简介
For an easier repair, use our fix kit and follow this shorter guide to replace your iPhone’s entire screen.
For more advanced fixers, this guide will help you replace only the iPhone 7 LCD and digitizer assembly (a.k.a. the bare “front panel”). This requires you to transfer several components from your original screen to the new one before installing it—including the front camera assembly, earpiece speaker, LCD shield plate, and home/Touch ID sensor.
For all screen/display repairs, it's important to carefully transfer the original home/Touch ID sensor onto the new display in order for it to function. The solid state home button is paired to its original logic board by Apple, so replacing it will render it unusable.
你所需要的
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
在这个步骤中使用的工具:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap.
Skip the next three steps.
Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
Apply a suction cup to the lower half of the front panel, just above the home button.
在这个步骤中使用的工具:Tri-point Y000 Screwdriver$5.99
Remove four tri-point Y000 screws securing the lower connector bracket, of the following lengths:
Three 1.2 mm screws
One 2.4 mm screw
Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
One 1.1 mm screw
Three 1.3 mm screws
Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
Remove the three Phillips screws securing the earpiece bracket to the front panel:
Two 2.6 mm screws
One 1.7 mm screw
Reheat your iOpener and apply it to the upper edge of the display assembly to soften the adhesive holding the front camera and sensor assembly in place.
Remove the three 1.2mm tri-point Y000 screws from either side of the display assembly for a total of six screws.
Heat an iOpener and lay it over the edge of the shield closest to the home button to soften the adhesive holding it in place.
442等其他人完成本指南。
49条评论
When I took off the home button, a small black square rubber piece fell out. while prying off the cable.
Can anyone tell me where this is supposed to go when I put the home button back on.
The small black square that fell off is originally located on the bottom pentalobe screw bracket on the screen. It can slide back over it if you place it right.
Primus -
Thank you!!!
useless guide without a guide how to mount it all back on.
The home button wont fit back in its whole
You have to put the flex through the hole from the front, and set the button against the front of the screen. Just like you got it out, in reverse.
