跳转到主内容
iPhone 7 Plus Pentalobe Screws Replacement
你所需要的
  1. iPhone 7 Plus Pentalobe Screws Replacement, Pentalobe Screws: 步骤 1 中的图像 1,1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
结论
33等其他人完成本指南。
Evan Noronha
于02/05/15注册
223,594 声望
创作了168篇指南
4条评论
Can anyone confirm 7/7P's pentalobe screws have a ring of seal near the screw head?
Cooper Chase - 回复
Hey Cooper,
There is no seal on the screw. The head of the screw simply pushes against the lip of the screw well, without using any sort of pneumatic seal, o-ring etc.
As Talon says, it is part of the casing.
Harry Rowse -
I not recall seeing one. If there is one I would expect it to be part of the casing.
Talon - 回复
as the costumer said, there is a sealant but not noticeable
Mark Perick Quemado - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 23
过去 30 天: 105
总计 20,013
