跳转到主内容
iPhone 6s Plus Opening Procedure
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. iPhone 6s Plus Opening Procedure, Pentalobe Screws: 步骤 1 中的图像 1,1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
  2. iPhone 6s Plus Opening Procedure, Opening Procedure: 步骤 2 中的图像 1,1
    • Optionally, apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  3. iPhone 6s Plus Opening Procedure: 步骤 3 中的图像 1,1
    • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
  4. iPhone 6s Plus Opening Procedure: 步骤 4 中的图像 1,2 iPhone 6s Plus Opening Procedure: 步骤 4 中的图像 2,2
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
  5. iPhone 6s Plus Opening Procedure: 步骤 5 中的图像 1,3 iPhone 6s Plus Opening Procedure: 步骤 5 中的图像 2,3 iPhone 6s Plus Opening Procedure: 步骤 5 中的图像 3,3
    • The safest place to pry from is the notch in the front panel above the headphone jack.
    • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
  6. iPhone 6s Plus Opening Procedure: 步骤 6 中的图像 1,2 iPhone 6s Plus Opening Procedure: 步骤 6 中的图像 2,2
    • Twist the spudger to widen the gap between the front panel and the rear case.
  7. iPhone 6s Plus Opening Procedure: 步骤 7 中的图像 1,3 iPhone 6s Plus Opening Procedure: 步骤 7 中的图像 2,3 iPhone 6s Plus Opening Procedure: 步骤 7 中的图像 3,3
    • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
  8. iPhone 6s Plus Opening Procedure: 步骤 8 中的图像 1,2 iPhone 6s Plus Opening Procedure: 步骤 8 中的图像 2,2
    • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
  9. iPhone 6s Plus Opening Procedure: 步骤 9 中的图像 1,2 iPhone 6s Plus Opening Procedure: 步骤 9 中的图像 2,2
    • Insert the flat tip of the spudger under the right edge of the display.
    • Slide the spudger up the right side.
  10. iPhone 6s Plus Opening Procedure: 步骤 10 中的图像 1,2 iPhone 6s Plus Opening Procedure: 步骤 10 中的图像 2,2
    • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
    • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
  11. iPhone 6s Plus Opening Procedure: 步骤 11 中的图像 1,2 iPhone 6s Plus Opening Procedure: 步骤 11 中的图像 2,2
    • Pull up on the small nub on the suction cup to remove it from the display.
  12. iPhone 6s Plus Opening Procedure: 步骤 12 中的图像 1,3 iPhone 6s Plus Opening Procedure: 步骤 12 中的图像 2,3 iPhone 6s Plus Opening Procedure: 步骤 12 中的图像 3,3
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to support the display.
结论
另外一个人完成了本指南。
Dante Mazzanti
于07/13/15注册
36,177 声望
创作了26篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 774
