简介
Is your iPhone's selfie camera failing to take photos? It may be time to replace the front camera. Use this guide to replace the front camera sensor assembly, including the ambient light sensor and microphone in an iPhone 7.
你所需要的
视频概述
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
在这个步骤中使用的工具:Tri-point Y000 Screwdriver$5.99
Remove four tri-point Y000 screws securing the lower connector bracket, of the following lengths:
Three 1.2 mm screws
One 2.4 mm screw
Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
Remove the three Phillips screws securing the earpiece bracket to the front panel:
Two 2.6 mm screws
One 1.7 mm screw
Reheat your iOpener and apply it to the upper edge of the display assembly to soften the adhesive holding the front camera and sensor assembly in place.
160等其他人完成本指南。
20条评论
Question ..... I have a clear square plastic piece (open in the center) with a tab on one side. What is that for?
Holds the lens in place.
No that is for the ambient light sensor. LCD replacements come with it already installed on em’, so you can toss it if you see it on the replacement already. The larger, circular plastic piece is for the lens.
Does the iPhone 7 plus Front Camera and Sensor Cable Replacement has to do anything with the earpieces speaker? i have replace my iphone 7 plus screen and front camera and sensor cable replacement and speaker and it still doesn’t work. what could really be wrong with my iphone 7 plus?
Awesome tutorial, thank you! I couldn’t have replaced my camera without this! Well I could have but not the right way!!
