简介
此指南会教导你如何更换你iPhone 6s Plus 里的Lightning 接口排线。此排线组包含耳机孔与Lightning 接口。如果你手机在透过USB充电或连接有问题时, 或是耳机孔失去功能时, 更换此零组件, 能帮你解决以上的问题。
注意在保留逻辑主板的情况下也是可以更换这个配件的,跳过第22—37,第40—49 和第53步。在第56步,不要移除扬声器,你必须要么仔细把它移到外面,要么把它从黑色天线上移除。然后,当移除 Lightening 接口组件的时候,你必须格外小心,不要撬刀主板或电池。
使用这个方法后,你的维修空间很小。但可以省下很多步骤。
你也可以参考以下其他指南。
你所需要的
如要组装的话, 请按逆序操作。
如要组装的话, 请按逆序操作。
163等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
24条评论
Hardest thing I have every done!! But well worth it. Now I know I need to go up on my labor price!!! :-) Thanks a ton from South Carolina!!
I just completed this repair, replacing the Headphone Jack/Lightening port, battery and iSight camera all at the same time. I removed everything as it explained in the guide, but can totally see how not removing the logic board would save time and isn't 100% necessary. I imagine that peeling the upper portion of the headphone/lighting port is slightly easier with the logic board removed, and you don't have to worry about that antenna cable. If I did it again, I would probably still remove the logic board.
you would have to be crazy to remove the board. just flip the speaker up on its back and rest against logic board. 20 mins should complete this . i cant stress enough that board or camera does not need removed . PERIOD
I completed this and it starts charging, but the home button stop working. It still sense my finger print, but it does not respond when i click on it.
Any help?
