跳转到主内容
iPhone 7 五角螺丝的更换
你所需要的
  1. iPhone 7 五角螺丝的更换, 五角螺丝: 步骤 1 中的图像 1,1
    • 开始前,请将手机的电量降低到 25% 以下。充满电的锂离子电池意外被刺破的话可能起火或爆炸。
    • 开始拆卸前请关闭手机电源。
    • 打开手机屏幕将破坏下方的防水胶条。如果不替换胶条的话,手机将失去防水功能。
    • 移除手机底端的两颗 3.4mm 五角螺丝。
结论
如需重组设备,请按逆序操作。
53等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Evan Noronha
于02/05/15注册
223,412 声望
创作了168篇指南
5条评论
are there any water seals associated with the pentalobe screws? I blew compressed air into my iphone 7 and two tiny square rubber gaskets (~3mm) popped out. They squares have a round hole in them. I can only figure they are part of the pentalobe screw water seals, but I’m not sure, and I don’t know how to put them back in the phone to restore the water seal. Can anyone offer a solution?
Austin Taterka - 回复
@ataterka The screws themselves have a tiny ring-shaped rubber gasket on them. The two rubber squares you found slip onto the screw bosses. I don’t think those are needed for water sealing, and they’re not even included on newer models.
Jeff Suovanen -
Does iPhone 7 and iPhone 8 (including «Plus» models) share the same bottom pentelope screws?
Victor Rezai - 回复
Put new lcd on with no problems then later batter went bad got new battery and can not get the 2 pentathlon screws out they loosen but not come out will tighten back up lossen but still want come out
Jerry Bonner - 回复
How do I get screws out
Jerry Bonner - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 33
过去 30 天: 159
总计 38,372
