工具
视频概述
加热手机的下部可以软化屏幕下方的粘胶,使屏幕更容易被打开。
¿Cuántos segundos son los recomendados?
Sesenta segundos
Absolutely. Just don’t overdo it—the adhesive usually softens up pretty easily. If you are experienced with a heat gun, you’ll have no problem. (If you are inexperienced, it’s easy to cook the display or cause other damage.)
If i use this process, will iphone 7 still be sealed, water/ splash resist after that?
Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Can I use a cpb heating pad to soften the adhesive ? If yes how much time and temperature ?
Will doing this compromise the screen protector (Zagg) that I have on my phone?
Eric Nance - 回复
Hairdryer worked for me but I needed to use a razor to pry it open at the bottom then used the spudger
Is there a reason why you wouldn’t put the iopener over the entire length of the phone, instead of just the bottom corner?
The motherboard is extremely sensitive to heat.
Hello can the head damage the id touch bottom?
After heating opening it stoped working.
Qrizmasex @ gmail . Com
It definitely can. That happened to me.
I just threw a hand towel in hot water, and then stuck it into a plastic bag. Dryers work fine, too.
Thanks for this, the other instructions make it seem SOOOOO simple to open up the case with the suction cup! It actually is hellish. The instruction here about the pre-heating and the required patience really helped!
For those of you who don’t have an iOpener or a girlfriend, I used a ziplock bag with some instant mashed potato inside. It worked perfectly first time and you can fold the bag around the ID button in order to prevent damage to it.
You also get to celebrate by eating the mash afterwards, HUZZAH!
I found this to be completely useless. It didn’t help at all. I had to use a heat gun instead. Waste of money.
将吸盘吸到显示屏的下半部分,Home按键的上方。
A wide, single strip of packing tape, well placed, will solve this for you. :)
Mimic44444 - 回复
Last comment works well. Thank you !
Using packing tape for a cracked screen should be included in the description in Step 3.
Cracked screen is most probably the reason you are replacing it.
I agree that using packing tape for a cracked screen should be included in this steps description. I don’t have wide but turned mine horizontal and that worked great.
Mary Knapp - 回复
Bekomme die Oberschale einfach nicht runter! Trotz mehrmaligem erwärmen durch den iOpener und seitlichen bewegen! Weiß nicht mehr weiter!
Wouldn’t that screw up the Touch ID?
Rexx Havok - 回复
拉起吸盘,使显示屏组件和外壳之间形成一个小缝隙。
将撬棒平面那头插进缝隙。
This was SO hard for me to do with the spudger. I couldn’t get a gap to insert it because my phone was so cracked (even though I used tape on the front) to get a solid seal with the suction cup. I ended up taking a VERY thin knife and inserting it straight down to make the initial break that allowed me to insert the spudger.
I’ve given up using a plastic spudger to try to open any of these phones. I use a metal one with a flat base and a very sharp end…close to a razor. As long as I’m careful, it won’t slip and scratch the base. It’s much easier than using these plastic spudgers.
mcr4u2 -
I confirm that the plastic spudger it’s not the best tool for this operation. I suggest to use a larger metal tool like a “Jimmy” or “iSesamo open tool” (I used the first one)
Cristef -
Im trying to get the screen off right now and my phone is not cracked and its still a pain
Using a blow dryer was extremely helpful and using the suction cup towards one of the lower edges was also helpful
This is not working for me. How long does the heat need to be applied? Still trying right now…. =/
Apply hair dryer for at least 1 minute. I inserted the tip end of a thin mini screwdriver and with some force, pryed it open and inserted my plastic spudger to continue the separation process. It worked, just be patient.
Please wear protective glasses! My iPhone glass was severely cracked, when separating the glass a corner area of broken glass exploded in my face. Apply transparent tape over the broken glass to contain the shards.
I second Jessica’s January 8 comment. I just finished a battery replacement on my iPhone 7 and this step was the most nerve-wracking part. I ended up using a sharper (but not razor-sharp) metal object to get this done with confidence (tried the spudger and guitar pick but not thin enough). The tool I used was the exact duplicate of what iFixIt calls “iSesamo Opening Tool” in their tool selection. I did the heat up with a hair dryer (after attempts with an iOpener hot pad) and the secret (as Jessica also noted) was to not use the angle of attack shown in the pictures, but to push it in more vertically along the bottom edge while pulling up on the suction cup. From there you can easily lever the tool to the lower angle-of-attack (as shown in the picture). I actually used the metal tool for most of the perimeter as well, just don’t go deep (you don’t need to). Notes: my display was intact, and I was able to pull up fairly hard with a glass screen protector still on it.
This is frustrating. I heated the lower edge with a hair dryer for 1 min on high about 3-4 times. In between each heat cycle, I rocked the suction cup back and forth. I was eventually able to create significant space for the provided tool. This takes a lot of patience. Once the space was created, it was very easy to remove the screen.
use a fingernail, then the blue tool, then the spudger
The iOpener worked just fine for me. Had to keep it on for a few minutes. I also was able to get the suction cup seal right close to the edge, over top of the home button for added leverage. Used the blue tool and transitioned to the spudger. Slow, steady pressure…and patience. ;)
Unable to open an iPhone 7 display assembly. Used gell pack at 150 degrees F. The phone wouldn’t budge when I used the iFixit suction cut. Part of the problem is that the cup doesn’t adhere for long before it looses suction. I suspect it would work better on unbroken glass, but that doesn’t help me now. After spending a lot of time at this, I changed heating methods to a hot air heater. I raised the temp of the bottom end of the phone to, ultimately, 175 degrees, and used a variety of tools to try to pry the glass apart enough to get a spudger (or anything) in, but it didn’t even lift enough for a double-edged razor blade to get in. I’ve been trying this for hours now, and about to give up and throw a lot more money at this to have a service perform the work. I figured that 175 was as high as I should need to go to soften the adhesive without damaging the electronics. Should I have gone higher? I see no mention of measured temps in any instructions or comments.
Have you tried applying tape to the broken screen? This will help a lot with keeping the suction cup on it.
It doesn’t need to get very hot; pulling up on the display is mainly what does the trick. Make sure the two pentalobe screws have been removed and then try the tricks in this step. If all else fails, superglue the suction cup to your display and let it cure, and then pull. Keep in mind you only need a tiny gap to insert a plastic pick and start cutting the adhesive. Good luck!
The trick I found, was to add packing tape right across the bottom over the home button then use hairdryer on the end, then suction cup on the very bottom and it lifted enough to get a gap. No one mentioned how it would be impossible to handle the phone after the hairdryer ;)
Didn’t have an iOpener and 60 seconds on a hairdryer wasn’t doing it for me. Still wouldn’t budge. I had to take a very sharp razor along the seam at the bottom between the speakers. It took about 20 passes for it to separate enough to get the spudger in. Make sure you keep the razor at a 90-45˚ angle and that it goes no more than 1-2mm into the phone. The bottom of the phone is metal, but the casing for the screen is plastic. So if you cut lower than a 45˚ (flat with the phone) you risk cutting into the casing. Apply light pressure when making the passes. I would just do the razor on the flat part on the bottom.
minimalist - 回复
I used a hair drier while lifting up at the same time until I could get the too inside. The seal is pretty finicky. Just take your time and you should be fine. Work the hair drier and the tool all the way around before lifting the screen up and off. There will likely be sealant stuck between the screen and phone. You can just break it with the tool.
This step was impossible for me despite using a blow dryer and having no cracks on the screen. I finally took it to a local repair place and had them do battery replacements for two iPhone 7’s. The girl let me watch her do it. She used a razor blade (just until she had a small opening that she could hold open with her fingernail) and confirmed that she too would have difficulty opening it with a plastic tool and suction cup. The plastic tool was great for prying the rest of it open once a crack was there, but she said she would never try to use that as the tool to initially open it. The tools provided for initially prying open the screen are inadequate.
Chad Twedt - 回复
Hopeless - no chance to get the screen off without any damage. No matter what tools, heat etc.
When the right heat is reached, the easiest way is to use a metal iFlex to create the initial gap, then insert the Jimmy or iSesamo next to it so the gap gets bigger, at this point you can get in with the flat edge of a plastic spudger and slowly slide it in the borders to cut the adhesive. You will still need to force a bit the upper end to separate the screen by pulling it down while keeping up the screen, and twist to the right. I hope this is clear enough. Never apply too much strength too quickly anyway.
I used the short blade of my swiss knife to make an initial opening. Using the sharp edge, inserting about 1 mm straight down and twisting down into a 45° angle. Then I was able to insert the spudger.
This is a difficult step. Fortunately, I had another suction cup from an earlier repair available, so I applied one to each side of the phone. After warming with a hair dryer, I was able to pull the two suction cups far enough away that another person could easily insert the spudger.
The third hand was essential.
I found this tactic to be the best solution for us. I used two suction cups, one on each side of the phone, and another set of hands to get a pry tool under the display. We still had to take our time prior while heating the adhesive, but were able to pry the display fairly easily using the two suction cup method.
Lucas -
It was a really excruciating process of heating, lifting with the suction cup, trying to slide in the spudger/pick, and repeating the process for 20 times or so. But in the end, my patience paid off!
I used a hair dryer, then used a safety razor blade parallel to the bottom edge to push straight down (from the glass side, towards the back) while lifting with the suction cup. I wiggled the blade (top to bottom) while pressing down gently, until I saw a gap that would accept the spudger. It did not take much force on the blade or much wiggling, just patience.
I would skip right to using a single edge razor blade and a hair dryer to create the gap needed for the spudger.
Think plunging the toilet - it did not work for me for a long time. the suction cup would not stay held on a long pull. I found that tiny push-pull repeated motions, reseating the suction cup with each push slowly overcame the adhesive, and contributed heat :). I had it after about 50-70 cycles
seconding this comment from Ted ~~~ “the secret (as Jessica also noted) was to not use the angle of attack shown in the pictures, but to push it in more vertically along the bottom edge while pulling up on the suction cup. From there you can easily lever the tool to the lower angle-of-attack (as shown in the picture).”
I echo what everyone is saying here, the spudger just isn’t good enough for this and neither is a pick. The razor is the best way to go. I tried using a very sharp penknife blade and managed to damage my LCD (somehow!) and the bezel so I ended up having to buy a new screen display as well as a new battery. Think twice before doing this. Be prepared to shell out for a new screen just in case it goes wrong. You’ll also need the heat gun (the iopener was useless). If you do need to buy a new screen, make your life easier and get one with the speaker, forward-facing camera, home button, etc., already attached (you can then replace the home button) or you’ll end up having to transfer all these from your old display.
沿着iPhone的下边向左移动动撬棍。
移动撬棍以扩大屏幕和后壳之间的间隙。
minimalist - 回复
I used a hairdryer and a razor
The photos are a con. You cannot get a spudger in unless you can lift the screen. You cannot lift the screen because of the adhesive. Using a anything metal will damage the paintwork or the glass edge.
I agree, these guides are half imaginary idealism it seems. A thin metal edge pushed vertically down just a fraction of a mm will cause the adhesive to weaken better than any amount of heat, but affects the final appearance sadly.
将撬棍头从iPhone左侧拉出,从下边缘开始,朝向音量控制按钮和静音开关移动。
Be VERY careful on this next step going up the right side of the phone. There is a ribbon cable 1/3 of the way up from the bottom that is very close to the edge. Do NOT use the blue triangle!!!! Just lightly rotate the spudger to get separation on the edge.
上拉吸盘抬起屏幕从而打开iPhone。
do not pull up pull sideways it will brake
Made this mistake
Somehow my phone turned itself back on during the opening. Scared me a little, like a patient coming out of anesthesia during the operation. I was able to turn it back off. Gotta be more careful where you grab this thing.
沿着iPhone的顶部边缘滑动拆机片,将屏幕与外壳彻底分离
The plastic clips mentioned are on the top of the screen being replaced… so not sure why it matters not to break them. Trick here was to pull the screen downwards to open a gap at the top and then insert as shown and raise to break the seal.
This is relevant for other guides than the display replacement guide.
jvalaamo -
将屏幕从手机顶端轻轻向下拉动来松开塑料卡扣的连接。
从左侧像翻书一样翻开显示屏来打开iPhone。
same dude im such a freak lol omg haha
Are there replacements ribbons?
Has anyone else noticed very small squares of rubber with a circle cut through it (I think they fall off into the phone when dismantling)?
I just replaced my screen and worked out that these are actually a wee pocket that slips over the pentalobe screw holes on the replacement screen. I’m not sure if it’s an additional water resisting mechanism or if it’s to add additional traction for the screws
Thanks, I was wondering where those were from!
Albert -
Same, I only had one fall out and I had no idea if important, and didn’t re-add - because I wasn’t sure where it fell from - but it was definitely from the home screen button….watch it be important. -__-
I just broke cable connecting camera and earpiece speaker to logic board. Be careful with it.
This section is missing a critical step - to lay some Post-It notes or something below the right half of the phone when you swing it open, so the ribbon cables don’t get sliced by the sharp edge of the phone case. I broke the Home Button ribbon cable because there was no strain relief when I laid it open.
I also broke the home button cable and now I have to use assistive touch.
Keep the suction cup on the display to keep it propped up while you disconnect the ribbon cables.
minimalist - 回复
I broke the short ribbon cable that attaches underneath the lower connector bracket. Be SURE when you lift the display, you do it from left to right. I thought I had the phone oriented correctly in my hand, but I was mistaken.
no mention of what you do once u open the book. are the ribbons long enough to lie flat or do we have to keep screen raised while removing screws,, like when we hold screen up 45 degrees while removing 5 screw plat when at top of phone. I only realised how fragile the ribbons are and how important it is to use suction cup to rest screen on an angle so ribbons don't stretch or cut on frame.
thanks for the above comments and probably the most important section. I just hope I closed t before I fdid any damage. its lke the fragility of iPhone 3’s all over again.
I just broke one of the cables… yeah, it is not nice… I’m lucky in the sense the screen is still working, but the button is not.
Trying a cheap screen on Ebay (that contains the cable) do 20$, after that, it’s a new cellphone…
从下侧连接器支架上拆下以下长度的四颗三点式 Y000 螺丝:
三个1.2mm螺丝
一个2.4 mm螺丝
维修过程中,使用磁性垫来记住每颗螺丝所对应的位置,避免重新安装的过程中螺丝安装错位损伤您的手机。
These screws just spin for me. They don't back out, but the heads aren't stripped either. I've tried applying backpressure to help lift the screws, but no luck
Jeff Hurst - 回复
What driver do I need to remove these screws i’m stuck
i cant use, the Y000 it isnt working.
What if I stripped a screw what do I do??
Yep, only the 2.4mm came out, other 3 won’t budge, and worried I’ve stripped the heads. Anyone got any ideas?
It’s the screwdriver bit that is the problem. I had the same issue with 2 Y000 bits not grabbing the screw properly. I fixed it by using a small 3 sided file to slightly grind the groves in the Y000 bit just a bit deeper. Then the bit worked like a charm on these screws.
Use Y000 on all 4. U have to be very sensitive on the 1.2mm screws. Put the bit in the screw, put the left pointing finger on top of the screwdriver and turn the driver carefully to the right until you feel a “bump”, thats the trick :-), then you are able to screw the screw out.
For me the key here was a LOT of downward pressure to ensure the Y000 bit caught in the screw. Not sure i can describe how much exactly, but is was significant. Otherwise the bit would not catch.
What do I do if I Stripped one of them?
Can’t get them removed what to do ?
Managed to get the central one out. The upper one won't move, the lower one I've popped out with some force. This allows you to rotate the cover enough to unplug the various bits. Not ideal, but works. I've tried applying a lot of pressure, using the tighten/ loosen method, but the heads have just got mashed… no wonder Samsung are now No1, sigh…
You need to be careful when just rotating the cover as you can accidentally slice through the two black antennas! You only need to nip them…As you can tell I have done this in the past :/
The first, longer screw came out fine, but the other three wouldn’t budge, regardless of more/less pressure or a slight angle or anything. I finally filed down the tip of the Y000 bit ever so slightly, and then it worked. Hope this helps someone.
Filing down the bit worked for me. The tip about putting an index finger on the end of the screwdriver handles and then turning gently until it clicks into place was very helpful! Using these 2 tips I didn't need much downward pressure. Screws are out in a few turns.
Mine came out easily. I placed the screws in the area where the bit goes in my kit so I can keep track.
I use a 28 day pill box and keep every screw separate and reburn to exact slot because they all vary in length, width and can really damage u phone if too long and nt secure if to small. use a magnetised screwdriver, or make the cheap freebees magnetic for a short period by rubbing it up an a magnet. lol
Absolutely ridiculous had to go get a different one just stupid
Was able to get the outer bracket screws out using fine needle nose pliers 90 degrees straight down for the outer ones by pressing down a little and using medium gripping force. Had to take these out first before i could use tweezers on the middle one, for which I had to use tweezers to hold the screw, then rotating the bracket (not the screw) counter clockwise a few mm many times over to slowly unscrew it 1/32th of a turn at a time, repeat. (this loosened middle screw). Think ‘rotating bracket 3minutes/degrees counterclockwise at a time while holding screw in place.) You are gonna need really small/fine pliers and tweezers for this because the heads are countersunk into the bracket.
To help tell if the screw is turning, put a small dot from a marker on the head of the screws. This helped me to know I wasn't just stripping the head.
卸下下侧连接器支架。
my battery cable connector was stuck to the bottom of this metal bracket plate so be careful when you lift it off
This may have been intentionally done by Apple to make sure the battery gets disconnected before any other connector is disconnected. So always make sure to disconnect the battery before disconnecting and reconnecting the connectors for the display.
So…I forgot to put this bracket back on when reassembling. Now I’ve adhered the display to the case and don’t have another adhesive strip…so I’m wondering: what purpose does this bracket serve? The phone is powering on and seems to work okay.
Am I going to run into trouble with this bracket missing?
Well, that didn’t last long. The phone shuts down without warning. So I guess that plate is important…
Thanks, Josh Martin! Mine was stuck too, so I lifted carefully.
使用撬棒尖端将电池连接器从逻辑主板上的插座中翘起。
Was kann passieren wenn man diesses Kabel vergessen hat zu entfernen `?
Reconnecting the battery poorly can cause the iPhone to appear to be properly powered and functional, but then suffer a reboot loop.
I had difficulty after a screen replacement, and the Console app on my Mac showed that the ‘thermalmonitord’ process was throwing lots of errors from not getting any sensor readings from the battery. It would never charge past 1% and just kept rebooting.
The contacts on this conector looked fine so even though I had reseated this connector several times already, I reconnected it very firmly using my thumb and a spudger to really press all the corners and middle and really gave it a good massage and then finally it showed the normal dead battery screen and started properly charging and eventually booted back up to normal functionality.
It seems the battery has to be able to transmit data to the phone to say it’s not overheating or iOS will not allow any current into the battery to recharge it, and the kernel will panic from the null readings and just reboot over and over again.
In my case, the battery connector was attached to the bracket. We just left it connected bracket when we pryed it up.
Reconnecting the battery connector was a bit difficult in my case. The cable that comes out of the battery was a tiny bit too long, or that I placed the battery a bit too high (i.e., too close to the top of the phone). It took me several frustrating minutes of fiddling with the connector for it to sit right into the socket. I was not sure if that was connected correctly but, alas, the phone came back to life when it was turned back on.
使用撬棒或者指甲来将两条显示排线从逻辑板上的插座中撬出。
To be honest you don’t really need to disconnect the display cables in step 15 or 16 to get the battery out. Just keep the suction cup on the screen to keep it propped up and to give the cables some slack. The only reason to take these cables off is that it’s a pain to apply the replacement display adhesive with those cables in the way. If you’re not re-waterproofing your phone just leave these attached.
minimalist - 回复
MAKE SURE you hold the top screen when dislodging the cable connections. I let the screen lie flat down and ended up tearing one of the cable connections, now my touch ID does not work at all! I’m going to have to order a whole new screen.
Don’t miss that SECOND CONNECTOR like I did. It will break very easily if not disconnected :(
I replaced the screen and have ended up with a blank screen. Touch control seem to work (touch button works and I can shut down the phone by pressing power button for some seconds and then swipe left to right in the upper part of the screen). But the screen is blank. I’ve tried to disconnect and connect the two connectors in step 16 but with the same result (blank screen). What do I need to do?
Thanks for advice!
this point is the most important in the whole manual.
Please pay attention not to strain the flex cables or they will end up breaking
I should have been more careful - the second cable tore off.
My own fault after having done this replacement about four times previously without any issues, I clearly got cocky and didn’t pay enough attention.
Be VERY CAREFUL and remember to unplug those cables. Don’t skip steps.
I’ve now had to order a replacement screen.
拆下固定前面板感应器组排线支架的两颗 1.3mm #000 十字螺丝。
取下支架。
Has anyone had trouble getting these two screws off? I’ve been working on these for about 10 minutes and the LEFT screw wont spin. It seems like the little PH000 screwdriver bit won’t even grip it. (The one of the right comes off, no problem)
It looks like I’ll have to pick this project up again with a screwdriver that will actually take off this piece.
If you’re having trouble removing these screws;
the screw on the right goes into a standoff screw that is screwed into the frame.The left one goes into the logicboard.
If your phone is used most likely it has been repaired in the past and the person that repaired it put the screws in way too tight.
If your phone is brand new And you know 100% it is then the problem is your screwdriver.Stop before you strip it completely and buy a better screwdriver (EBAY).
If you already stripped the screw head take the phone to a shop before you break it.
there are ways to get them out but truthfully it’s extremely dangerous and sometimes your better off quitting while you are ahead.
I used a #1 flat head tip to loosen.
I couldn’t get the two screws out either—used the correct screw tip and everything. Stripped the screw. Will now attempt to just keep the cable attached…..
Use the PH000 and apply a little more force before spinning, should come right out!
^To anyone having trouble, this is the correct answer. Put the phone on a firm surface, align your driver carefully, press down hard, and twist. As long as your driver is approximately the right size, it’ll come out.
the two screw i have are stripped and i have n way of getting either screws off whats my next bet
The PH000 bit is to large. I can’t get the screws out either which really sucks…now I have to put everything back together, find another bit that will work and try this again another day. Not impressed with IFIXIT’s attention to detail so far :-(
Using iFixit’s driver kit, I prefer a PH00 for this, which is larger than the PH000. If you think the PH000 is too big, something is wrong.
I think part of the issue with the iFixit PH000 is that it is slightly too pointy. The PH00 fits better because the splines engage the slots of the screw before the point bottoms out. The PH000 tip bottoms out in the screw’s center point and the splines don’t engage as well. I have other PH000 tips that are more blunt nose and they work better than the iFixit bit.
PH000 screwdriver didn’t work for any of these screws, or the barometric vent, or the taptic engine. It was too big. I had to use a different screwdriver from another kit I had.
minimalist - 回复
the cable tore. is that it i need a new phone?
You don’t need a new phone, but your selfie camera and phone speaker will not work. You can get replacements for that about $10.
jack jones - 回复
Reconnecting this cable and coverplate took a good 20 minutes. O_O
I also had issues to loosen up the screws, in two parts the right side up and the left side down, i think the PH000 is to pointy or something or its too hard for the srews of the iphone, i cannot take it off and know im regreting i bought i order all the way from Paraguay in south america and know so angry it doesnt work
I skipped this step. Just be really careful not to pull on the screen.
从主板的插座上断开前面板传感器组件排线插头。
Das ist sehr mutig, das Kabel dort so zu strapazieren.
Mich würde das Display daneben stellen und mit irgendetwas stützen, dass es nicht umkippen kann um Beschädigungen an dem Kabel zu vermeiden. Das reißt sehr schnell ein.
Is this the connector for the earpiece, as well? I did the screen replacement and everything worked, except now I can’t use my earpiece… I’m afraid I didn’t fully connect this particular portion.
Victor Bui - 回复
@victorbui714 Correct, this is also the connector for the earpiece speaker. Check the flex cable carefully and make sure it wasn’t pinched or torn. Make sure the connector socket is clean (give it a blast with some compressed air if needed) and try reseating it. If that doesn’t help, you may want to remove the earpiece speaker and inspect the four springs on the back, and check that they’re intact and making good contact with the four circular pads on the flex cable. Give the pads a wipe with some IPA and try not to leave any skin oils on them. If none of that works, try replacing the entire flex cable/sensor assembly. Good luck!
移除显示屏部件。
When removing the screen, be aware of the two tiny square black rubber grommets on the Penelope screw brackets that secure the screen. They can fall off very easily and be lost without even knowing it (it happened to me, but was lucky enough to find them).
Guy Cooley - 回复
Sorry, I’m so unclear about when to replace the Adhesive tape. Should I put the iPhone 7 Display Assembly Adhesive at this step, or after I’ve replaced the battery?
Victor Bui - 回复
@victorbui714 Battery first, then adhesive during reassembly, as it says in the instructions. ;)
This is the 3rd screen iv put in my phone and everyone them bust at the top by the camera every time iv bought one of these screen idk if it’s the manufactures fault or what?
trent bost - 回复
@trentb28922 Ouch! That’s not normal. Is your phone’s frame bent? Are you having to use a lot of force when you install the display?
卸下两颗将气压计固定到后壳的1.9mm P000 十字螺丝。
卸下三颗将Taptic Engine固定到后壳的 1.6mm P000十字螺丝。
My screws are stripped here. Please help, I don’t know what to do!
Hey Salva and Kyle, sorry to hear about all these stripped screws! For help with removing them, check out our guide.
I had my 7 battery replaced by an Apple Authorized dealer. Around 2 weeks after the taptic engine started to make a !&&* of a noise when it was activated (sounded as if it was loose)… then 1 month after that… it stopped working completely. fast forward 8-9 months later, the battery they had replaced just wasn’t holding its charge anymore (phone was spending more time plugged in charging and depleting very quickly = full charge lasted about 1-2 hours). Having bought the ifixit battery and have gotten as far as this step, I could see that all three of the 1.6mm screws were just floating around in the compartment and the taptic engine was just being held on via it’s ribbon lead. WTF?! Screws aren’t stripped and I managed to fix it in again. Why would these screws be floating around like this??
使用钝头镊子将电池下边的一条胶带剥离。
I can recommend preheating - first phone attempted without preheating both strips broke almost instantly, but this time heating the back of phone until battery felt about 40 degrees made for a smooth removal, saving me ages prying it out with cards…
Definitely preheat. Don’t even bother trying to pull out the tabs without preheating the back.
慢慢地将一块电池胶片朝iPhone的底部方向从电池中拉出,。
拉的时候要平稳用力,保持胶条上的恒定张力,直到其从电池和后壳体之间滑出。 为了获得最佳效果,请以60º或更小的角度拉胶条。
Same here, I had to work it out with the guitar pic they give you.
greggammon - 回复
How do you keep it from wrinkling without tearing
After a past experience with the adhesive strips immediately tearing on an iPhone 4, I knew to heat the battery with a hair dryer before pulling on the strip. After heating the battery, I was able to pull the adhesive strip without any problems.
First one worked perfectly as it was seen in the video. The second one teared immediately. I lifted the battery a little by a spudger and used the tweezers to pull out the white part and grabbed with my fingers and gently pulled it slowly, which worked.
A very good way I found when I, as probably many others, made the straps snap; a way I definitely will apply next time if I do this: use a spudger and “spinn” the white tejp out. Working with the hands trying to pull it out was not ideal… So:
Stick the tejp on/around the spudger and roll it up/out on the tip on the spudger. Once it grips hold on the spudger and you roll it, it almost eats it way out.
Otherwise it would have taken me ages to get it out but yes, if it snaps (or from start) you can get hold of it under the battery then you definitely have a substitute solution here.
The spinning spudger worked really well! That and heating it first made it a breeze.
Joe -
如果任何胶带断掉但是带你吃仍然卡在后壳上,请准备一个iOpener或者使用吹风机来直接加热后壳的外部。 加热温度应该保持在温热,可以舒服触摸的范围。
将手机反过来然后使用塑料卡片来切断电池后面残留的粘合剂
将电源线上的牙线或绳子穿过电池上端,将两端拿在一起,用折叠的布包住,然后均匀拉出。
Bij mij brak ook een van de kleefstrips , ik heb toen de batterij een heel klein beetje opgelicht en er wat isopropyl (alcohol) laten tussenlopen en dan een halve minuut gewacht . Vervolgens heb ik heel voorzichtig in combinatie van een Plastic card en een iSesamo opening tool (deze zijn beiden hier te koop bij iFixit), de batterij kunnen los wrikken zonder dat deze beschadigd of geplooid was.
将电池从后壳上取下。
重组后,请强制重启,这样可以预防一些问题的发生并会简化故障排除难度。
After I replace the battery, should I put on the iPhone 7 Display Assembly Adhesive and then follow the steps in that guide to reassemble?
Victor Bui - 回复
Follow this guide for the display adhesive. There should be a link here for it. iPhone显示屏粘合胶的更换
minimalist - 回复
==> Step 18 !
VauWeh -
There should be directions as to how to locate the new battery in the case! There is enough freedom of movement that the battery could be glued back into the case and not be able to make the battery connection. Some temporary spacers would be a great idea.
I put the Taptic Engine back in the case first. The battery seems to rest right against it, so it becomes a physical reference point. I cut out a piece of the plastic cover that came on the battery & put it over the battery connector mating point on the circuit board to keep the battery disconnected until necessary.
There should be a STEP 30 Instructions to refer you to the link for instructions for installing the REPLACEMENT SEALS. Or at least a big note saying to install the seal now before re-assembling
Bought kit, followed all the instructions, and now the Touch ID and home button don’t work on my phone, rendering it useless. Connections are fine, no obvious cable tears, I’ve checked and rechecked all connections … not to mention, what component did I even touch to render home button useless since it’s on the display screen? This is going to cost me. What a horrible experience that’s taken up 4 hours and cost me time and money. Can’t recommend just shipping phone back to Apple enough. One of the most disappointing experiences with a product in ages. And all just to replace a freakin’ battery …
John Cagle - 回复
I have the same issue :(
radeise -
Hello guyz. Please help me. I tried to replace my iphone 7 battery. When i was removing the 4 tri wing screws on the cover that is covering the battery cable Etc, I used many screwdriver because at first I didn’t know that those are tri wing screws. I ordered .6 tri wing screwdriver. I successfully removed the 2 screws but the other 2 cannot remove. I think they are stripped or they are damaged because of what i did pn my first try. I dont know what to do. My iphone battery health is 73 percent. I want them to be removed but i dont know how. Pleaseee help mee guyss. (Sorry if my english is bad, im from Philippines) please help me
若要重组你的设备,重新涂抹显示屏粘胶剂 并按照相反的顺序执行以下指南。为获得最佳性能,请校准新安装的电池:将手机充电至100%并将其继续留在充电器上至少两个小时。 之后开始使用手机,直到它由于电池电量不足而关闭,再将其不间断充电直到电量回到100%。
595等其他人完成本指南。
特别感谢这些译者︰
66%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
78条评论
yes , unless it is sealed back with new waterproof tape, which almost no one has yet
Atronx -
No you can buy the replacement. See the above guide for a link on how to do that and iFixIt sells them. Recommend buying more than one because installation is tricky - must get it aligned perfectly though the spluger and pointy tweezers can help reposition minor slipups.
Is there any way to put back the waterproof sealing after changing the battery for iPhone 7? Thanks
I too would like to know this! It's a shame they don't elaborate as such. There is this part here - Display Adhesive iPhone 7 Display Assembly Adhesive which I assume needs to be put on after the screen is taken off but this guide says it's not needed? But for a screen repair it is? Does it get placed on the phone housing or screen? Thanks
blitzn -
Yep, we have a guide for replacing the seal (display adhesive) now. I don't know how waterproof the seal will be afterward, but I think it's worth doing regardless.
Most of the adhesives that are being sold are not rated to be waterproof, and are not the geniune OEM brand materials.
Atronx -
Probably too late, but there are many vendors that sell the waterproof seal for iPhone7. Use alchohol and tweezers to remove the old seal and glue, align the new seal and stick it. Compared to the battery change, it’s a breeze.
Yes it is. Have a look at the iPhone Display Adhesive Replacement guide
steinmb -
Hi!
Now I got a huge problem concerning the HomeButton/ForceTouch-function.
It does not work anymore. I think it's a safety measure by Apple to prevent people from changing their batteries.
ANY HELP, please? :(
87schiller - 回复
Those functions aren't related to the battery. Double-check your work, reseat the cable connectors, and inspect the cables and home button hardware carefully for damage.
I know this is a month late, but hopefully this helps someone. On the 7, 3D Touch and the home button are routed through the same flex cable that comes out from underneath the metal backing of the display and plugs into the board.
This flex cable is very easy to pull and damage when taking the screen off for the first time. In most situations you won't see this damage because it will be underneath the metal backing of the display.
If this same thing happens to you, you'll unfortunately need a screen replacement to fix it.
My problem is with the 4 tri screws holding the 1st bracket down. They just spin, all 4 of them. The screw heads aren't stripped, as they all spin, they just don't back out. I've applied backpressure in hopes that would help lift the screws, but no luck.
Jeff Hurst - 回复
You dont have to remove the Taptic Engine but it gives you more room to work with the glue.
nicolay.94 - 回复
Hello there, I got a dead iPhone 7, so I tested the battery, and the only “weird” thing.. is that the battery is rated 3.8v… and on this one.. im having a reading of 4.1V…. maybe this overpowered issue is preventing the iPhone to turn on???
So, I changed the battery of my iPhone 7 with the kit provided by IFIXIT a couple of days ago, and cononutBattery is reporting that the battery is already at 95% (1862 out of 1960 mAh), with only 1 charge cycle. Is this normal?
Hi Federico
Did you try the following tip?
For optimal performance after completing the guide, calibrate your newly installed battery: Drain it below 10%, then charge it uninterrupted to 100%.
Takehiro -
The step by step guide can be converted to a pdf by selecting Options>Download PDF.
mnvery east to follow quide but i almoust did burn down my phone when i was removing battery it cathed on fire and i have no idea did i puncture it or what.
In any such venture, when dealing with precision components. DON’T RUSH, if you have any issue with hands that tremor for whateverr reason when handinlng small items, DON’T TRY THIS, LEAVE IT TO SOMEONE WITH STEADY HANDS !!
My iPhone 7 wasn't not charging. So, After searching on Google, I found this guide "iPhone 7 not charging". And, with this guide I get to know about that, my iPhone battery got damaged. And, My iPhone warranty also got expired. So, I have decided to replace the battery by myself. And, this guide really helped me to replace my iPhone battery. Just want to say thanks to you. :)
Can you pull the battery adhesive tabs without removing the Taptic Engine? Anyone tried that?
@balleklorin You certainly can, but you’re much more likely to break the adhesive strips that way. You want to pull them at as low an angle as possible, and with the Taptic Engine installed you’ll have to pull them at nearly 90 degrees. My advice is not to take shortcuts, but it’s your phone and your rules! Good luck.
Hi ! I want to do this repair but I read online that if I use a non-original battery Apple’s software will detect it and will slow down the phone (like it does for the damaged original battery).
Is it still true or is it fixed in the current IOS ?
Not true at all. As long as you have a high-quality battery, the iPhone’s performance is just as good as with a brand-new battery from Apple. If you have any doubts, you can verify the performance by benchmarking it with the GeekBench app.
Hi everyone, I’ve replaced my iPhone 7 Battery and for some reason i am still seeing the old battery readings (same percentage and same battery health percentage 80%) on battery settings. Will this fix after the battery gets calibrated?
Thanks.
my home button stopped working. Any ideas how to fix this ?
I‘ve done it step by step, everything went well. everything works, except touchID wont work.
could anyone tell me what the reason could be?
thank you lads.
Follow this guide for the display adhesive. There should be a link for it here in this guide. I had to go looking for it. iPhone显示屏粘合胶的更换
minimalist - 回复
super détail pour les vis et leurs tailles
ca va m’ aider , car au démontage rien etait fixé, et il en manque 2 ( au moins 12 vis en promenades)
donc avec le kit commandé je pourrai m aider des différents tuto pour retrouver leurs emplacements
cordialement marchal
Gros Lutin - 回复
Excellent guide, but may I make a couple of suggestions:
1) in step 18 this guide should strongly recommend that anyone doing the waterproof sealant replacement MUST watch the linked “iPhone Display Adhesive Replacement” guide FIRST considering that it does require an additional tool (no, I did not have enough pennies on me to do the recommended heat treatment followed by weight-pressing the reassembled iPhone assisted by said pennies).
2) also in step 18, you could point out that the forward camera assembly at the top of the front plate of the iPhone 7 has a hooked ridge that must be fitted into the bottom plate for the re-assembly to work at all. Personally I had NOT noticed that, so when I tried to reassemble mine I hadn’t tried to make sure that the ridge was properly placed. Could you add a picture here of that ridge and perhaps recommend that everyone working on disassembly that they should see how it works so they can recall it upon re-assembly.
I agree. Reassembly is NOT the reverse of the many steps! That ridge or plastic edge MUST be slid into first. Opening the iPhone doesn’t reveal that. Careful, because the waterproof glue can catch the battery cable too. Aligning the battery by connecting the battery cable/ribbon helps BUT be careful and remember to disconnect the battery BEFORE reconnecting the two data cables (Again, this would be obvious if the steps or reassembly pics were included. Number of steps = 60 more realistically because reassembly is just as important and risky!
BTW: when I first completed my re-assembly, when I first looked at my screen there was a set of greyish bands that covered about 1/3rd of the screen. Not so dark that clearly blocked the use of those parts of the screen but rather noticable. I shrugged my shoulders, thinking that perhaps there was some internal damage that I couldn’t help having done.
But less than 24 hours after that, that banding has been considerably reduced (covering less than 10%) AND it is much less grey. It is such that I must bring up an app like Notes in order to have a mostly blank white screen in order to see what remains, so perhaps this was merely an artifact left by the ending heating I did to “cure” the waterproof adhesive, and over time it will disappear entirely.
after doing this fix ive gotten a message - unable to activate touch id on this iphone —-its an iphone 7
super! merci
Home button not working after battery replacement.
karllittau - 回复
Thanks for the guide. Very helpful on two iPhones
For some reason i forgot to use the suction cup but was still able to open the phone without much difficulty (so don’t worry about needing iopeners etc. )
Of course one of my battery strips snapped, but with a bit of effort and pointed tweezers under the battery i managed to grab it after a few attempts and fully remove it.
Although you could do this without removing the screen, you will need to remove it to place a new sealant strip around the edge.
Just completed changing the battery on my Father-in-law's iPhone 7. He had purchased the phone used and I suspect the battery had been replaced previously as there was no adhesive seal holding the display to the case. In addition one of the screws holding the bracket was missing. Nonetheless the procedure went very well. The instructions were clear and easy to follow. The most difficult part of this project was removing the battery from the case as the adhesive broke almost immediately. Fortunately the tips that are in that step made removing the battery easy. Bottom line, read the instructions ahead of time, watch the video and TAKE YOUR TIME! Good luck!
I used this guide with the ifixit replacement kit and it went very well. I do wish though that the guide gave advice on how to install the new adhesive gasket when reassembling.
Hey Thomas! Glad to hear that everything went well. Sorry to leave you hanging on the adhesive install, we do have a guide but it’s a little hidden. iPhone显示屏粘合胶的更换
I followed every step. Replaced the battery. Played backwards every step. Now I am stuck with the Apple Logo slowly flashing on & off. I think I just killed my iPhone7. My Mac does not ‘see’ my phone when I connect it to iTunes.
i am not being able to do it… I have heated up the phone, to smooth the glue… but the cover doesn’t me off
Good instructions. Two things that would be nice to add to reassembly would be how to apply the adhesive and seal.
Tom Fields - 回复
My iphone fell in the toilet and was there maybe 5 seconds. I dried it and let it rest but then (I know) tried to to do things. The next day (I took it to a TekDry machine and they put it through for two half hour plus periods. After the first half hour, the start screen came back for a maybe a minute. (I almost paid.) Then nothing. I brought it home and plugged it in to charge it. After 5 hours (?) it began to flash- It was like a living creature trying to breathe- It would light up- then go dark- many times. I tried a hard reset and think I managed to turn it off. Now it is in a vertical position, off the charger. This is a newly refurbished phone. (I had it for a day)- I am wondering where I could take it to in Seattle for someone to open it up. It will turn on even now. Or should I give it a decent burial? I am in my 70s and techno-challenged. Any advice, expressions of gentle derogation or approval, are welcome.
Lyn Coffin - 回复
Getting the adhesive to loosen was the hardest and most frustrating part of this with me trying it multiple times for a few days. Simply “warming up” the phone did not work, I had to make it really, really hot in order to lift the phone a fraction of a millimeter with the whole thing flying around the room and me hitting myself in the face with the suction cup multiple times. Using a thinner metal plunger did the trick, but scratched my case. Nevertheless, it was the only way to open up that beast. A third hand would have been be nice for that job x)
Me too. I stopped and bought the tool that has two suction cups and looks like pliers. It allowed me to gently squeeze, release, squeeze and eventually it began to separate. Also, that tool kept me from pulling to hard or opening too wide thus saving the ribbon connections. The iFixIt heat tool worked better than a hairdryer.
hat geklappt, danke für die Anleitung!
LG Andreas von studi kompass
Completed. This is now the second 7 that I have successfully replaced the battery on.
I have to agree with some of the other comments - the re-assembly instructions might have helped!!! Instead of having to switch between guides to figure out how and when to apply the screen adhesive. I successfully dismantled the iPhone, replaced the battery, got through the majority of the re-assembly, realised the instructions hadn’t included the screen adhesive, searched for the instructions, then re-disconnect the screen AGAIN, apply the screen adhesive, re-assemble the iPhone completely this time, only to find I’d broken the display at some point!!!
Perfect install. Now phone is dead.
I missed the “forced restart” after reassembly. That created some angst for me wondering where the trusty white Apple logo was hiding. I reread the notes and found the forced restart. All is good. Super nice tutorial. Many thanks,
I’ve made it, after all. How dare you not saying that one need new adhesive strips and sealing AT THE BEGINNING of this instruction or OFFER IT IN THE INTRODUCTION as all the other stuff, I’ve asked!!!
Great kit and tutorial, I had it done in one shot without buying any extra strips! Just go slow and you’ll get there eventually. Oh and, keep the hairdryer nearby, it will be your bff for this! Good luck and many thanks to the people in the comments as your warnings have been really helpful!!
Worked OK. Hard bits is screen removal - I used very narrow screwdriver. Advise using piece of A4 with step numbers to place various screws and parts on as you remove. Some very tiny screws in there.
I followed all the steps perfectly and the battery shorted out (the back heated up really hot and the phone wouldn’t turn on). Then I tried to do it all again but the pentalobe driver is not biting into the screws anymore so I couldn’t open the case.
I replaced the battery and the Home Button no longer works. The are a few other comments posted on this here and a long chain in the iPhone 7 section. I have done a lot of troubleshooting to include reseating all the connectors , loosening the middle screw over the Home Button, hard resets, etc. No luck. I have done quite a few phone repairs successfully and have had good luck. I was very careful with this battery replacement and don’t know how I could have damaged a cable. Some repairmen suspect the heat application to loosen the seal. It’s the only reasonable explanation I can think of. I now have an iPhone 4 that looks like an iPhone 7!
Thank you so very much for publishing this very helpful instructions. They helped me sucessfully install a battery and save $33 doing it myself.
J’ai changé la batterie sans difficulté avec ce tutoriel. En revanche, la batterie se décharge rapidement même si le téléphone n’est pas utilisé, et même la lorsque le téléphone est éteint. C’est curieux et je ne sais pas d’où vient la panne: de la batterie ou du téléphone?
I replaced the battery, and put everything back together. When I turned on the phone I received “Touch_ID_Issue_Notification. Touch ID and home button do not work even though the screen and home button are the original. I rechecked all connection and ribbons and all red seated correctly and unharmed. I hard reset the phone (volume down/power button) and nothing works.
Anyone have any ideas oh to correct this issue?
me too i’m sorry to hear it. not sure what to do now haha f*ck
Thanks for tanking my home button.
Simple battery replacement causes home and haptics to stop working on an iPhone 7
Put a warning up.
you too?? any way to fix this?
my home button won’t work
Home button does not work after fitting new battery. I was very careful to not strain the leads while doing the job and have checked the leads with a magnifying glass and there is not a mark on them. Tried re-fitting old battery and all the other suggestions to be found on Google search but still nothing. Is there any diagnostic software to test it?
what is the “vent” for? on the opposite side of the main loudspeaker
It is for the microphone.
Can anyone confirm 7/7P's pentalobe screws have a ring of seal near the screw head?
Cooper Chase - 回复
Confirmed, the screws have a black ring seal around the head.
rcheing - 回复
Can’t get the display front
Bernadette Pfeifer - 回复
From personal experience, I highly recommend before doing this procedure or any other, that you do a backup of your phone (preferably local) in case your procedure goes south.
ballina5ny - 回复
I purchased the repair tools with the replacement battery from iFixit. The tools include a screw driver and three heads none were labeled 3.4 mm. I think the one that fit the pentalobe screws was labeled Y000. The guide should identify the screw driver head supplied by the kit not 3.4mm.
Mark Lieberman - 回复
in the iphone 7 replacement battery kit from iFixit, the screwdriver that fits the 3.4 mm pentalobe screws is labeled P2 (and not Y000)
Jan-Tijn Oppermann -
the screwdriver PH000 does not work i wasted two screws and now they dont have the 4 cross mark they are now a circle, i buyed it all from Paraguay and it doesnt work, had to assembly back the parts because i got stuck like i mention with some screws, well im just going to send to a professional to install, thanks
Martin Frutos, Nuñez - 回复
The bottom screws are Pentalobe, not Phillips.
Bram Driesen -
Before starting, I would recommend backing up your Iphone’s data just in case.
Jon Moylan - 回复
If you managed to make it to this section, just send the phone into apple for 50 + 6 dollars shipping. The ribbon cables on the screen are designed to break. I can literally twist on the rest of the cable and it won’t fall apart but there is a diagonal section where it snaps. This is the fault of apple and the fault of ifixit for misrepresenting the fragility of the cables.
Ryan Huebert - 回复
Had to reheat it a few times for a minute each with a hairdryer to get the seal to break after pulling and rocking the suction
Cynthia Lamb - 回复
