你所需要的
视频概述
将蓝色的手柄朝铰链的方向拉,以解除反向钳的分离模式。
将支撑臂滑过 iPhone 的左边缘或右边缘。
将两个吸盘放到Home键上方的屏幕——一个在前,一个在后(屏幕朝向自己的地方为前)。
将上方吸盘向下压以施加吸力到目标位置。
如果你在拆卸电池时仍有困难,可在电池边缘的破损胶条区域滴几滴高浓度(90%或更高)的酒精。
将手机向上倾斜,使酒精能够流向胶条。
保持手机倾斜,并稍等1-2分钟,让酒精削弱粘合剂。
使用撬片或撬棒的平头,慢慢撬起电池。
将新的更换配件与原始配件进行比较 —— 在安装之前,你可能需要转移剩余配件或从新配件上移除粘合剂背衬。
如要组装的话, 请按逆序操作一下步骤。
将你的电子废料带到R2 或 e-Stewards 认证的回收商。
维修不像计划中一样进行?查阅[links|https://www.ifixit.com/Answers/Device/iP...|问题解答论坛]来排查错误。
如要组装的话, 请按逆序操作一下步骤。
568等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
92条评论
Most common on IPhone 6s/6 repair jobs is this battery replacement. Great tutorial!
so few comments on this one?!
has any/many done this without the adhesive strips.. and was it ok?
If you mean the battery adhesive strips, sure—you can put a piece of double-sided tape down the back of the battery, and it probably won't move anywhere. There's not much room for the battery to move anyway. Use the adhesive strips if you want to do it right—but, if you're in a bind and you just need the phone working, you can skip the strips. And you can always open the phone back up and add the adhesive strips later.
If you mean the adhesive gasket around the display, the answer is pretty much the same—It's better to have it, but it doesn't hurt anything to put the phone back together without it.
Where can one buy the adhesive gasket for the case
