跳转到主内容
iPhone 6s Screen Replacement
你所需要的
  1. iPhone 6s Screen Replacement, Pentalobe Screws: 步骤 1 中的图像 1,1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
  2. iPhone 6s Screen Replacement, Tape over the display: 步骤 2 中的图像 1,3 iPhone 6s Screen Replacement, Tape over the display: 步骤 2 中的图像 2,3 iPhone 6s Screen Replacement, Tape over the display: 步骤 2 中的图像 3,3
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
  3. iPhone 6s Screen Replacement, Anti-Clamp instructions: 步骤 3 中的图像 1,3 iPhone 6s Screen Replacement, Anti-Clamp instructions: 步骤 3 中的图像 2,3 iPhone 6s Screen Replacement, Anti-Clamp instructions: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Anti-Clamp
    $24.95
    购买
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 6s Screen Replacement: 步骤 4 中的图像 1,3 iPhone 6s Screen Replacement: 步骤 4 中的图像 2,3 iPhone 6s Screen Replacement: 步骤 4 中的图像 3,3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  5. iPhone 6s Screen Replacement, Opening Procedure: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    Anti-Clamp
    $24.95
    购买
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  6. iPhone 6s Screen Replacement: 步骤 6 中的图像 1,1
    • Opening the display on the 6s separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • Take care not to place the suction cup over the home button.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  7. iPhone 6s Screen Replacement: 步骤 7 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 7 中的图像 2,2
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
    • If you have any trouble, heat the front of the iPhone using an iOpener, hair dryer, or heat gun until it's slightly too hot to touch. This will help soften the adhesive securing the edges of the display.
  8. iPhone 6s Screen Replacement: 步骤 8 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 8 中的图像 2,2
    • There is a notch on the underside of the display, just above the headphone jack. This is the safest place to begin prying the phone open.
    • Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
  9. iPhone 6s Screen Replacement: 步骤 9 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 9 中的图像 2,2
    • Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
  10. iPhone 6s Screen Replacement: 步骤 10 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 10 中的图像 2,2
    • Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case.
    • Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
  11. iPhone 6s Screen Replacement: 步骤 11 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 11 中的图像 2,2
    • Remove the spudger and reinsert it on the bottom edge, where you pried the phone open.
    • Slide the spudger to the right, along the bottom edge of the phone.
  12. iPhone 6s Screen Replacement: 步骤 12 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 12 中的图像 2,2
    • Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
  13. iPhone 6s Screen Replacement: 步骤 13 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 13 中的图像 2,2
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90º, as it is still connected at the top by three cables that may break if stretched.
  14. iPhone 6s Screen Replacement: 步骤 14 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 14 中的图像 2,2
    • Pull up on the nub on the top side of the suction cup to remove it from the front panel.
  15. iPhone 6s Screen Replacement: 步骤 15 中的图像 1,3 iPhone 6s Screen Replacement: 步骤 15 中的图像 2,3 iPhone 6s Screen Replacement: 步骤 15 中的图像 3,3
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  16. iPhone 6s Screen Replacement, Battery Connector: 步骤 16 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    购买
    • Remove two Phillips screws securing the battery connector bracket, of the following lengths:
    • One 2.9 mm screw
    • One 2.2 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  17. iPhone 6s Screen Replacement: 步骤 17 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 17 中的图像 2,2
    • Remove the battery connector bracket from the iPhone.
  18. iPhone 6s Screen Replacement: 步骤 18 中的图像 1,3 iPhone 6s Screen Replacement: 步骤 18 中的图像 2,3 iPhone 6s Screen Replacement: 步骤 18 中的图像 3,3
    • Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
  19. iPhone 6s Screen Replacement: 步骤 19 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 19 中的图像 2,2
    • Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
  20. iPhone 6s Screen Replacement, Unfasten the display cable bracket: 步骤 20 中的图像 1,1
    • Remove the following four Phillips screws securing the display cable bracket:
    • Three 1.2 mm screws
    • One 2.8 mm screw
  21. iPhone 6s Screen Replacement: 步骤 21 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 21 中的图像 2,2
    • Remove the display cable bracket.
  22. iPhone 6s Screen Replacement: 步骤 22 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 22 中的图像 2,2
    • Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
  23. iPhone 6s Screen Replacement: 步骤 23 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 23 中的图像 2,2
    • Disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  24. iPhone 6s Screen Replacement: 步骤 24 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 24 中的图像 2,2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the display cable by prying it straight up from its socket on the logic board.
  25. iPhone 6s Screen Replacement: 步骤 25 中的图像 1,1
  26. iPhone 6s Screen Replacement, Home Button Assembly: 步骤 26 中的图像 1,1
    • Remove the three 1.7 mm Phillips screws securing the home button bracket.
    • Do not over-tighten these screws as these can damage the front of the display.
  27. iPhone 6s Screen Replacement: 步骤 27 中的图像 1,3 iPhone 6s Screen Replacement: 步骤 27 中的图像 2,3 iPhone 6s Screen Replacement: 步骤 27 中的图像 3,3
    • Lift the lower edge of the home button bracket until it clears the small peg on the right side.
    • Slide the bracket out from under the EMI shield to remove it.
  28. iPhone 6s Screen Replacement: 步骤 28 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 28 中的图像 2,2
    • Use a spudger to disconnect the home button connector by popping it out of its socket on the back of the display panel.
  29. iPhone 6s Screen Replacement: 步骤 29 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 29 中的图像 2,2
    在这个步骤中使用的工具:
    iOpener
    $19.99
    购买
    • The rubber gasket surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
    • Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
  30. iPhone 6s Screen Replacement: 步骤 30 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 30 中的图像 2,2
    • Use the pointed tip of a spudger to carefully separate the home button flex cable from the back of the display panel.
  31. iPhone 6s Screen Replacement: 步骤 31 中的图像 1,2 iPhone 6s Screen Replacement: 步骤 31 中的图像 2,2
    • Remove the home button assembly.
  32. iPhone 6s Screen Replacement, Screen: 步骤 32 中的图像 1,1
    • Only the screen remains.
结论
1381等其他人完成本指南。
Jeff Suovanen
于08/06/13注册
427,786 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,718篇指南
138条评论
Muito bom. Já aprendi muito consultando os tutoriais da IFIXIT. Parabéns.
Eder Macario - 回复
Solution worked very well - a couple of comments: 1. With a cracked screen the suction cup doesn't hold very well, I was nevertheless able to get the screen corner off with some heavy prying above the headphone jack as suggested in step 4. 2. In the replacement part I received, the order of the digitizer and camera cables was reversed, I had to tuck the digitizer cable back under the camera cable to get them down in the correct order. Great pictures and guide from ifixit.
stread777 - 回复
Agree with both points. The guide is also missing steps (or mention of) moving the camera/sensor/etc to the new digitizer. I didn't think about it until I wondered why the old screen had 3 cables and the new one only had 2.
nerdatheart -
Thanks for the tip, I had the same issue with the suction cup not working on the cracked screen. Applying clear packaging tape over the screen helped but it still didn't come apart. Ended up using a blow dryer on the highest setting to help melt the adhesive around the bottom of the phone (being careful to not let it heat up too long) which eventually made it possible to wedge the spudge inside.
The guide and photos were great along with the replacement part from iFixit. Probably the easiest screen replacement I've done so far.
gotchay -
Try putting packing tape in the center of the screen. This will keep the glass chunks in and the suction cup will stick to it.
Michael St. Hilaire -
添加评论
浏览统计数据:
过去 24 小时: 65
过去 7 天: 447
过去 30 天: 2,095
总计 983,891
