跳转到主内容
iPhone 8 Back Glass Replacement
视频概述
  1. iPhone 8 Back Glass Replacement, iPhone 8 Back Glass Replacement: 步骤 1 中的图像 1,1
    • Wire up the Back Glass Separator. Connect the Back Glass Separator with Air Compressor via an air pipe. Switch on the Air Compressor. Open the air compressor valve.
    • Switch on the Back Glass Separator. Rotate the pressure regulating valve and set the value as 0.4Mpa.
  2. iPhone 8 Back Glass Replacement: 步骤 2 中的图像 1,2 iPhone 8 Back Glass Replacement: 步骤 2 中的图像 2,2
    • Place iPhone 8 back glass assembly into the corresponding mold. Press ‘Up’. With the temperature rising to 240℃, press ‘Start’. The back glass assembly is clamped tightly by the mold.
    • After 200 seconds of heating, mandril of the machine starts to work.
  3. iPhone 8 Back Glass Replacement: 步骤 3 中的图像 1,1
    • Remove the back glass after 18 seconds. Remove glue residue on the back glass thoroughly.
    • iPhone 8 back glass separating has been completed successfully.
    • Attach a new back glass to the midframe in the end.
终点
13等其他人完成本指南。
Phryne
于11/17/19注册
20,329 声望
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 133
过去 30 天: 574
总计 50,226
