跳转到主内容
简介
参考本指南,以更换有故障的电源和音量按钮排线——其中包括负责音量大小的开关,静音控制和电源开关,以及一个麦克风和双LED闪光灯。
如果你想更换电源键帽,参考本指南;更换音量键帽,参考本指南
  1. 开始前,请将手机的电量降低到 25% 以下。充满电的锂离子电池意外被刺破的话可能起火或爆炸。
    • 开始前,请将手机的电量降低到 25% 以下。充满电的锂离子电池意外被刺破的话可能起火或爆炸。
    • 开始拆卸前请关闭手机电源。
    • 打开手机屏幕将破坏下方的防水胶条。如果不替换胶条的话,手机将失去防水功能。
    • 移除手机底端的两颗 3.4mm 五角螺丝。
    Can anyone confirm 7/7P's pentalobe screws have a ring of seal near the screw head?
    Cooper Chase - 回复
    Confirmed, the screws have a black ring seal around the head.
    rcheing - 回复
    Can’t get the display front
    Bernadette Pfeifer - 回复
  2. 将温暖的iOpener放在手机的下边从而将屏幕封胶融化。
    • 将温暖的iOpener放在手机的下边从而将屏幕封胶融化。
    • 等待大约一分钟,让屏幕封胶融化,然后再进行下一步骤。
    ¿Cuántos segundos son los recomendados?
    joscarlos91 - 回复
    Sesenta segundos
    Krutav Shah -
    It is a process. I heated the lower area of the phone with a hair dryer on and off (1min each) about 3-4 times before I was able to get the provided tool in.
    Dan - 回复
    I suggest using a hairdryer. I used the iOpener for maybe 30 mins to no avail. However, when I used the hairdryer the screen came of much quicker.
    Michael - 回复
    I totally Mr. Myagi’ed it, by rubbing my hands together until they burned, then held the phone un my hot hands. I did this 5-6 times over a couple of minutes. It was a good zen way to get started!
    Ark - 回复
    Can a heat gun be used?
    Lee - 回复
    Absolutely. Just don’t overdo it—the adhesive usually softens up pretty easily. If you are experienced with a heat gun, you’ll have no problem. (If you are inexperienced, it’s easy to cook the display or cause other damage.)
    Jeff Suovanen -
    If i use this process, will iphone 7 still be sealed, water/ splash resist after that?
    Marius Serban - 回复
    Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    Angel Hermida -
    Can I use a cpb heating pad to soften the adhesive ? If yes how much time and temperature ?
    davidecongiu - 回复
    Will doing this compromise the screen protector (Zagg) that I have on my phone?
    Eric Nance - 回复
    Hairdryer worked for me but I needed to use a razor to pry it open at the bottom then used the spudger
    Gina Torres - 回复
  3. 将吸盘吸到显示屏的下半部分,Home按键的上方。 确保吸盘与Home按键不重叠,否则吸盘将不能吸起前玻璃。
    • 将吸盘吸到显示屏的下半部分,Home按键的上方。
    • 确保吸盘与Home按键不重叠,否则吸盘将不能吸起前玻璃。
    The glass is completely cracked and the suction cup doesn't work because it gets air in between. any tip?
    Display is glued and doesn't come off.
    support - 回复
    A wide, single strip of packing tape, well placed, will solve this for you. :)
    Mimic44444 - 回复
    Last comment works well. Thank you !
    Using packing tape for a cracked screen should be included in the description in Step 3.
    Cracked screen is most probably the reason you are replacing it.
    Arni Benediktsson - 回复
    I agree that using packing tape for a cracked screen should be included in this steps description. I don’t have wide but turned mine horizontal and that worked great.
    Mary Knapp - 回复
    Bekomme die Oberschale einfach nicht runter! Trotz mehrmaligem erwärmen durch den iOpener und seitlichen bewegen! Weiß nicht mehr weiter!
    Stephan Lienhard - 回复
    Wouldn’t that screw up the Touch ID?
    Rexx Havok - 回复
  4. 拉起吸盘,使显示屏组件和外壳之间形成一个小缝隙。 将撬棒平面那头插进缝隙。 固定屏幕的密封胶粘性很强,如果想产生一个缝隙需要用很大的力。 如果你很难开出一个缝隙,可以上下摇摆屏幕以削弱密封胶的粘性,直到你可以用撬棍插入缝隙。
    • 拉起吸盘,使显示屏组件和外壳之间形成一个小缝隙。
    • 将撬棒平面那头插进缝隙。
    • 固定屏幕的密封胶粘性很强,如果想产生一个缝隙需要用很大的力。 如果你很难开出一个缝隙,可以上下摇摆屏幕以削弱密封胶的粘性,直到你可以用撬棍插入缝隙。
    This was SO hard for me to do with the spudger. I couldn’t get a gap to insert it because my phone was so cracked (even though I used tape on the front) to get a solid seal with the suction cup. I ended up taking a VERY thin knife and inserting it straight down to make the initial break that allowed me to insert the spudger.
    jessica harlow - 回复
    I’ve given up using a plastic spudger to try to open any of these phones. I use a metal one with a flat base and a very sharp end…close to a razor. As long as I’m careful, it won’t slip and scratch the base. It’s much easier than using these plastic spudgers.
    mcr4u2 -
    I confirm that the plastic spudger it’s not the best tool for this operation. I suggest to use a larger metal tool like a “Jimmy” or “iSesamo open tool” (I used the first one)
    Cristef -
    Im trying to get the screen off right now and my phone is not cracked and its still a pain
    Jordon Johnson - 回复
    Using a blow dryer was extremely helpful and using the suction cup towards one of the lower edges was also helpful
    Jordon Johnson - 回复
    This is not working for me. How long does the heat need to be applied? Still trying right now…. =/
    Chris Gallego - 回复
    Apply hair dryer for at least 1 minute. I inserted the tip end of a thin mini screwdriver and with some force, pryed it open and inserted my plastic spudger to continue the separation process. It worked, just be patient.
    Please wear protective glasses! My iPhone glass was severely cracked, when separating the glass a corner area of broken glass exploded in my face. Apply transparent tape over the broken glass to contain the shards.
    amberron - 回复
    I second Jessica’s January 8 comment.  I just finished a battery replacement on my iPhone 7 and this step was the most nerve-wracking part.  I ended up using a sharper (but not razor-sharp) metal object to get this done with confidence (tried the spudger and guitar pick but not thin enough).  The tool I used was the exact duplicate of what iFixIt calls “iSesamo Opening Tool” in their tool selection.  I did the heat up with a hair dryer (after attempts with an iOpener hot pad) and the secret (as Jessica also noted)  was to not use the angle of attack shown in the pictures, but to push it in more vertically along the bottom edge while pulling up on the suction cup.  From there you can easily lever the tool to the lower angle-of-attack (as shown in the picture).  I actually used the metal tool for most of the perimeter as well, just don’t go deep (you don’t need to).  Notes: my display was intact, and I was able to pull up fairly hard with a glass screen protector still on it.
    Ted - 回复
    This is frustrating. I heated the lower edge with a hair dryer for 1 min on high about 3-4 times. In between each heat cycle, I rocked the suction cup back and forth. I was eventually able to create significant space for the provided tool. This takes a lot of patience. Once the space was created, it was very easy to remove the screen.
    Dan - 回复
    use a fingernail, then the blue tool, then the spudger
    Therese Peffer - 回复
    The iOpener worked just fine for me. Had to keep it on for a few minutes. I also was able to get the suction cup seal right close to the edge, over top of the home button for added leverage. Used the blue tool and transitioned to the spudger. Slow, steady pressure…and patience. ;)
    johnhall918 - 回复
    Unable to open an iPhone 7 display assembly. Used gell pack at 150 degrees F. The phone wouldn’t budge when I used the iFixit suction cut. Part of the problem is that the cup doesn’t adhere for long before it looses suction. I suspect it would work better on unbroken glass, but that doesn’t help me now. After spending a lot of time at this, I changed heating methods to a hot air heater. I raised the temp of the bottom end of the phone to, ultimately, 175 degrees, and used a variety of tools to try to pry the glass apart enough to get a spudger (or anything) in, but it didn’t even lift enough for a double-edged razor blade to get in. I’ve been trying this for hours now, and about to give up and throw a lot more money at this to have a service perform the work. I figured that 175 was as high as I should need to go to soften the adhesive without damaging the electronics. Should I have gone higher? I see no mention of measured temps in any instructions or comments.
    ted - 回复
    Have you tried applying tape to the broken screen? This will help a lot with keeping the suction cup on it.
    Christian Groothuis -
    It doesn’t need to get very hot; pulling up on the display is mainly what does the trick. Make sure the two pentalobe screws have been removed and then try the tricks in this step. If all else fails, superglue the suction cup to your display and let it cure, and then pull. Keep in mind you only need a tiny gap to insert a plastic pick and start cutting the adhesive. Good luck!
    Jeff Suovanen -
    Just a question. After this operation the impermeability function was compromitted?
    bentek86 - 回复
    The trick I found, was to add packing tape right across the bottom over the home button then use hairdryer on the end, then suction cup on the very bottom and it lifted enough to get a gap. No one mentioned how it would be impossible to handle the phone after the hairdryer ;)
    Andrew Lansdowne - 回复
    Didn’t have an iOpener and 60 seconds on a hairdryer wasn’t doing it for me. Still wouldn’t budge. I had to take a very sharp razor along the seam at the bottom between the speakers. It took about 20 passes for it to separate enough to get the spudger in. Make sure you keep the razor at a 90-45˚ angle and that it goes no more than 1-2mm into the phone. The bottom of the phone is metal, but the casing for the screen is plastic. So if you cut lower than a 45˚ (flat with the phone) you risk cutting into the casing. Apply light pressure when making the passes. I would just do the razor on the flat part on the bottom.
    minimalist - 回复
    I used a hair drier while lifting up at the same time until I could get the too inside. The seal is pretty finicky. Just take your time and you should be fine. Work the hair drier and the tool all the way around before lifting the screen up and off. There will likely be sealant stuck between the screen and phone. You can just break it with the tool.
    Ray Bieze - 回复
  5. 沿着iPhone的下边向左移动动撬棍。 移动撬棍以扩大屏幕和后壳之间的间隙。 移动撬棍以扩大屏幕和后壳之间的间隙。
    • 沿着iPhone的下边向左移动动撬棍。
    • 移动撬棍以扩大屏幕和后壳之间的间隙。
    minimalist - 回复
    I used a hairdryer and a razor
    Gina Torres - 回复
  6. 将撬棍头从iPhone左侧拉出,从下边缘开始,朝向音量控制按钮和静音开关移动。 不要沿着手机的顶部边缘撬动,否则有可能损坏固定屏幕的塑料卡子。 不要沿着手机的顶部边缘撬动,否则有可能损坏固定屏幕的塑料卡子。
    • 将撬棍头从iPhone左侧拉出,从下边缘开始,朝向音量控制按钮和静音开关移动。
    • 不要沿着手机的顶部边缘撬动,否则有可能损坏固定屏幕的塑料卡子。
    Be VERY careful on this next step going up the right side of the phone. There is a ribbon cable 1/3 of the way up from the bottom that is very close to the edge. Do NOT use the blue triangle!!!! Just lightly rotate the spudger to get separation on the edge.
    Timothy Varvais - 回复
  7. 将撬棍的头插入设备的右下角 移动撬棍以扩大屏幕和后壳之间的间隙。 将撬棍的头滑动,从而打开屏幕固定胶
    • 将撬棍的头插入设备的右下角
    • 将撬棍的头滑动,从而打开屏幕固定胶
  8. 上拉吸盘抬起屏幕从而打开iPhone。 请勿将掀开超过10°以上,因为在手机的右边有链接屏幕到显示器的排线
    • 上拉吸盘抬起屏幕从而打开iPhone。
    • 请勿将掀开超过10°以上,因为在手机的右边有链接屏幕到显示器的排线
    do not pull up pull sideways it will brake
    Riley Patterson - 回复
    Made this mistake
    rachael.grime - 回复
  9. 拨弄吸盘上的小尖,从而将吸盘从屏幕上取下。
    • 拨弄吸盘上的小尖,从而将吸盘从屏幕上取下。
  10. 沿着iPhone的顶部边缘滑动拆机片,将屏幕与外壳彻底分离 小心不要损坏手机顶部的卡扣。
    • 沿着iPhone的顶部边缘滑动拆机片,将屏幕与外壳彻底分离
    • 小心不要损坏手机顶部的卡扣。
    The plastic clips mentioned are on the top of the screen being replaced… so not sure why it matters not to break them. Trick here was to pull the screen downwards to open a gap at the top and then insert as shown and raise to break the seal.
    This is relevant for other guides than the display replacement guide.
    jvalaamo -
  11. 从手机底端将屏幕略微抬起 通过从左侧拉动显示屏来打开iPhone,就像翻一本书的封底。 不要尝试完全取下屏幕,因为几个脆弱的排线仍然连接着iPhone主板。
    • 从手机底端将屏幕略微抬起
    • 通过从左侧拉动显示屏来打开iPhone,就像翻一本书的封底。
    • 不要尝试完全取下屏幕,因为几个脆弱的排线仍然连接着iPhone主板。
    I just broke the cable to the battery!
    No Bama - 回复
    same dude im such a freak lol omg haha
    Aiden Polaski - 回复
    Are there replacements ribbons?
    Blax Bently - 回复
    Has anyone else noticed very small squares of rubber with a circle cut through it (I think they fall off into the phone when dismantling)?
    I just replaced my screen and worked out that these are actually a wee pocket that slips over the pentalobe screw holes on the replacement screen. I’m not sure if it’s an additional water resisting mechanism or if it’s to add additional traction for the screws
    richarddillon - 回复
    Thanks, I was wondering where those were from!
    Albert -
    I just broke cable connecting camera and earpiece speaker to logic board. Be careful with it.
    Natan Haładyn - 回复
    This section is missing a critical step - to lay some Post-It notes or something below the right half of the phone when you swing it open, so the ribbon cables don’t get sliced by the sharp edge of the phone case. I broke the Home Button ribbon cable because there was no strain relief when I laid it open.
    neila - 回复
    I also broke the home button cable and now I have to use assistive touch.
    Laurencio Gonzalez - 回复
    Keep the suction cup on the display to keep it propped up while you disconnect the ribbon cables.
    minimalist - 回复
    I broke the short ribbon cable that attaches underneath the lower connector bracket. Be SURE when you lift the display, you do it from left to right. I thought I had the phone oriented correctly in my hand, but I was mistaken.
    John Murray - 回复
    Put the suction cup on the right side of the middle of the screen when you rotate it up and out. It serves as a nice stand to take the pressure off the connectors.
    Ray Bieze - 回复
    • 从下侧连接器支架上拆下以下长度的四颗三点式 Y000 螺丝:
    • 三个1.2mm螺丝
    • 一个2.4 mm螺丝
    • 维修过程中,使用磁性垫来记住每颗螺丝所对应的位置,避免重新安装的过程中螺丝安装错位损伤您的手机。
    Ahhh shoot! accidentally ordered tri-wing vs tri-point (must have just looked for y000).. It seems they only did this to annoy repair folks because not everything is tri-point on the phone...
    Steve - 回复
    These screws just spin for me. They don't back out, but the heads aren't stripped either. I've tried applying backpressure to help lift the screws, but no luck
    Jeff Hurst - 回复
    The Y000 took out one of the screws but not the other 3. I even tried the PH000 as suggested but nothing.
    dbright - 回复
    What driver do I need to remove these screws i’m stuck
    Nasser Nader - 回复
    i cant use, the Y000 it isnt working.
    joscarlos91 - 回复
    What if I stripped a screw what do I do??
    Jacob Ramos - 回复
    Yep, only the 2.4mm came out, other 3 won’t budge, and worried I’ve stripped the heads. Anyone got any ideas?
    Stephen Babbage - 回复
    It’s the screwdriver bit that is the problem. I had the same issue with 2 Y000 bits not grabbing the screw properly. I fixed it by using a small 3 sided file to slightly grind the groves in the Y000 bit just a bit deeper. Then the bit worked like a charm on these screws.
    Jim Staples - 回复
    Use Y000 on all 4. U have to be very sensitive on the 1.2mm screws. Put the bit in the screw, put the left pointing finger on top of the screwdriver and turn the driver carefully to the right until you feel a “bump”, thats the trick :-), then you are able to screw the screw out.
    Magne Eivindson - 回复
    For me the key here was a LOT of downward pressure to ensure the Y000 bit caught in the screw. Not sure i can describe how much exactly, but is was significant. Otherwise the bit would not catch.
    Erik Fredriksen - 回复
    What do I do if I Stripped one of them?
    Adam Corral - 回复
    Can’t get them removed what to do ?
    cowling_luke - 回复
    Managed to get the central one out. The upper one won't move, the lower one I've popped out with some force. This allows you to rotate the cover enough to unplug the various bits. Not ideal, but works. I've tried applying a lot of pressure, using the tighten/ loosen method, but the heads have just got mashed… no wonder Samsung are now No1, sigh…
    jimpoolio - 回复
    You need to be careful when just rotating the cover as you can accidentally slice through the two black antennas! You only need to nip them…As you can tell I have done this in the past :/
    Kyle Webb -
    The first, longer screw came out fine, but the other three wouldn’t budge, regardless of more/less pressure or a slight angle or anything. I finally filed down the tip of the Y000 bit ever so slightly, and then it worked. Hope this helps someone.
    Harmony Vine - 回复
    Filing down the bit worked for me. The tip about putting an index finger on the end of the screwdriver handles and then turning gently until it clicks into place was very helpful! Using these 2 tips I didn't need much downward pressure. Screws are out in a few turns.
    Chris Bennett - 回复
    If you can’t get the bit to grip the screw properly, you can use a little bit of the water-proof sealing between the bit and the screw. That worked for me. Hope this helps anyone.
    jvalaamo - 回复
    Mine came out easily. I placed the screws in the area where the bit goes in my kit so I can keep track.
    Gina Torres - 回复
    I used a bunch of medicine cups to track my screws. You need like 12 if you want them all in cups. I ran out. There are so many different sizes that literally vary by 1mm. The tolerances on these things are tight.
    Ray Bieze - 回复
  12. 卸下下侧连接器支架。
    • 卸下下侧连接器支架。
    my battery cable connector was stuck to the bottom of this metal bracket plate so be careful when you lift it off
    Josh Martin - 回复
    This may have been intentionally done by Apple to make sure the battery gets disconnected before any other connector is disconnected. So always make sure to disconnect the battery before disconnecting and reconnecting the connectors for the display.
    Oscar Moreno - 回复
  13. 使用撬棒尖端将电池连接器从逻辑主板上的插座中翘起。 将连接器电缆略微弯曲,以防止它与插座接触并继续向手机供电。 将连接器电缆略微弯曲,以防止它与插座接触并继续向手机供电。
    • 使用撬棒尖端将电池连接器从逻辑主板上的插座中翘起。
    • 将连接器电缆略微弯曲,以防止它与插座接触并继续向手机供电。
    Was kann passieren wenn man diesses Kabel vergessen hat zu entfernen `?
    Julian Eltrich - 回复
  14. 在该步骤中,断开或重新连接排线之前,请确保电池已经断开连接。 使用撬棒或者指甲来将两条显示排线从逻辑板上的插座中撬出。 来连接这些排线插头的时候,先按压插头的一侧来确保其已经安装到位,然后再按压另一端。 切勿在中部按压。 如果插头稍微不对准,插头可能会弯曲,造成永久性损坏。
    • 在该步骤中,断开或重新连接排线之前,请确保电池已经断开连接。
    • 使用撬棒或者指甲来将两条显示排线从逻辑板上的插座中撬出。
    • 来连接这些排线插头的时候,先按压插头的一侧来确保其已经安装到位,然后再按压另一端。 切勿在中部按压。 如果插头稍微不对准,插头可能会弯曲,造成永久性损坏。
    • 如果在重新安装显示屏后,发生显示屏无法显示内容、显示白线、部分或全部触摸失灵等情况,请重新连接排线插头,确保安装到位。
    To be honest you don’t really need to disconnect the display cables in step 15 or 16 to get the battery out. Just keep the suction cup on the screen to keep it propped up and to give the cables some slack. The only reason to take these cables off is that it’s a pain to apply the replacement display adhesive with those cables in the way. If you’re not re-waterproofing your phone just leave these attached.
    iPhone显示屏粘合胶的更换
    minimalist - 回复
  15. 拆下固定前面板感应器组排线支架的两颗 1.3mm P000十字螺丝。 取下支架。 取下支架。
    • 拆下固定前面板感应器组排线支架的两颗 1.3mm P000十字螺丝。
    • 取下支架。
    Has anyone had trouble getting these two screws off? I’ve been working on these for about 10 minutes and the LEFT screw wont spin. It seems like the little PH000 screwdriver bit won’t even grip it. (The one of the right comes off, no problem)
    It looks like I’ll have to pick this project up again with a screwdriver that will actually take off this piece.
    Makana Sylva - 回复
    The right screw kept spinning, tried different levels of force but didn’t work. I left the screw on and bent the shield to get to the cable.
    s h - 回复
    I used a #1 flat head tip to loosen.
    Peter Pearson - 回复
    I couldn’t get the two screws out either—used the correct screw tip and everything. Stripped the screw. Will now attempt to just keep the cable attached…..
    Therese Peffer - 回复
    Use the PH000 and apply a little more force before spinning, should come right out!
    Sierra Scolaro - 回复
    ^To anyone having trouble, this is the correct answer. Put the phone on a firm surface, align your driver carefully, press down hard, and twist. As long as your driver is approximately the right size, it’ll come out.
    Jeff Suovanen -
    the two screw i have are stripped and i have n way of getting either screws off whats my next bet
    Alexis Marie Colon - 回复
    The PH000 bit is to large. I can’t get the screws out either which really sucks…now I have to put everything back together, find another bit that will work and try this again another day. Not impressed with IFIXIT’s attention to detail so far :-(
    Ryan Welborn - 回复
    Using iFixit’s driver kit, I prefer a PH00 for this, which is larger than the PH000. If you think the PH000 is too big, something is wrong.
    Jeff Suovanen -
    I think part of the issue with the iFixit PH000 is that it is slightly too pointy. The PH00 fits better because the splines engage the slots of the screw before the point bottoms out. The PH000 tip bottoms out in the screw’s center point and the splines don’t engage as well. I have other PH000 tips that are more blunt nose and they work better than the iFixit bit.
    rcarswell - 回复
    Use the J00 bit. Worked perfectly
    efazio588 - 回复
    PH000 screwdriver didn’t work for any of these screws, or the barometric vent, or the taptic engine. It was too big. I had to use a different screwdriver from another kit I had.
    minimalist - 回复
    I’d do this step before removing the ribbon cables by the battery connector. That way you can disconnect all of them at the same time.
    Ray Bieze - 回复
  16. 从主板的插座上断开前面板传感器组件排线插头。 重新连接该插头的时候也应该先从一侧开始按压,将损坏的风险降到最小。
    • 从主板的插座上断开前面板传感器组件排线插头。
    • 重新连接该插头的时候也应该先从一侧开始按压,将损坏的风险降到最小。
    Das ist sehr mutig, das Kabel dort so zu strapazieren.
    Mich würde das Display daneben stellen und mit irgendetwas stützen, dass es nicht umkippen kann um Beschädigungen an dem Kabel zu vermeiden. Das reißt sehr schnell ein.
    Detlef Menninger - 回复
    Is this the connector for the earpiece, as well? I did the screen replacement and everything worked, except now I can’t use my earpiece… I’m afraid I didn’t fully connect this particular portion.
    Victor Bui - 回复
    @victorbui714 Correct, this is also the connector for the earpiece speaker. Check the flex cable carefully and make sure it wasn’t pinched or torn. Make sure the connector socket is clean (give it a blast with some compressed air if needed) and try reseating it. If that doesn’t help, you may want to remove the earpiece speaker and inspect the four springs on the back, and check that they’re intact and making good contact with the four circular pads on the flex cable. Give the pads a wipe with some IPA and try not to leave any skin oils on them. If none of that works, try replacing the entire flex cable/sensor assembly. Good luck!
    Jeff Suovanen -
  17. 移除显示屏部件。
    When removing the screen, be aware of the two tiny square black rubber grommets on the Penelope screw brackets that secure the screen. They can fall off very easily and be lost without even knowing it (it happened to me, but was lucky enough to find them).
    Guy Cooley - 回复
    Sorry, I’m so unclear about when to replace the Adhesive tape. Should I put the iPhone 7 Display Assembly Adhesive at this step, or after I’ve replaced the battery?
    Victor Bui - 回复
    @victorbui714 Battery first, then adhesive during reassembly, as it says in the instructions. ;)
    Jeff Suovanen -
    This is the 3rd screen iv put in my phone and everyone them bust at the top by the camera every time iv bought one of these screen idk if it’s the manufactures fault or what?
    trent bost - 回复
    @trentb28922 Ouch! That’s not normal. Is your phone’s frame bent? Are you having to use a lot of force when you install the display?
    Jeff Suovanen -
  18. 将SIM卡取出工具或曲别针插入SIM卡托上的小孔。 将工具向内捅。 可能需要用力一些。
    • 将SIM卡取出工具或曲别针插入SIM卡托上的小孔。
    • 将工具向内捅。
    • 可能需要用力一些。
    • 从手机上卸下SIM卡托。
    • 当插入SIM卡时,请确认相对卡托的方向是正确的。
    Received a sim card tray from IFIXIT for my iphone 7. I can’t seem to get it to close flush no matter how hard I try. Any suggestions?
    AJ Dereume - 回复
  19. 使用撬棒(Spudger)的平端断开后置摄像头的连接器。 使用撬棒(Spudger)的平端断开后置摄像头的连接器。
    • 使用撬棒(Spudger)的平端断开后置摄像头的连接器。
  20. 卸下以下两种固定后置摄像头支架到后盖的P000 十字螺丝: 一颗1.3mm螺丝
    • 卸下以下两种固定后置摄像头支架到后盖的P000 十字螺丝:
    • 一颗1.3mm螺丝
    • 一颗2.5mm螺丝
    I couldn’t get my 1.3mm screw out. It’s not required thankfully as you can just bend the cover up and out of the way to complete the rest of the steps.
    Ray Bieze - 回复
  21. 卸下支架。
    • 卸下支架。
  22. 使用撬棒的尖端以断开闪光灯线缆连接器。 使用撬棒的尖端以断开闪光灯线缆连接器。
    • 使用撬棒的尖端以断开闪光灯线缆连接器。
  23. 卸下2颗固定上部线缆支架的 1.2mm Y000 三点螺丝。
    • 卸下2颗固定上部线缆支架的 1.2mm Y000 三点螺丝。
  24. 卸下上部线缆支架。 卸下上部线缆支架。
    • 卸下上部线缆支架。
  25. 使用撬棒的平端断开上部线缆的连接器。 使用撬棒的平端断开上部线缆的连接器。
    • 使用撬棒的平端断开上部线缆的连接器。
  26. 卸下以下两种固定 Wi-Fi 天线的 P000 十字螺丝: 三颗1.2mm螺丝
    • 卸下以下两种固定 Wi-Fi 天线的 P000 十字螺丝:
    • 三颗1.2mm螺丝
    • 一颗1.7mm螺丝
    I lost one of these 1.2 mm screws. Will that affect the signal reception?
    Bethany Knaebel - 回复
    There is another screw connecting the antenna to the case.
    tbaiello - 回复
  27. 卸下顶部左侧的天线。 卸下顶部左侧的天线。
    • 卸下顶部左侧的天线。
    ** also remove the small Phillips screw fastening the WiFi antenna to the top rear casing of the phone
    iBroke - 回复
  28. 卸下以下两种 P000 十字螺丝:
    • 卸下以下两种 P000 十字螺丝:
    • 一颗1.3mm螺丝
    • 一颗2.2mm螺丝
  29. 卸下支架。 卸下支架。
    • 卸下支架。
    What's this bracket called
    Cris Velasquez - 回复
    %#*@, lost that part during the job, thought it’d be alright without it. Couple days later figured out NFC doesn’t work anymore. Any ideas on where to get this part from, colleagues?
    azowux - 回复
  30. 从接地支架处卸下 2.2mm 压铆螺柱螺丝。
    • 从接地支架处卸下 2.2mm 压铆螺柱螺丝。
    • 你可以通过专用的压铆螺柱螺丝刀螺丝刀组更轻松地卸下它们。
    • 当然一把小平头螺丝刀也是可以的,但要注意不要损伤周边元件。
    What bit is this? The link doesn’t use the same name.
    Mike Moran - 回复
    I didn’t even have an eyeglass repair kit flathead, so I hit the end of a paperclip with a hammer to make a flathead, and it works!
    Ark - 回复
    I hate getting the deep into a repair to find there’s a tool missing. This bit should be part of the toolkit!
    Ark - 回复
    I received two boxes - one box contained the repair part, the other was the tool kit. I only opened the tool kit before disassembling the phone. The standoff screwdriver bit was not in there. Neither was the guitar pick. I used a real guitar pick and a small standard screwdriver from my toolbox. When I was ready to reassemble, I opened the repair part box and guess what was in there - the standoff screwdriver bit and guitar pick. So, I guess if you just order the part it will come with (at least) those two tools. The tool kit contains tweezers, suction cup, three screwdriver bits (tri-point, pentalobe, and phillips) and screwdriver handle, a long black spudger with a flat end and a pointy end, and a smaller, thicker spudger with a wide, flat ends.
    bronyaur - 回复
    The flat end of the spudger works a treat too.
    Robert Trammel - 回复
  31. 使用镊子轻轻地弯曲分离主板边缘支架。 使用镊子轻轻地弯曲分离主板边缘支架。
    • 使用镊子轻轻地弯曲分离主板边缘支架。
  32. 使用一个撬棒将两天线电缆连接器的插座分离逻辑板。 使用一个撬棒将两天线电缆连接器的插座分离逻辑板。 使用一个撬棒将两天线电缆连接器的插座分离逻辑板。
    • 使用一个撬棒将两天线电缆连接器的插座分离逻辑板。
  33. 用镊子轻轻的将天线电缆从逻辑板金属支架上移除。 用镊子轻轻的将天线电缆从逻辑板金属支架上移除。 用镊子轻轻的将天线电缆从逻辑板金属支架上移除。
    • 用镊子轻轻的将天线电缆从逻辑板金属支架上移除。
  34. 使用一个撬棒尖端断开下电缆连接器。 使用一个撬棒尖端断开下电缆连接器。
    • 使用一个撬棒尖端断开下电缆连接器。
  35. 拆下下列螺钉:
    • 拆下下列螺钉:
    • 一颗1.4 mm 十字螺丝
    • 三颗 2.2 mm 压铆螺柱螺丝
    • 简单来说,一个平头的螺丝刀就可以做到了——但是需要额外地小心,确保不要损坏周围部件。
  36. 使用一个撬棒尖端移动SIM卡弹出柱塞从逻辑板上移除。 使用一个撬棒尖端移动SIM卡弹出柱塞从逻辑板上移除。
    • 使用一个撬棒尖端移动SIM卡弹出柱塞从逻辑板上移除。
  37. 使用一个撬棒平端轻轻抬起逻辑板电池连接器。 确保所有电缆都已断开。如果你觉得没有,请检查所有的电缆,连接器和组件是否真的断开。
    • 使用一个撬棒平端轻轻抬起逻辑板电池连接器。
    • 确保所有电缆都已断开。如果你觉得没有,请检查所有的电缆,连接器和组件是否真的断开。
  38. 提起逻辑板的电池接头端并将其拔出后盖。 小心不要有任何电缆还插在逻辑板上。 小心不要有任何电缆还插在逻辑板上。
    • 提起逻辑板的电池接头端并将其拔出后盖。
    • 小心不要有任何电缆还插在逻辑板上。
  39. 卸下两颗将气压计固定到后壳的1.9mm P000 十字螺丝。
    • 卸下两颗将气压计固定到后壳的1.9mm P000 十字螺丝。
  40. 卸下气压计。 卸下气压计。
    • 卸下气压计。
  41. 使用一个撬棒平端从逻辑板插座断开taptic发动机连接器。 使用一个撬棒平端从逻辑板插座断开taptic发动机连接器。
    • 使用一个撬棒平端从逻辑板插座断开taptic发动机连接器。
  42. 拆下三个1.6毫米十字螺钉固定taptic引擎后的情况。
    • 拆下三个1.6毫米十字螺钉固定taptic引擎后的情况。
  43. 去除taptic引擎 去除taptic引擎
    • 去除taptic引擎
  44. 用一把钝尖镊子将电池背面的一条胶带撕下来。 用一把钝尖镊子将电池背面的一条胶带撕下来。 用一把钝尖镊子将电池背面的一条胶带撕下来。
    • 用一把钝尖镊子将电池背面的一条胶带撕下来。
  45. 用一把钝尖的镊子把电池边缘下的另一条胶带撕下来。 用一把钝尖的镊子把电池边缘下的另一条胶带撕下来。
    • 用一把钝尖的镊子把电池边缘下的另一条胶带撕下来。
  46. 尝试在此过程中保持条平折皱;皱条会粘在一起,而不是拉出来休息。 慢慢地拉一个电池胶标签远离电池,对iPhone的底部。 稳步拉,保持恒定张力的条带,直到它滑出之间的电池和后方的情况下。最好的结果是,把带在60º角或更少。
    • 尝试在此过程中保持条平折皱;皱条会粘在一起,而不是拉出来休息。
    • 慢慢地拉一个电池胶标签远离电池,对iPhone的底部。
    • 稳步拉,保持恒定张力的条带,直到它滑出之间的电池和后方的情况下。最好的结果是,把带在60º角或更少。
    • 本条将许多倍的原始长度。继续拉,再拿条在电池附近,如果必要的话。
  47. 第二条重复上一步。
    • 第二条重复上一步。
    • 在拆卸第二条带时,请按住电池,否则当电池与外壳分开时,电池可能会甩出电池。
    • 如果你移除胶带成功,跳过下一步。
    • 否则,如果有一条胶带在电池下面断了,无法收回,请继续下一步。
  48. 如果你成功地移除胶带,继续下一步。否则,你将需要从后盖撬开电池。 准备一个适用于iOpener的后盖后,电池直接在。或者,你可以加热用热风枪或电吹风。
    • 如果你成功地移除胶带,继续下一步。否则,你将需要从后盖撬开电池。
    • 准备一个适用于iOpener的后盖后,电池直接在。或者,你可以加热用热风枪或电吹风。
    • 大约一分钟后,取出iOpener,翻转手机和使用塑料卡打破任何剩余的粘合剂落后电池。
    • 避免弯曲电池。对电池的损伤可释放有害的化学物质,并能引起火灾。
    • 不要把电池的前第三下,你可能会损坏音量键排线。
  49. 移除电池。
    • 移除电池。
    • 安装电池时,参考本指南来取代您的电池的胶条。
  50. 移除下列 P000 十字螺丝: 两颗1.9 mm螺丝固定电源按钮。
    • 移除下列 P000 十字螺丝:
    • 两颗1.9 mm螺丝固定电源按钮。
    • 三颗2.3 mm螺丝固定音量按钮。
  51. 移除以下 1.3 mm P000十字螺丝: 一个螺丝在后置摄像头上
    • 移除以下 1.3 mm P000十字螺丝:
    • 一个螺丝在后置摄像头上
    • 一颗螺丝在后壳上
  52. 使用撬棒的尖端,从手机外侧将静音开关推入后壳。 该操作将带出固定静音开关的橡胶圈。
    • 使用撬棒的尖端,从手机外侧将静音开关推入后壳。
    • 该操作将带出固定静音开关的橡胶圈。
  53. 使用镊子移除后置摄像头。 使用镊子移除后置摄像头。
    • 使用镊子移除后置摄像头。
  54. 使用拨片,从电源键一侧开始,剥离天线排线下方的粘胶。 使用拨片,从电源键一侧开始,剥离天线排线下方的粘胶。
    • 使用拨片,从电源键一侧开始,剥离天线排线下方的粘胶。
  55. 将拨片在天线排线下向手机顶端划动,剥离剩余粘胶。 将拨片在天线排线下向手机顶端划动,剥离剩余粘胶。
    • 将拨片在天线排线下向手机顶端划动,剥离剩余粘胶。
  56. 使用镊子移动天线排线,从下方的支架上脱离 移除天线排线。
    • 使用镊子移动天线排线,从下方的支架上脱离
    • 移除天线排线。
  57. 移除固定闪光灯支架上的 2.3mm 子母螺丝。
    • 移除固定闪光灯支架上的 2.3mm 子母螺丝。
    • 你可以用专用的iPhone子母螺丝刀把它们去掉,必要时也可以使用一个小的一字型螺丝刀。
    • 简单来说,平头螺丝刀可以胜任——但是需要格外小心不要损坏周围部件。
  58. 移除闪光灯支架。 移除闪光灯支架。
    • 移除闪光灯支架。
  59. 使用撬棒的尖端轻轻地将闪光灯抬起。 使用撬棒的尖端轻轻地将闪光灯抬起。
    • 使用撬棒的尖端轻轻地将闪光灯抬起。
  60. 使用 Halberd 叶片式撬棒将麦克风下的粘胶剥离。 使用 Halberd 叶片式撬棒将麦克风下的粘胶剥离。
    • 使用 Halberd 叶片式撬棒将麦克风下的粘胶剥离。
  61. 轻轻地将电源键模组从后壳向内弯曲。 轻轻地将电源键模组从后壳向内弯曲。
    • 轻轻地将电源键模组从后壳向内弯曲。
  62. 使用撬棒从电源键处排线的下方开始,剥离其下部的粘胶。 继续朝手机上方移动撬棒剥离粘胶。 继续朝手机上方移动撬棒剥离粘胶。
    • 使用撬棒从电源键处排线的下方开始,剥离其下部的粘胶。
    • 继续朝手机上方移动撬棒剥离粘胶。
  63. 继续移动撬棒剥离音量电源排线。 慢慢移动以确保排线在剥离过程中不会损坏。 慢慢移动以确保排线在剥离过程中不会损坏。
    • 继续移动撬棒剥离音量电源排线。
    • 慢慢移动以确保排线在剥离过程中不会损坏。
  64. 滑动撬棒移除音量控制下的部分排线。 轻轻地向下划动撬棒刃部,剥离剩余的粘胶。 轻轻地向下划动撬棒刃部,剥离剩余的粘胶。
    • 滑动撬棒移除音量控制下的部分排线。
    • 轻轻地向下划动撬棒刃部,剥离剩余的粘胶。
  65. 拆下电源和音量控制电缆。
    • 拆下电源和音量控制电缆。
结论
将您的设备,遵循这些指示,逆向重组。
22等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Scott Havard
于2016年06月27日注册
35,717 信誉积分
创作了33篇指南
Hello,
how can I disassemble and assemble the mute button from the flex cable. because most spare part cables are without mute button…
thanks
Martin - 回复
the mute button can slide out. there is space on the side that is not marked red. it looks like three clips hold it in but simply grab hold of the button nob thing with tweezers and slide or wedge it out from underneath that bar that goes around the side with the red line and then once it’s out you can slip that button into the new flex
reymito sanchez -
Well theres 2 hours of my life I’m not getting back, worked a treat though…
Trig0r - 回复
添加评论
浏览统计数据:
过去的24小时: 26
过去的7天: 149
过去的30天: 677
总计 20,735
