so yes. This is the ear piece too so if the ribbon tears there is a chance the ear piece will stop working as well.
    Stephen Patterson - 回复
    Be super careful handling this ribbon particularly. I did a battery install and, when I was done, I had a phone with a new battery and no Face ID. That’s a $300 Apple repair, and no 3rd party shop will touch it. I believe the ribbon lays vertically (i.e., perpendicular to the “floor” of the phone, against the side edge of the battery. During the re-install, I must have forced the ribbon into position after seating the connector, causing fatal flexing of the ribbon. (Don’t know this for sure, but I see another comment saying that this cable is part of Face ID.) Anyway, bottom line: BE CAREFUL REMOVING AND REINSTALLING THIS RIBBON!
    Jonathan Pines - 回复
  19. 移除屏幕组件。
    I tried this and broke the cable can it still repair
    Alexis Rodriguez - 回复
    At this point I would have found it easier to remove the glue from the edges than later on when I was reassembling it. I bought the kit that had the replacement glue in it.
    Grant - 回复
  20. 移除屏幕总成后红外镜头旁的1.2 mm Y型螺丝。
    • 移除屏幕总成后红外镜头旁的1.2 mm Y型螺丝。
    Not sure as of what to do now, I have stripped this screw.
    Kelvin - 回复
    It might be your driver tip that is no good. Try a new driver tip Y000
    carol - 回复
    when I opened my iPhone the screw was already stripped, I had the phone once at an Apple store for repair about 2 years ago. Had not opened it in between so it seems they stripped the screw there or it came like that from the factory. Any ideas? I don’t want to try and force it out.
    Be careful: the metal clip beneath this screw it’s really small, make sure not losing it.
    Luca Ciprian - 回复
  21. 在您刚移除的螺丝下有一个小的圆环金属片。如果刚才拧下螺丝时金属片没有掉下,请将其移除。 重新组装的过程中,请将金属片放平(如图所示),将金属片对准位置并保持住,然后将螺丝从中穿过并拧紧。 重新组装的过程中,请将金属片放平(如图所示),将金属片对准位置并保持住,然后将螺丝从中穿过并拧紧。
    • 在您刚移除的螺丝下有一个小的圆环金属片。如果刚才拧下螺丝时金属片没有掉下,请将其移除。
    • 重新组装的过程中,请将金属片放平(如图所示),将金属片对准位置并保持住,然后将螺丝从中穿过并拧紧。
    sin ese clip la señal wifi se recibe a duras penas
    Harizola Taberna Margari - 回复
    Is there a way to just buy the gold grounding clip because my phone cannot search for wifi anymore!
    Anonymous - 回复
    Is there any way we buy the ground metal clip separately please if there’s a way to get it emailed me
    Sisthanu Iman - 回复
    Reinstalling this clip + screw is super hard =P
    Josh Estelle - 回复
  22. 移除另外两个保护听筒+传感器总成的Y型螺丝:
    • 移除另外两个保护听筒+传感器总成的Y型螺丝:
    • 一个1.6mm螺丝
    • 一个1.3mm螺丝
    What do you do if the 1.6mm tripoint screw won’t come out…? I think it may be stripped :(
    Salvatore Boenzi - 回复
    You could try using an old screwdriver & carefully adding a dab of superglue to the screw to attach it to the screwdriver, Then the screw may come out, Superglue’s strength is holding 2 pieces together when the stress point is pulling the 2 pieces away from each other. Superglue becomes surprisingly easy to break when twisting the 2 pieces. So be careful since the rotation of the screw will put the stress point at the weakest of the glue’s strength.
    Sandman619 - 回复
    I would suggest:
    1. Try a small precision flat head, a good quality one, I bought some that were supposed to be to remove stripped screws, about 20-30 bucks for 4 or 5 of them, and they have saved my butt many times.
    2. I have been able to remove stripped screws with wire cutters. Or you can try some vamp pliers but they are probably too large for this situation.
    3. If the last two fail, the course of action is to basically destroy the head of that screw (assuming you are removing the stuff you need for your new lcd, which is very likely) they have drill bits called easy outs or screw removing drill bit, which is a drill bit with the spiral going the opposite direction (for a screw that tiny you can take a small drill bit, cut and sharpen the end that normally has no spiral, I have made that work in the past) the point is that as you drill in, the drill bit is digging and moving counterclockwise, so at some point as it digs in it will get “stuck” and keep spinning go the screw, thus removing it.
    Victor Miranda - 回复
  23. 听筒被一点粘胶粘在这里。 使用一个撬棒,轻轻将听筒组件从其上端撬起,然后将其翻过来远离屏幕上端。
    • 听筒被一点粘胶粘在这里。
    • 使用一个撬棒,轻轻将听筒组件从其上端撬起,然后将其翻过来远离屏幕上端。
    • 听筒剩余的部分连接在一个非常薄的弯折型排线上。注意不要损伤排线。
    i damage the cable, where can i buy a replacemnt
    Haoyu Li - 回复
  24. 使用一个吹风机或加热风枪或准备一个iOpener,加热屏幕前部的顶端大约一分钟,来软化用于保护传感器的粘胶。
    • 使用一个吹风机或加热风枪或准备一个iOpener,加热屏幕前部的顶端大约一分钟,来软化用于保护传感器的粘胶。
  25. 使用撬棒的平直端小心的在麦克风下的排线的下面划动。 轻轻转动撬棒来将麦克风分离,小心不要损坏排线。 如果需要的话,使用撬棒的尖端将麦克风从前面板上的圆形切口中分离。
    • 使用撬棒的平直端小心的在麦克风下的排线的下面划动。
    • 轻轻转动撬棒来将麦克风分离,小心不要损坏排线。
    • 如果需要的话,使用撬棒的尖端将麦克风从前面板上的圆形切口中分离。
  26. 使用一个三角拨片在排线和距离感应器+泛光感应元件下从左往右划动。 轻轻摆动并提拉模组来将其与前面板上的开孔分离。 提起听筒有助于上面的操作。注意不要使排线受到很大拉力。
    • 使用一个三角拨片在排线和距离感应器+泛光感应元件下从左往右划动。
    • 轻轻摆动并提拉模组来将其与前面板上的开孔分离。
    • 提起听筒有助于上面的操作。注意不要使排线受到很大拉力。
    i can i purchase this part
    M. Brown - 回复
  27. 使用镊子轻轻扭动环境光传感器来将其从屏幕开孔中提起。 传感器剩余的部分和剩下的传感器组通过一个很薄的弯折型排线连接。小心不要损伤排线。
    • 使用镊子轻轻扭动环境光传感器来将其从屏幕开孔中提起。
    • 传感器剩余的部分和剩下的传感器组通过一个很薄的弯折型排线连接。小心不要损伤排线。
  28. 如果您成功的移除了整个环境光感应器(如图一所示),请继续下一步。 如果传感器上的白色柔光条脱落并残留在屏幕上(如图二所示),您需要使用一个薄的刀片或撬棒从屏幕的上缘小心地将其撬出。提前重新加热可能会使其更容易操作。 重新组装的过程中,请先将柔光条安装到屏幕上,确保其面对正确的方向(朝前的一面如图一所示,朝后的一面如图三所示)。
    • 如果您成功的移除了整个环境光感应器(如图一所示),请继续下一步。
    • 如果传感器上的白色柔光条脱落并残留在屏幕上(如图二所示),您需要使用一个薄的刀片或撬棒从屏幕的上缘小心地将其撬出。提前重新加热可能会使其更容易操作。
    • 重新组装的过程中,请先将柔光条安装到屏幕上,确保其面对正确的方向(朝前的一面如图一所示,朝后的一面如图三所示)。
    • 然后将环境光感应器安装到柔光条上。当您安装固定听筒+传感器组的螺丝时您需要保持住传感器正确的位置。当螺丝拧紧时,传感器就会固定到正确的位置并能正常工作。
    quá rõ ràng, cảm ơn ifixit
    Dang Tuan - 回复
  29. 移除听筒+前传感器组件。 重新组装的过程中,请检查包含以下元件的黑色塑料模组的位置: 距离感应器
    • 移除听筒+前传感器组件。
    • 重新组装的过程中,请检查包含以下元件的黑色塑料模组的位置:
    • 距离感应器
    • 泛光感应元件
    • 模组必须对准该位置以避免以上元件被周围的粘胶遮盖。
    there was no bracket on my new screen I purchased from here.. am I supposed to heat up and remove the old one, or was their supposed to be one on the new screen ??
    0perationguttertech - 回复
    @br0k3nilluzion If your new display didn’t come with a front camera frame, you can (and should) remove the old one from your broken display and transfer it over. Use heat and careful wiggling/prying to remove it—and if it’s stubborn, add a few drops of isopropyl alcohol. Hope this helps!
    Jeff Suovanen - 回复
    Does face-id stop working if the black plastic separates from the flex(The orange and red dot)?
    tharshan91 - 回复
    If the black plastic piece with the flood illuminator and the proximity sensor is separated from the flex cable, then Face ID will definitely not work. Be very careful not to damage any of the parts in the front sensor assembly.
    Adam O'Camb -
    There is some sort of a tape in front of the flood illuminator which is not present on the replacement screen! Is that gonna cause a problem too?
    BTW, it’s so difficult to position the front camera frame without glue. I guess it takes a few attempts of trial and error!
    shoeib - 回复
    It might not cause any major problems, but there’s a chance that it could effect FaceID functionality. If possible, transfer the tape from the old screen to the new one.
    Adam O'Camb -
    I find it better, regardless of if your new screen comes with the transparent front camera frame, to remove the front sensor assembly from the old screen with the frame, and lifting up the whole assembly using the frame. That way you do not need to apply heat directly to the fragile assembly, but apply it to the other side, the front of the screen at the top, instead, to soften the frame adhesive. The frame is then usually easy to pry loose using a narrow spudger, and comes off cleanly. After that it is much easier to remove the sensors and microphone from the frame, no heat needed usually. And if your new screen doesn’t come with the frame, just plonk the whole frame/sensor assembly down in the right place, and boom, Bob’s your uncle.
    Lars - 回复
    Hello I have an iPhone X i Bought it in 2019 with Face ID not working ( not available try later ) I think the screen was changed with another original , tru tone Off , Als off no auto brightness (and the PROXIMITY SENSOR too ! ) no black screen in calls, i would like to ask u if the earpiece speaker flex was changed with another one (all components ) not the original , did proximity sensor still work ?? Because I don’t know is the original flex of my iphone or not ? I found some scratches in the flex it appears to have small cut so I don’t know the PROXIMITY SENSOR not working because there are a small cut in the flex or because the flex is not the same ?? And if the flex is not the original it can disable (proximity sensor)too not only flood and als ?? Thank you
    Ach - 回复
    Yes it should still work. If you change the assembly to one that isn’t original to that iPhone X everything except the FaceID should still work - I have done so several times for clients. So the reason for yours not working is probably the same small scratches and cuts you have seen. The cable is a bit fragile and some of the copper leads running through it are extremely thin.
    Lars -
    To keep True Tone function on the replacement screen you’ll need a chip data programmer EEPROM to copay data from the old screen onto the new one. There a device called JC-V1 which should do the trick.
    Yousef Ghalib - 回复
    Screen glitching slightly after changing the screen. Any suggestion to what it can be?
    Tim Morell - 回复
    Tim. I had a glitchy screen as well. It would force touch out of nowhere, and “ghost touch” every now and then. Eventually, the top half of the screen stopped responding. Reach out to customer service ASAP. You may have a defective screen.
    Alex Hurtado -
    My front ear speaker not working . The mic it’s working . Apple said you have to replace all the screen to fix the ear speaker because it’s connected with one cable all together. If I buy the speaker and change it myself it will work after or I’m getting into trouble?
    josh - 回复
    I have the same problem. I have the same problem. how did you solve?
    xX_Sn4k3x_Xx - Official -
    Be sure to remove the blue protective film from the BACK of a replacement screen.
    Jim Breef - 回复
    can this piece assembly cause for the back camera and flashlight not work? All I did was change the screen and transfer this earpiece and it says warning sign that the flashlight needs to cool down and back camera not working
    Dulce Vidal - 回复
    disregard my last post, problem solved on my end customer had a bad back camera due to bad fall and so i replaced it and now the back camera and flashlight works. :)
    Dulce Vidal - 回复
    Hello I replaced today the second time iphone x display. The first time after a while the front camera stopped working. Today mounted the second time the display and the front camera works, while the rear one does not work. What can I do? Thanks
    Mimmo Cordola - 回复
结论
将你用于更换的备件和之前的备件进行对比
-- 你可能需要将备件的剩余部分从之前的备件转移过来,或是在安装新备件之前清理干净粘胶。
“请倒序进行上述的步骤来重新组装你的设备。”
将你的电子垃圾丢弃到 R2 or e-Stewards certified recycler.
维修进行得不顺利?看看Answers community 能不能帮到你。
76等其他人完成本指南。
特别感谢这些译者︰
en zh
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Adam O'Camb
于2015年04月11日注册
135,296 信誉积分
创作了392篇指南
团队
iFixit iFixit 的会员
Community
137 名成员
创作了16,049篇指南
Is it possible to fix the ““Face ID Is Not Available” problem? There seems to be a problem with the TrueDepth camera. Thanks!
Alejandro D - 回复
@alejandrod I’m afraid Face ID won’t work if this part is replaced. As stated in the introduction, this component is paired to the logic board from the factory (similar to the home button on earlier iPhones). Currently, if you need to replace this part, you’ll have to sacrifice Face ID, or else pay Apple directly to perform the repair. (They have a software calibration tool that pairs the new part to your phone to re-enable Face ID, but they don’t share it with anyone outside of Apple.)
Jeff Suovanen -
The flex cable was too bent, and now is broken. I’m going to buy another flex cable, but… Are there any ways to recover the Face ID functionality? Desoldering some components from the old one and weld them in the new flex cable?
Andrea Giacon - 回复
Flex cables can be repaired by a skilled microsolderer. It’s not a DIY however. If it’s a phone you care about, you’ll want to find yourself a good repair shop with the right equipment and skills. Apple can also repair it, but they will most likely just charge you $279 to replace the entire screen.
Jeff Suovanen -
My proximity sensor is defective and puts my phone in a boot loop when connected. To replace that, would I need to use a skilled microsolderer to replace that?
oosaghae - 回复
My earpiece is broken would replacing mean that I’m sacrificing Face ID?
Mujtaba Suhrawardy - 回复
Just did mine, and yes, my face ID doesn’t work anymore.
Dane Frederick -
Hey does anyone know what’s wrong with my Iphone X. I thought I had a blown ear speaker. So I just replaced the assembly, but after reassembling it doesn’t sound any different. Anyone speaking is extremely quiet. And yes my Bluetooth is off, no I don’t have any headphones in it. and the volume is all the way up. Any other ideas what is happening? It has been a major inconvenience to have to put everyone on speaker phone just to talk to them.
Dane Frederick - 回复
Have you checked the speaker grille/mesh to make sure it’s clean? They can get clogged with pocket lint over time, blocking sound from the speaker.
Jeff Suovanen -
شكرا علي كلشيء
Corva Loco - 回复
Hi All,
I replaced the screen on the iPhone X and now the camera and face ID don’t work. The camera app is black when I open it. I can’t test the proximity sensor because there is no cell service on the phone. I assumed I damaged the flex cable so I put a new one in and same result.
I put the original flex back on the original screen and same result. I am not sure if face ID or the camera was working before the repair. I normally check what is working and what isn’t, but I forgot to this time.
Thanks!
Mitch - 回复
Hey i was repair my iphone x battery when this broke off. i bought a new earpiece thing and the sensor part but i heard that apple pairs specific parts to the logic board so if i replace it will the mic still work?
Mak - 回复
I lost the screw and grounding clip. Your step 21, “Beneath the screw you just removed lies a small metal grounding clip. “ Any ideal where I can get the screw and grounding clip?
Melvin Hamill - 回复
Your step 21, “Beneath the screw you just removed lies a small metal grounding clip. “ I have lost the screw and grounding clip. Any ideal where I can find the screw and grounding clip/
Thank you
MEL
Melvin Hamill - 回复
I have replaced the battery, the dock connector and this component and I forgot to install the grounding clip while closing the phone. Now everything works expect the charging; the phone recognizes the charger as an accessory but it does not charge at all. It charges only if it is not powered on (without showing any charging symbol, by the way). Do you know if this might be due to this missing grounding clip? Thanks!
Andrea Giammanco - 回复
Hola, con este proceso mi face id dejará de funcionar?
Saludos desde México!
Horlando Anzures Quiroz - 回复
Correcto, no funcionará
Terranova -
Si el Face ID deja de funcionar.
Terranova - 回复
What adhesive do you recommend for reattaching the earpiece speaker on to the replacement display?
mcvtech - 回复
I have iPhone X and the ear speaker not working. But I have one more iPhone X with cracked screen. Can I remove the ear speaker from the second  iPhone and replace it to my iPhone? Is the Face ID will work after if it’s original Apple part?
josh - 回复
添加评论
浏览统计数据:
过去的24小时: 133
过去的7天: 854
过去的30天: 3,554
总计 122,750
