跳转到主内容
iPhone X 听筒+前传感器组件的替换
你所需要的
  1. iPhone X 听筒+前传感器组件的替换, 防撬螺丝: 步骤 1 中的图像 1,1
    • 开始之前,将iPhone电池放电至25%以下。 充电的锂离子电池如果意外刺破,可能会引起火灾和/或爆炸。
    • 在开始拆卸之前关闭你的iPhone。
    • 卸下iPhone底部的两颗6.9毫米五角梅花型长螺丝。
    • 如果螺丝滑牙或损坏,更换这些螺丝
    • 拆解iPhone的显示屏将损害其防水密封性。 在执行此步骤之前,请准备好新的密封胶条,或者在不更换密封条的情况下重新组装iPhone,但请不要让iPhone与液体接触。
    There are 6.81mm long screws!
    Daniel - 回复
    One of the pentalobe screws is stripped :( - suggestions for how to get it out?
    cgtyoder - 回复
    same situation here
    kaunomarcius - 回复
    Same issue for me too, how do I get the stripped screw out?
    patronics - 回复
    Update: I was able to get the “stripped” screw out using another Pentalobe-2 screwdriver bit from another company. It seems it wasn’t the screw, but the screw driver that was actually stripped. Hence why the other screwdriver kit I got came with 3 of this bit, I suppose.
    patronics - 回复
    I ended up going to a jewelry store, and they drilled down into the screw, with of course an incredibly tiny bit. That allowed me to insert the P2 driver, and I was able to unscrew it at that point. Good luck!
    cgtyoder - 回复
    Same issue with the stripping. The tip of the iFixit P2 head in my $70 kit just ground off on the first screw and that was that. Not much you can do.
    Kyle Harris - 回复
    yes correct the same happened to me, the screws were perfect shaped never been open and as soon as i used the P2 it stripped the screws, seems like the P2 is slightly smaller but Dremel kit with a very small drill bits and precise knife tool is the way to go.
    Dulce Vidal - 回复
    This step in automatically followed through, without any thought. Why remove these screws? Can anybody explain? The Screen is detachable all the same, with them well screwed in…
    Uri - 回复
    These screws attach to a plate that’s part of the screen half of the phone. If you succeed in detaching the screen without removing those, it would seem reasonable that you will have damaged that plate or its ability to keep the two halves together.
    Dan Long -
    @Dan Long is right
    Uri -
    Clean out the pentalobe screw heads first so the tool goes all the way in. A small sewing needle works well to loosen any build up and then press some putty/chewing gum into the screw head and pull away quickly for a final clean out.
    William Olstad - 回复
    The this kit should include screws because you’re going to strip them. Can’t even get past step one. Did anybody figure this out
    justin - 回复
    Never opened my phone ever, when I went to look at the first step.. I noticed one of my screws was stripped. I thought it was impossible, but I removed the non stripped one, then once I got to the stripped one.. I learned my assumptions were correct. I bought this one straight from the apple site years ago ahaha Any tips to remove the stripped screw?
    Clarence Williams - 回复
    William Olstad's tip about cleaning the screws with a needle and a bit of poster putty worked well for me. There was a lot of crud in there! The opening is shallow, so it's easy to see how the screwdriver wouldn't catch with even a bit of grit in the way, No problem getting the pentalobe screws out with the ifixit screwdriver.
    punkinann - 回复
    If all else fails, very carefully cut a slot across the head of the screw with a Dremel tool using a diamond bit that dentist will gladly give you - I ask my dentist for used bits; and chuck them in a drill bit chuck designed for Dremel. The slot allows you to use a tiny, straight blade screwdriver. You can reuse the screw or replace it with a new pentalobe screw.
    Dan Smith - 回复
  2. iPhone X 听筒+前传感器组件的替换, 标记你的三角撬片: 步骤 2 中的图像 1,3 iPhone X 听筒+前传感器组件的替换, 标记你的三角撬片: 步骤 2 中的图像 2,3 iPhone X 听筒+前传感器组件的替换, 标记你的三角撬片: 步骤 2 中的图像 3,3
    • 如果插入太深,三角撬片可能会损坏你的设备。 按照此步骤标记撬片并防止损坏。
    • 从尖端测量 3 毫米,并用永久性记号笔标记三角撬片。
    • 你还可以用不同的尺寸标记三撬片的其他角。
    • 或者,将 将一枚硬币 粘在距撬片尖端 3 毫米处。
  3. iPhone X 听筒+前传感器组件的替换, 用胶带覆盖任何裂缝: 步骤 3 中的图像 1,3 iPhone X 听筒+前传感器组件的替换, 用胶带覆盖任何裂缝: 步骤 3 中的图像 2,3 iPhone X 听筒+前传感器组件的替换, 用胶带覆盖任何裂缝: 步骤 3 中的图像 3,3
    • 如果你的 iPhone 屏幕破裂,请在维修过程中用胶带粘住玻璃,以遏制进一步的破损并防止人身伤害。
    • 将透明胶带条重叠地放在 iPhone 屏幕上,直至覆盖整个表面。
    • 佩戴护目镜,以保护您的眼睛免受维修过程中晃动的玻璃的伤害。
    • 如果在接下来的几步中无法让吸盘粘住,请将一块强力胶带(例如管道胶带)折叠成手柄状,然后用它抬起屏幕。
    • 如果其他方法都失败,你可以将吸盘粘到屏幕上。
  4. iPhone X 听筒+前传感器组件的替换, 反向钳使用指南: 步骤 4 中的图像 1,3 iPhone X 听筒+前传感器组件的替换, 反向钳使用指南: 步骤 4 中的图像 2,3 iPhone X 听筒+前传感器组件的替换, 反向钳使用指南: 步骤 4 中的图像 3,3
    • 接下来的两个步骤演示了如何使用反向钳,一个旨在简化打开过程的工具。 如果你不使用 反向钳,请跳过这两个步骤以使用替代方法。
    • 有关如何使用 反向钳的完整说明,请查看本指南
    • 向后拉蓝色手柄以解锁反向钳臂。
    • 将支撑臂滑过 iPhone 的左边缘或右边缘。
    • 将吸盘放置在 iPhone 底部边缘附近 - 一个位于正面,一个位于背面。
    • 将吸盘挤压在一起,对所需区域施加吸力。
    • 如果发现设备表面太光滑而反向钳无法吸住,你可以使用胶带来创造一个更容易抓握的表面。
  5. iPhone X 听筒+前传感器组件的替换: 步骤 5 中的图像 1,3 iPhone X 听筒+前传感器组件的替换: 步骤 5 中的图像 2,3 iPhone X 听筒+前传感器组件的替换: 步骤 5 中的图像 3,3
    • 向前拉蓝色手柄以锁定手臂。
    • 顺时针旋转手柄 360 度或直到吸盘开始拉伸。
    • 确保吸盘彼此保持对齐。 如果它们开始滑出不对齐,请稍微松开吸盘并重新对齐手臂。
  6. iPhone X 听筒+前传感器组件的替换: 步骤 6 中的图像 1,3 iPhone X 听筒+前传感器组件的替换: 步骤 6 中的图像 2,3 iPhone X 听筒+前传感器组件的替换: 步骤 6 中的图像 3,3
    • 加热 iOpener 并将其穿过反向钳。
    • 你还可以使用吹风机热风枪或电热板,但过热可能会损坏显示屏和/或内部电池,因此请小心操作。
    • 折叠 iOpener,使其位于 iPhone 的底部边缘。
    • 等待一分钟,让粘合剂有机会释放并出现开口间隙。
    • 在屏幕和塑料边框下方插入三角撬片,而不是屏幕本身
    • 如果反向钳无法形成足够的间隙,请对该区域施加更多热量并将手柄旋转四分之一圈。
    • 反向钳一次不要超过四分之一圈,两次之间要等待一分钟。让反向钳和时间来为你工作。
    • 跳过接下来的两个步骤。
    DO NOT separate the glass from the plastic bumper or rim around it. These instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body. It is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - 回复
    Thanks for pointing this out! I'll revise this step to clarify this point.
    Arthur Shi -
  7. iPhone X 听筒+前传感器组件的替换: 步骤 7 中的图像 1,1
    • 加热iPhone的下边缘将有助于软化固定显示器的粘合剂,使其更容易打开。
    • 使用吹风机或加热枪或准备一个iOpener,并将其放置到iPhone的下边缘约一分钟,以软化下面的粘合剂。
    General tip regarding heating necessary to remove adhesive:
    consider using a heated tip of a small screwdriver or metal spudger (not the one made of plastic, provided in kit), rather than to heat the device itself.
    Uri - 回复
    You then need to be careful about the temp of the tool which if hot enough can melt plastic components or harm them. Keeping the heat source (heat gun) far enough away from the object that you’ll eventually melt the glue but would be much harder to melt components. I try to keep 4” or 5” gap between the source & object
    Sandman619 -
    Thanks for the info. Could a air convector do the job
    dominique.br - 回复
    When opening a device that has previously been worked on, and on which the adhesive might not have been replaced, be extremely carful when opening the phone. It will open much more easily than expected. If you’re not careful you might rip a cable.
    jonpol - 回复
    Is this tool required or can I just use the Anti-Clamp by itself.
    Mikail - 回复
    If you have a 3d printer, heat the bed to 80c and put the phone screen side down on it for 30 secs
    philip.joseph123 - 回复
  8. iPhone X 听筒+前传感器组件的替换: 步骤 8 中的图像 1,2 iPhone X 听筒+前传感器组件的替换: 步骤 8 中的图像 2,2
    • 如果使用单个吸盘,将其应用到手机的底部边缘,同时避免玻璃的弯曲部分。
    If you were using some form of screen protector, it may come off first as soon as you pull on the suction cup. Do not be alarmed. That is normal behavior.
    Alain-Daniel Wa-Baguma - 回复
    3m VSB double stick tape will stick to the screen when the suction cups fail (see my comment on step 1)
    Tawan Khamapirad - 回复
  9. iPhone X 听筒+前传感器组件的替换: 步骤 9 中的图像 1,3 iPhone X 听筒+前传感器组件的替换: 步骤 9 中的图像 2,3 iPhone X 听筒+前传感器组件的替换: 步骤 9 中的图像 3,3
    • 牢牢的拉起吸盘,使前面板和后壳之间产生一个微小的间隙。
    • 将撬片插入屏幕塑料边框下方的缝隙中,而不是屏幕本身
    • 将屏幕固定到位的防水粘合剂非常牢固; 创造这个初始间隙需要很大的力量。 如果你很难打开间隙,请施加更多热量,然后轻轻地上下摇动屏幕以削弱粘合剂,直到形成足够的间隙以插入工具。
    In addition to safety goggles, I would recommend you also wear good gloves to avoid getting cut with the glass as you try to pry it open.
    The top about applying more heat and gently rocking the screen up and down to weaken the adhesive did the trick for me. Thank you!
    Monil Shah - 回复
    There needs to be more clarity on where to shove the opening pick into. There is actually two openings that the pry tool can be forced into: one below the black plastic bezel, and one above the black plastic bezel. When I heated my screen with a warming pad and pulled up the suction cup, it actually pried apart above the black plastic bezel which removed the touch screen from the display panel. With this being the first newer iPhone I'd opened since the 3GS, I didn't realize that I was opening the wrong opening as the directions only mentioned one opening and did not warn of this. I was pretty disappointed in the lack of mentioning this, as I was taking my time and following it to the tee. As a result, it destroyed my original iPhone screen.
    Caleb Davison - 回复
    DO NOT separate the glass from the plastic bumper or rim around it. As someone else noted, these instructions don't clarify that the pick has to be inserted between the plastic rim and the metal body of the phone. When pulling upwards with the suction cup, it is likely that the glass will lift slightly off the plastic surround before the plastic will lift out of the metal body. I had success sliding a card or pick back and forth along the bottom edge of the plastic rim while pulling on the suction cup. Eventually there was a space large enough for the pick to go under the plastic rim.
    Anessa - 回复
    Thank you for pointing this out! I've updated the step to reflect this.
    Arthur Shi -
    The suction cup doesn't work at all... The minimum force I apply to lift it up, it comes off completely. This is very frustrating!!!
    Mario Silva - 回复
  10. iPhone X 听筒+前传感器组件的替换: 步骤 10 中的图像 1,3 iPhone X 听筒+前传感器组件的替换: 步骤 10 中的图像 2,3 iPhone X 听筒+前传感器组件的替换: 步骤 10 中的图像 3,3
    • 将三角撬片沿着 iPhone 的左下角向上滑动,切开固定显示屏的粘合剂。
    • 请勿将撬片插入超过 3 毫米,否则可能会损坏内部组件。
  11. iPhone X 听筒+前传感器组件的替换, 注意事项: 步骤 11 中的图像 1,1
    • iPhone 的右边缘有易损排线。 请勿将撬片插入此处,插入此处可能会损坏排线。
    Wouldn’t it be better to put this part BEFORE the step where you have to pry open the phone?
    Jan D. Höllwarth - 回复
  12. iPhone X 听筒+前传感器组件的替换: 步骤 12 中的图像 1,3 iPhone X 听筒+前传感器组件的替换: 步骤 12 中的图像 2,3 iPhone X 听筒+前传感器组件的替换: 步骤 12 中的图像 3,3
    • 将撬片重新插入 iPhone 的底部边缘,然后将其向上滑动到右侧以继续分离粘合剂。
    • 请勿将撬片尖端插入超过 3 毫米,否则可能会损坏显示屏排线。
    If you have flat feeler gauges (for adjusting engine valve tappet clearance, ignition points … old school) the .003” thick gauge goes right in. Work your way up in thickness until you can get the pic or supplied pry tool in. Don’t insert metal feeler gauge in too far, just enough to hold crack open. I didn’t need to use the suction cup. I used a hot/cold gel pack heated in microwave to heat edges to soften glue a bit. Made sure it wasn’t so hot I couldn’t stand it on my skin.
    William Olstad - 回复
  13. iPhone X 听筒+前传感器组件的替换: 步骤 13 中的图像 1,3 iPhone X 听筒+前传感器组件的替换: 步骤 13 中的图像 2,3 iPhone X 听筒+前传感器组件的替换: 步骤 13 中的图像 3,3
    • 显示屏的顶部边缘被胶水和卡扣固定。
    • 沿显示屏的上角滑动撬片,同时朝着Lightning端口的方向向下轻轻拉动或推动显示屏。
    • 如果用力太大,固定显示屏的卡扣会被折断。 请小心操作!
    • 将撬片滑动到对角,并切掉所有剩余用来固定显示器的粘合剂。
    These are the best instructions I’ve ever read for anything.! Thank you!
    Peter Andrew - 回复
  14. iPhone X 听筒+前传感器组件的替换: 步骤 14 中的图像 1,1
    • 拉上吸盘上的小凸起,将其从前面板上取下。
  15. iPhone X 听筒+前传感器组件的替换: 步骤 15 中的图像 1,3 iPhone X 听筒+前传感器组件的替换: 步骤 15 中的图像 2,3 iPhone X 听筒+前传感器组件的替换: 步骤 15 中的图像 3,3
    • 从iPhone显示屏的左侧向上打开iPhone,就像面对书本底部时,翻开最后一页一样。
    • 不要试图将屏幕和手机完全分开,因为几条易碎的连接线任然与iPhone的控制板连接着。
    • 如图所示,保证屏幕的框架也和屏幕一起拆开,而不是还卡在手机里。
    • 在重新组装过程中,将显示器放置到位,沿着顶部边缘对齐夹子,然后小心地将顶部边缘压入到位,然后将其余部分向下收紧。 如果不能轻松安装到位,请检查显示器周边的夹子状况,确保它们没有弯曲。
    My phone came apart in a different way and looks not right the little box at the top of the display as actually bolted to the top of the frame body I think something went really wrong when I opened it.
    Mike Kostersitz - 回复
    It opens like a book but be careful not to open it all the way — only as far as shown in the photo. Otherwise it will strain the thin cable that connects the sensor module and then no more FaceID for you (or, as it turns out me). This could have been made more explicit in the instructions.
    Richard Tucker - 回复
    It opens like a book but be careful not to open it all the way  … the small stainless steel tabs that hold the screen around the metal frame, that are on the bend place (right side of the phone)… are tend to bend, you can straighten them back to 90 deg. but the plastic base that they are on? very fragile- watch out not to break the plastic bezel … it may come apart of the glass.
    dabur872 - 回复
    Advice for re-assembly: Before closing up the phone with the seal, check if phone is powering up again and speaker, mic and sensors are still working. If done this check even before installing the board connector bracket in Step 13.
    Alexander Nowak - 回复
  16. iPhone X 听筒+前传感器组件的替换, 屏幕组件: 步骤 16 中的图像 1,1
    • 拧出固定逻辑板支架的5个符合以下长度Y000规格的螺丝
    • 3个1.1mm的螺丝
    • 1个3.1mm的螺丝
    • 1个3.7mm的螺丝
    • 做这步的时候,注意记住每个螺丝位置并在安装的时候准确的拧回去,因为这保护你的摄像头不被破坏。
    One thing I found helpful for replacing the screws was to use only the 000screwdriver tip, without the handle. This way, the tip isn’t magnetized and the screw doesn’t tend to ‘roll’ off the screwdriver tip (the screw has almost no mass, so the head (largest surface) is pulled around to the side of the screwdriver tip when magnetized).
    Rich May 23, 2020
    ungodly - 回复
    My 3.1mm screw had a stripped head, could not remove it. (Factory defect, this iPhone was never opened)
    So I had to give up removing the display assembly, and jumped directly to battery replacement, Step 20.
    That was tricky as I had to keep the display at 90º with a risk of breaking display connectors, but hopefully the replacement went well.
    I would not recommend to do this but to follow the guide, but, in case someone encounters a similar issue, that could help!
    vingu - 回复
    My 1.1mm screw had a stripped head. Used a 3mm steel drill to cut the head off (just 1 mm deep haha) so i could remove the bracket.
    Renout - 回复
    Be careful on reassembly. Keep the screen supported and not moving. I had difficulty getting the screws in and ended up ruining the screen connectivity at the back of the screen where the ribbon cables go in near the center. I was trying to hand hold the screen and it ended up moving around too much.
    SETH GREEN - 回复
    To keep track of the screws, I copy the photos showing their places, then arrange these photos on document in Pages, print it. Next I apply two sided sticky tape (the roll-on type). So all screws have their corresponding places …
    Max Glanzmann - 回复
  17. iPhone X 听筒+前传感器组件的替换: 步骤 17 中的图像 1,1
    • 移除后盖
    • 后盖可能会轻轻在粘连着,用稳定并缓慢的力度将其分开。
    • 在你装回去的过程中,在屏幕密封之前这是一个测试你的iPhone是否功能完好的好机会,但要注意在测试完后一定要关机后才能继续进行下一步哦。
    I tested it, then proceeded to close up the device without the bracket. Do I need to reopen and install? All connections are good?
    monastra7 - 回复
    The bracket helps those many connectors underneath maintain good contact. Probably in the short term nothing bad will happen, but I’d hang onto the bracket and reinstall it when convenient.
    Jeff Suovanen -
    Agree with Jeff
    cgtyoder -
    I tested all imaginable functionality on the new OLED screen. Taptics are fine. Then, I noticed that the battery wasn't charging. Any ideas as to what could have gone wrong?
    Monica - 回复
    for me, the replacement battery was completely dead, small panic when the power-on button was pressed, but quickly realised that this was the situation, and now watching the phone take a power cycle.
    James Stanbridge - 回复
    Before clicking the screen assembly back, I tried to test the iPhone by pushing the start button, but nothing happened. After taking off the bracket, reseating the plugs I tried again - nothing happened! Then I plugged in the charging cable connected with the iMac, and it started immediately. So if the phone does not start using the startup button, it might just be a glitch when reconnecting the battery.
    Max Glanzmann - 回复
  18. iPhone X 听筒+前传感器组件的替换: 步骤 18 中的图像 1,2 iPhone X 听筒+前传感器组件的替换: 步骤 18 中的图像 2,2
    • 用撬棍的尖端或干净的指甲去撬开电池与逻辑板的连接
    • 尽量不要损伤在逻辑板或其他板周围的黑色硅脂,这是用来加强防水防尘能力的
    • 轻轻挑开那个接口,避免逻辑板意外的连到电池上接通手机的电源
    cosa può succedere se non si disconnette la scheda logica'?
    luca.valli - 回复
    note: be careful not to crush or puncture your battery at this step!! I gave mine a minor dent, which I hope wont be a problem.. but something to keep in mind for fxlks in the future!
    Noal Balint - 回复
    Thanks, already did it)
    Stephen Hedrick -
  19. iPhone X 听筒+前传感器组件的替换: 步骤 19 中的图像 1,2 iPhone X 听筒+前传感器组件的替换: 步骤 19 中的图像 2,2
    • 用撬棍或者指甲来断开前面板传感器的连接
  20. iPhone X 听筒+前传感器组件的替换: 步骤 20 中的图像 1,2 iPhone X 听筒+前传感器组件的替换: 步骤 20 中的图像 2,2
    • 使用撬棒的尖端或手指甲来撬开OLED面板排线的插头。
    • 想要重新连接这种按压型插头,先将插头的一侧对准位置轻轻按压到位,然后在另一侧重复操作。切忌从中间按压插头。如果插头没有对准位置就对其进行按压的话,插头的触脚会被折弯,会对插头插座造成永久性的损坏。
    Snap ‘em in like little Legos.
    Ray Johnson - 回复
    Maybe the manual should flip step 17 and 18 (as the digitizer cable from 18, is in the way of the OLED cable of step 17) ?
    Renout - 回复
  21. iPhone X 听筒+前传感器组件的替换: 步骤 21 中的图像 1,2 iPhone X 听筒+前传感器组件的替换: 步骤 21 中的图像 2,2
    • 使用Spudger撬棒的尖端将数据排线的插头从插座撬开。
    • 这个插头所处于的隐蔽位置使其不容易重新连接上。要花点时间小心地将其对准位置,然后用你的手指先轻轻地将其一侧按压到位,然后是另一侧。你可以感觉得到它卡在正确的位置。
    • 如果维修完后发现屏幕有任何触摸失灵的部位,请先断开电池连接然后重新连接这个插头,确保其完整的卡在了正确的位置,并且插座里没有灰尘或其他的损坏。
    This was probably the hardest part other than trying to get the screen off with the crappy suction cups. I re-installed the bracket only the find out that the touch screen would not respond to touch. Had to remove the five screws, remove the bracket and reseat the recessed screen connector. Reseating the bracket took another 10+ minutes. I carefully used the angled forceps to grab the cable and align the connector being careful not to damage the cable.
    Once you have the connector seated, I would reconnect the battery, power on the phone, and check the touch screen response before re-installing the bracket (step 13).
    Yeah, this was probably the trickiest part of the reassembly. The power connector cable kept getting in the way so I moved it carefully but fully out of the way. Then it was a matter of fiddling around with it a bit and being careful not to force it on.
    Jeffrey Hoy -
    I was positive that I had messed something up, I had powered up the phone to test three different times and everything seemed find except there was no touch at all. On my fourth attempt, I carefully examined everything for dust and debris (blowing gently), and I did notice that a corner of the connector (more like part of the ribbon) was bent slightly, and I straightened it. I don't know if it was the ribbon or some tiny debris, but after reseating a fourth time, it worked.
    Pol Llovet - 回复
    Very important part of the tutorial. Be careful and patience! In my case the screen and camera didn't respond after assemble, so I tried again to reconnect the connector like tutorial said and it worked well. Now my iPhone feel like a new one 💪🏼
    Efrain Maestre - 回复
  22. iPhone X 听筒+前传感器组件的替换: 步骤 22 中的图像 1,3 iPhone X 听筒+前传感器组件的替换: 步骤 22 中的图像 2,3 iPhone X 听筒+前传感器组件的替换: 步骤 22 中的图像 3,3
    • 前面板传感器组弯折型的排线在这里被一点点粘胶粘住了。
    • 小心地提起排线直到粘胶被分离。
    Do this sensor affect face id?
    bonglkv - 回复
    It is part of the face id part so yes. This is the ear piece too so if the ribbon tears there is a chance the ear piece will stop working as well.
    Stephen Patterson - 回复
    Be super careful handling this ribbon particularly. I did a battery install and, when I was done, I had a phone with a new battery and no Face ID. That’s a $300 Apple repair, and no 3rd party shop will touch it. I believe the ribbon lays vertically (i.e., perpendicular to the “floor” of the phone, against the side edge of the battery. During the re-install, I must have forced the ribbon into position after seating the connector, causing fatal flexing of the ribbon. (Don’t know this for sure, but I see another comment saying that this cable is part of Face ID.) Anyway, bottom line: BE CAREFUL REMOVING AND REINSTALLING THIS RIBBON!
    Jonathan Pines - 回复
    My flex cable was more than lightly adhered in place. I needed to use a guitar pic or similar to help encourage adhesive to separate. I wouldn’t pull too hard like shown in pictures unless you had just the right grip on the ribbon cable so as to avoid damaging flex cable. See note above (5/31/20)
    William Olstad - 回复
    Bizarre — it turns out my whole front panel sensor assembly came entire off of the front screen and is stuck to the logic board.
    Karl Jarvis - 回复
    I also found the glue quite recluctant to release so I applied a second or two of heat using the wife's hair dryer which softened it and the cable lifted much easier then. Be careful not to apply too much heat though which could then impact other internal components.
    LosBenitos - 回复
    Cho ít cồn 90° vào để mềm keo dễ tháo
    huuhaukimngan - 回复
    my iphone x doesn't have a front panel sensor? in fact, it looks completely different than the picture???
    Kenneth McLeod - 回复
    @kennethmcleod, most likely you've separated the screen frame from the screen itself. We see this most commonly when people neglect to remove the pentalobe screws next to the charging port. Usually the cure is to take out those screws, then repeat the screen removal process on the frame that's still attached to the phone.
    Jerry Wheeler -
    You don't need to disconnect the front sensor to change the screen. Just leave it connected and remove from the screen side.
    Anthony Boshell - 回复
  23. iPhone X 听筒+前传感器组件的替换: 步骤 23 中的图像 1,1
    I tried this and broke the cable can it still repair
    Alexis Rodriguez - 回复
    At this point I would have found it easier to remove the glue from the edges than later on when I was reassembling it. I bought the kit that had the replacement glue in it.
    Grant - 回复
    Excellent guide! Would love to have a link to moving the sensor assembly from the old display to the new here.
    Nicole - 回复
    CAUTION:
    Removing the Taptic Engine or Speaker in next step is optional and the guide continues as this was per se needed.
    Unnecessary work and also If you remove the speaker you lose the adhesive gasket and this is not included in the scope of delivery of the "Battery replacement" offering.
    So do not remove and avoid losing waterproofing.
    Julian Gonzalez - 回复
  24. iPhone X 听筒+前传感器组件的替换, 听筒+前传感器组件: 步骤 24 中的图像 1,1
    • 移除屏幕总成后红外镜头旁的1.2 mm Y型螺丝。
    Not sure as of what to do now, I have stripped this screw.
    Kelvin - 回复
    It might be your driver tip that is no good. Try a new driver tip Y000
    carol - 回复
    when I opened my iPhone the screw was already stripped, I had the phone once at an Apple store for repair about 2 years ago. Had not opened it in between so it seems they stripped the screw there or it came like that from the factory. Any ideas? I don’t want to try and force it out.
    Be careful: the metal clip beneath this screw it’s really small, make sure not losing it.
    Luca Ciprian - 回复
    Steps 19 and on are all on the screen you just removed. Not the phone side. I didn’t look closely at the image and just went for the screw in roughly the same place on the phone body side. First warning sign it’s a phillips - but more importantly I was working on the entirely wrong piece. I guess you’ll probably figure it out faster than I did.
    Big Nerd - 回复
    FYI: My iphone XS has a slightly different screw position for the one shown to have a “clip”. There is no clip for this screw on mine. Maybe a rev update because of the clip getting lost and being hard to reinstall?
    William Olstad - 回复
    FYI - The sensor assembly of the replacement looks a bit different from my original one. The screw is located further to the right on the original. As a result, I am unable to attach the sensor assembly on the replacement part, because the fixture is at a different position.
    Unfortunately, there’s nothing I can do about it apart asking for a refund.
    Screws at my Iphone X are normal,but even w heat,i cant take them off,and even the strongest member of my family cant do this
    Matej Sedivec - 回复
  25. iPhone X 听筒+前传感器组件的替换: 步骤 25 中的图像 1,3 iPhone X 听筒+前传感器组件的替换: 步骤 25 中的图像 2,3 iPhone X 听筒+前传感器组件的替换: 步骤 25 中的图像 3,3
    • 在您刚移除的螺丝下有一个小的圆环金属片。如果刚才拧下螺丝时金属片没有掉下,请将其移除。
    • 重新组装的过程中,请将金属片放平(如图所示),将金属片对准位置并保持住,然后将螺丝从中穿过并拧紧。
    sin ese clip la señal wifi se recibe a duras penas
    Harizola Taberna Margari - 回复
    Is there a way to just buy the gold grounding clip because my phone cannot search for wifi anymore!
    Anonymous - 回复
    Is there any way we buy the ground metal clip separately please if there’s a way to get it emailed me
    Sisthanu Iman - 回复
    Reinstalling this clip + screw is super hard =P
    Josh Estelle - 回复
    It is pretty difficult without using a zoom in. A 2nd iphone camera zoomed in at 8x while using magnetic screwdrivers makes the job a little easier
    Bill McNamara -
    Yes eBay has it
    riosbenny09 - 回复
    Screw Gasket Ear Speaker for Apple iPhone X Replacement Repair Phone Part Speak
    riosbenny09 - 回复
    This looks different on my iPhone X. There’s no clip. It turns out that the replacement screen is NOT compatible with my iPhone. See my comment on Step 23. Must be a different HW revision. The whole front sensor assembly casting is a bit different. After replacing 2 screens of older iPhone generations this is my first failure due to HW incompatibility. From here on forward I probably won’t attempt another major smart phone repair. Technology is getting to complex for DIY. Will buy an iPhone 13 Pro with insurance (even though it’s utterly overpriced and I always like the DIY challenge)…
    it’s not technology that’s getting more advanced, it’s apple creating more barriers between a DIY repair vs funneling your hard earned dollar into apple care and the Genius Bar
    aburningstariv -
    I did the same thing here - its the x vs xs and my partner ordered the part
    I ripped off the side clips and ones in wrong place (put the old screen next to it - and rip them off with needle nose plyers (in a rolling motion so you get each solder one at a time)). the smaller clips that had enough room i left.. then i could force the screen on.
    And its working ...... lets see for how long - the sealant and small clips seem to be holding it together ok
    Archie Ko -
    Que pasa si no pones ese clip?
    ferxi sabee - 回复
  26. iPhone X 听筒+前传感器组件的替换: 步骤 26 中的图像 1,1
    • 移除另外两个保护听筒+传感器总成的Y型螺丝:
    • 一个1.6mm螺丝
    • 一个1.3mm螺丝
    What do you do if the 1.6mm tripoint screw won’t come out…? I think it may be stripped :(
    Salvatore Boenzi - 回复
    You could try using an old screwdriver & carefully adding a dab of superglue to the screw to attach it to the screwdriver, Then the screw may come out, Superglue’s strength is holding 2 pieces together when the stress point is pulling the 2 pieces away from each other. Superglue becomes surprisingly easy to break when twisting the 2 pieces. So be careful since the rotation of the screw will put the stress point at the weakest of the glue’s strength.
    Sandman619 - 回复
    I would suggest:
    1. Try a small precision flat head, a good quality one, I bought some that were supposed to be to remove stripped screws, about 20-30 bucks for 4 or 5 of them, and they have saved my butt many times.
    2. I have been able to remove stripped screws with wire cutters. Or you can try some vamp pliers but they are probably too large for this situation.
    3. If the last two fail, the course of action is to basically destroy the head of that screw (assuming you are removing the stuff you need for your new lcd, which is very likely) they have drill bits called easy outs or screw removing drill bit, which is a drill bit with the spiral going the opposite direction (for a screw that tiny you can take a small drill bit, cut and sharpen the end that normally has no spiral, I have made that work in the past) the point is that as you drill in, the drill bit is digging and moving counterclockwise, so at some point as it digs in it will get “stuck” and keep spinning go the screw, thus removing it.
    Victor Miranda - 回复
    what to do if during assembly the 1.6mm doesn’t want to go in it’s hole in the new screen but it fits perfectly in the old one??
    Khalil - 回复
  27. iPhone X 听筒+前传感器组件的替换: 步骤 27 中的图像 1,2 iPhone X 听筒+前传感器组件的替换: 步骤 27 中的图像 2,2
    • 听筒被一点粘胶粘在这里。
    • 使用一个撬棒,轻轻将听筒组件从其上端撬起,然后将其翻过来远离屏幕上端。
    • 听筒剩余的部分连接在一个非常薄的弯折型排线上。注意不要损伤排线。
    i damage the cable, where can i buy a replacemnt
    Haoyu Li - 回复
  28. iPhone X 听筒+前传感器组件的替换: 步骤 28 中的图像 1,1
    • 使用一个吹风机或加热风枪或准备一个iOpener,加热屏幕前部的顶端大约一分钟,来软化用于保护传感器的粘胶。
    que temperatura debe tener una estacion de calor para hacer el trabajo del iopener
    mismac - 回复
    I could not have done this without the iOpener, it was worth the investment!
    Bill Debevc - 回复
  29. iPhone X 听筒+前传感器组件的替换: 步骤 29 中的图像 1,3 iPhone X 听筒+前传感器组件的替换: 步骤 29 中的图像 2,3 iPhone X 听筒+前传感器组件的替换: 步骤 29 中的图像 3,3
    • 使用撬棒的平直端小心的在麦克风下的排线的下面划动。
    • 轻轻转动撬棒来将麦克风分离,小心不要损坏排线。
    • 如果需要的话,使用撬棒的尖端将麦克风从前面板上的圆形切口中分离。
  30. iPhone X 听筒+前传感器组件的替换: 步骤 30 中的图像 1,3 iPhone X 听筒+前传感器组件的替换: 步骤 30 中的图像 2,3 iPhone X 听筒+前传感器组件的替换: 步骤 30 中的图像 3,3
    • 使用一个三角拨片在排线和距离感应器+泛光感应元件下从左往右划动。
    • 轻轻摆动并提拉模组来将其与前面板上的开孔分离。
    • 提起听筒有助于上面的操作。注意不要使排线受到很大拉力。
    i can i purchase this part
    M. Brown - 回复
    yes mr.brown, you can
    MadMan2207 - 回复
    if you interrupt a small part of that black tape, is the piece of Face ID/micro phone unrecoverable?
    green_g - 回复
  31. iPhone X 听筒+前传感器组件的替换: 步骤 31 中的图像 1,2 iPhone X 听筒+前传感器组件的替换: 步骤 31 中的图像 2,2
    • 使用镊子轻轻扭动环境光传感器来将其从屏幕开孔中提起。
    • 传感器剩余的部分和剩下的传感器组通过一个很薄的弯折型排线连接。小心不要损伤排线。
  32. iPhone X 听筒+前传感器组件的替换: 步骤 32 中的图像 1,3 iPhone X 听筒+前传感器组件的替换: 步骤 32 中的图像 2,3 iPhone X 听筒+前传感器组件的替换: 步骤 32 中的图像 3,3
    • 如果您成功的移除了整个环境光感应器(如图一所示),请继续下一步。
    • 如果传感器上的白色柔光条脱落并残留在屏幕上(如图二所示),您需要使用一个薄的刀片或撬棒从屏幕的上缘小心地将其撬出。提前重新加热可能会使其更容易操作。
    • 重新组装的过程中,请先将柔光条安装到屏幕上,确保其面对正确的方向(朝前的一面如图一所示,朝后的一面如图三所示)。
    • 然后将环境光感应器安装到柔光条上。当您安装固定听筒+传感器组的螺丝时您需要保持住传感器正确的位置。当螺丝拧紧时,传感器就会固定到正确的位置并能正常工作。
    quá rõ ràng, cảm ơn ifixit
    Dang Tuan - 回复
    In my case the diffuser came out with the light sensor, but not completely. A layer of the diffuser was left behind in the recess. We will see how it goes. ;) I will report back.
    Pol Llovet - 回复
    what colour is the diffuser
    James Thomas (Tom) - 回复
    also can you show the position of sensors going back into the new screen
  33. iPhone X 听筒+前传感器组件的替换: 步骤 33 中的图像 1,3 iPhone X 听筒+前传感器组件的替换: 步骤 33 中的图像 2,3 iPhone X 听筒+前传感器组件的替换: 步骤 33 中的图像 3,3
    • 移除听筒+前传感器组件。
    • 重新组装的过程中,请检查包含以下元件的黑色塑料模组的位置:
    • 距离感应器
    • 泛光感应元件
    • 模组必须对准该位置以避免以上元件被周围的粘胶遮盖。
    there was no bracket on my new screen I purchased from here.. am I supposed to heat up and remove the old one, or was their supposed to be one on the new screen ??
    0perationguttertech - 回复
    @br0k3nilluzion If your new display didn’t come with a front camera frame, you can (and should) remove the old one from your broken display and transfer it over. Use heat and careful wiggling/prying to remove it—and if it’s stubborn, add a few drops of isopropyl alcohol. Hope this helps!
    Jeff Suovanen - 回复
    Does face-id stop working if the black plastic separates from the flex(The orange and red dot)?
    tharshan91 - 回复
    If the black plastic piece with the flood illuminator and the proximity sensor is separated from the flex cable, then Face ID will definitely not work. Be very careful not to damage any of the parts in the front sensor assembly.
    Adam O'Camb -
    There is some sort of a tape in front of the flood illuminator which is not present on the replacement screen! Is that gonna cause a problem too?
    BTW, it’s so difficult to position the front camera frame without glue. I guess it takes a few attempts of trial and error!
    shoeib - 回复
    It might not cause any major problems, but there’s a chance that it could effect FaceID functionality. If possible, transfer the tape from the old screen to the new one.
    Adam O'Camb -
    I find it better, regardless of if your new screen comes with the transparent front camera frame, to remove the front sensor assembly from the old screen with the frame, and lifting up the whole assembly using the frame. That way you do not need to apply heat directly to the fragile assembly, but apply it to the other side, the front of the screen at the top, instead, to soften the frame adhesive. The frame is then usually easy to pry loose using a narrow spudger, and comes off cleanly. After that it is much easier to remove the sensors and microphone from the frame, no heat needed usually. And if your new screen doesn’t come with the frame, just plonk the whole frame/sensor assembly down in the right place, and boom, Bob’s your uncle.
    Lars - 回复
    Hello I have an iPhone X i Bought it in 2019 with Face ID not working ( not available try later ) I think the screen was changed with another original , tru tone Off , Als off no auto brightness (and the PROXIMITY SENSOR too ! ) no black screen in calls, i would like to ask u if the earpiece speaker flex was changed with another one (all components ) not the original , did proximity sensor still work ?? Because I don’t know is the original flex of my iphone or not ? I found some scratches in the flex it appears to have small cut so I don’t know the PROXIMITY SENSOR not working because there are a small cut in the flex or because the flex is not the same ?? And if the flex is not the original it can disable (proximity sensor)too not only flood and als ?? Thank you
    Ach - 回复
    Yes it should still work. If you change the assembly to one that isn’t original to that iPhone X everything except the FaceID should still work - I have done so several times for clients. So the reason for yours not working is probably the same small scratches and cuts you have seen. The cable is a bit fragile and some of the copper leads running through it are extremely thin.
    Lars -
    To keep True Tone function on the replacement screen you’ll need a chip data programmer EEPROM to copay data from the old screen onto the new one. There a device called JC-V1 which should do the trick.
    Yousef Ghalib - 回复
    Screen glitching slightly after changing the screen. Any suggestion to what it can be?
    Tim Morell - 回复
    Tim. I had a glitchy screen as well. It would force touch out of nowhere, and “ghost touch” every now and then. Eventually, the top half of the screen stopped responding. Reach out to customer service ASAP. You may have a defective screen.
    Alex Hurtado -
    My front ear speaker not working . The mic it’s working . Apple said you have to replace all the screen to fix the ear speaker because it’s connected with one cable all together. If I buy the speaker and change it myself it will work after or I’m getting into trouble?
    josh - 回复
    I have the same problem. I have the same problem. how did you solve?
    xX_Sn4k3x_Xx - Official -
    Be sure to remove the blue protective film from the BACK of a replacement screen.
    Jim Breef - 回复
    Thank you so much for this. It does not look at all like it needs to be removed.
    Pol Llovet -
    Thank you, Jim, came here just to look for that advice!
    seth hollub -
    can this piece assembly cause for the back camera and flashlight not work? All I did was change the screen and transfer this earpiece and it says warning sign that the flashlight needs to cool down and back camera not working
    Dulce Vidal - 回复
    disregard my last post, problem solved on my end customer had a bad back camera due to bad fall and so i replaced it and now the back camera and flashlight works. :)
    Dulce Vidal - 回复
    Hello I replaced today the second time iphone x display. The first time after a while the front camera stopped working. Today mounted the second time the display and the front camera works, while the rear one does not work. What can I do? Thanks
    Mimmo Cordola - 回复
    if you interrupt a small part of that black tape, is the piece of Face ID/microphone unrecoverable at all?
    green_g - 回复
结论
将你用于更换的备件和之前的备件进行对比
-- 你可能需要将备件的剩余部分从之前的备件转移过来,或是在安装新备件之前清理干净粘胶。
请倒序进行上述的步骤来重新组装你的设备。
将你的电子垃圾丢弃到 R2 or e-Stewards certified recycler.
维修进行得不顺利?看看Answers community 能不能帮到你。
88等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Adam O'Camb
于04/11/15注册
196,143 声望
创作了416篇指南
23条评论
Is it possible to fix the ““Face ID Is Not Available” problem? There seems to be a problem with the TrueDepth camera. Thanks!
Alejandro D - 回复
@alejandrod I’m afraid Face ID won’t work if this part is replaced. As stated in the introduction, this component is paired to the logic board from the factory (similar to the home button on earlier iPhones). Currently, if you need to replace this part, you’ll have to sacrifice Face ID, or else pay Apple directly to perform the repair. (They have a software calibration tool that pairs the new part to your phone to re-enable Face ID, but they don’t share it with anyone outside of Apple.)
Jeff Suovanen -
The flex cable was too bent, and now is broken. I’m going to buy another flex cable, but… Are there any ways to recover the Face ID functionality? Desoldering some components from the old one and weld them in the new flex cable?
Andrea Giacon - 回复
Flex cables can be repaired by a skilled microsolderer. It’s not a DIY however. If it’s a phone you care about, you’ll want to find yourself a good repair shop with the right equipment and skills. Apple can also repair it, but they will most likely just charge you $279 to replace the entire screen.
Jeff Suovanen -
My proximity sensor is defective and puts my phone in a boot loop when connected. To replace that, would I need to use a skilled microsolderer to replace that?
oosaghae - 回复
My earpiece is broken would replacing mean that I’m sacrificing Face ID?
Mujtaba Suhrawardy - 回复
Just did mine, and yes, my face ID doesn’t work anymore.
Dane Frederick -
Hey does anyone know what’s wrong with my Iphone X. I thought I had a blown ear speaker. So I just replaced the assembly, but after reassembling it doesn’t sound any different. Anyone speaking is extremely quiet. And yes my Bluetooth is off, no I don’t have any headphones in it. and the volume is all the way up. Any other ideas what is happening? It has been a major inconvenience to have to put everyone on speaker phone just to talk to them.
Dane Frederick - 回复
Have you checked the speaker grille/mesh to make sure it’s clean? They can get clogged with pocket lint over time, blocking sound from the speaker.
Jeff Suovanen -
شكرا علي كلشيء
Corva Loco - 回复
Hi All,
I replaced the screen on the iPhone X and now the camera and face ID don’t work. The camera app is black when I open it. I can’t test the proximity sensor because there is no cell service on the phone. I assumed I damaged the flex cable so I put a new one in and same result.
I put the original flex back on the original screen and same result. I am not sure if face ID or the camera was working before the repair. I normally check what is working and what isn’t, but I forgot to this time.
Thanks!
Mitch - 回复
Hey i was repair my iphone x battery when this broke off. i bought a new earpiece thing and the sensor part but i heard that apple pairs specific parts to the logic board so if i replace it will the mic still work?
Mak - 回复
I lost the screw and grounding clip. Your step 21, “Beneath the screw you just removed lies a small metal grounding clip. “ Any ideal where I can get the screw and grounding clip?
Melvin Hamill - 回复
Your step 21, “Beneath the screw you just removed lies a small metal grounding clip. “ I have lost the screw and grounding clip. Any ideal where I can find the screw and grounding clip/
Thank you
MEL
Melvin Hamill - 回复
I have replaced the battery, the dock connector and this component and I forgot to install the grounding clip while closing the phone. Now everything works expect the charging; the phone recognizes the charger as an accessory but it does not charge at all. It charges only if it is not powered on (without showing any charging symbol, by the way). Do you know if this might be due to this missing grounding clip? Thanks!
Andrea Giammanco - 回复
Hola, con este proceso mi face id dejará de funcionar?
Saludos desde México!
Horlando Anzures Quiroz - 回复
Correcto, no funcionará
Terranova -
Si el Face ID deja de funcionar.
Terranova - 回复
What adhesive do you recommend for reattaching the earpiece speaker on to the replacement display?
mcvtech - 回复
I have iPhone X and the ear speaker not working. But I have one more iPhone X with cracked screen. Can I remove the ear speaker from the second  iPhone and replace it to my iPhone? Is the Face ID will work after if it’s original Apple part?
josh - 回复
Can I replace the earpiece speaker without also replacing the front sensor assembly?
Rosie Tabachnick - 回复
The earpiece flex is cut a little so my ear speaker stopped working is there any way to do this
black emmah - 回复
Could you recommend someone near me that can repair a flex cable? Westfield,Massachusetts
Louis - 回复
添加评论
浏览统计数据:
过去 24 小时: 44
过去 7 天: 278
过去 30 天: 1,122
总计 201,806
